ASA5520 Problem
Hi dear all :
I have a strange problem , when I try to save my configuration on the asa5520 I get the error massege that say
"%Error reading system:/running-config (Configuration line too long)
Error executing command
[FAILED]"
I check the memory and cpu and I fine it is ok and there is a space
so any one can help please?
1 ACCEPTED SOLUTION
Gold
Re: ASA5520 Problem
It looks you are hitting bug CSCsg87808
Taken from Cisco Bug tool
CSCsg87808 Bug Details
'wr mem' fails due to snmp config; Error: (Configuration line too long)
Symptom:
If snmp-server commands are configured, in a rare corner case
the configuration might fail to save to flash and give the error like below:
pix# wr mem
Cryptochecksum: ee8f5816 e1ce1ad7 83151424 f1a3b6fc %Error
Error executing command [FAILED]
Conditions:
The firewall must have snmp-server commands configured and running
version 7.2(1)25 or greater (includes 7.2(2)).
Workaround:
Remove the snmp-server commands from the configuration
-or-
downgrade to a version of code previous to 7.2(1)25
Gold
Re: ASA5520 Problem
Symptom:
pix# wr mem
Conditions:
Workaround:
-or-
Re: ASA5520 Problem
Thank you M.Sir:
Yes the snmp-server command was the problem
I remove the command and it is work ok , so thank you frined I have rate your solution
emad Frag
187
