ASA5525, No IPS, Upload Speed Very Slow
We recently replaced a MS-TMG firewall with an ASA5525, no IPS, and now the upload speeds are very slow – 15K/sec. The ISP service is 100Mb, speedtest indicates 90Mb down and 30Mb up. The interface connections are set to auto, they are both connected at Full / 1000Mb, and, there are no errors.
Any assistance is greatly appreciated.
Thanks.
Paul
speedtest from inside asa?
no - speedtest.net from my PC
no - speedtest.net from my PC.
Hey there,To troubleshoot
Hey there,
To troubleshoot these kind of problems you need to isolate the issue , try to check upload speeds during non-production hours by sending some traffic via ftp/tftp from asa. There could be some rough pc in your network sending some unwanted data to external world.
Try to pinpoint the issue.
We have tested uploading data
We have tested uploading data files from several different PC's to many different known services, including sharepoint, dropbox, etc... the upload rate is the same for all -- about 15K/sec. This was not the case just the day before replacing the existing firewall with the ASA5525. Additionally, we have connected some the same PC's bypassing the ASA and upload speeds are 18Mb/sec. Based on the troubleshooting methods used we believe the ASA is the issue.
Oh ok i think it could be
Oh ok i think it could be hardware issue as you've already mentioned there are no interface errors on the ASA , check input/output rate and try to hardcode speed/duplex settings. Last option is to open TAC case. Thank you
ASA1# sh int inside
Interface GigabitEthernet0 "inside", is up, line protocol is up
  Hardware is Linux Ethernet Dev, BW 100 Mbps, DLY 100 usec
        (Full-duplex), (100 Mbps)
        Input flow control is unsupported, output flow control is unsupported
        MAC address 0000.abe4.0600, MTU 1500
        IP address 10.0.0.1, subnet mask 255.255.255.0
        0 packets input, 0 bytes, 0 no buffer
        Received 0 broadcasts, 0 runts, 0 giants
        0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
        0 pause input, 0 resume input
        0 L2 decode drops
        1 packets output, 42 bytes, 0 underruns
        0 pause output, 0 resume output
        0 late collisions, 0 deferred
        0 input reset drops, 0 output reset drops
        input queue (blocks free curr/low): hardware (0/0)
        output queue (blocks free curr/low): hardware (0/0)
  Traffic Statistics for "inside":
        1 packets output, 28 bytes
        0 packets dropped
      1 minute input rate 0 pkts/sec,  0 bytes/sec<-------------------------
      1 minute output rate 0 pkts/sec,  0 bytes/sec<-------------------------
      1 minute drop rate, 0 pkts/sec<------------------------------------
      5 minute input rate 0 pkts/sec,  0 bytes/sec
      5 minute output rate 0 pkts/sec,  0 bytes/sec
      5 minute drop rate, 0 pkts/sec
Below is output for both
Below is output for both interfaces -- please let me know if there are any outstanding issues that need to be looked at further toward resolving the upload performance problem. Thanks.
Result of the command: "sho int g0/0"
Interface GigabitEthernet0/0 "outside", is up, line protocol is up
  Hardware is i82574L rev00, BW 1000 Mbps, DLY 10 usec
 Auto-Duplex(Full-duplex), Auto-Speed(1000 Mbps)
 Input flow control is unsupported, output flow control is off
 217157733 packets input, 240147730413 bytes, 0 no buffer
 Received 8911154 broadcasts, 0 runts, 0 giants
 0 L2 decode drops
 131655776 packets output, 37314293663 bytes, 0 underruns
 0 output errors, 0 collisions, 1 interface resets
 input queue (blocks free curr/low): hardware (500/386)
 output queue (blocks free curr/low): hardware (492/87)
  Traffic Statistics for "outside":
 217104860 packets input, 236061974415 bytes
 131655776 packets output, 34621364349 bytes
 7521214 packets dropped
      1 minute input rate 1307 pkts/sec,  1214642 bytes/sec
      1 minute output rate 1133 pkts/sec,  536756 bytes/sec
      1 minute drop rate, 55 pkts/sec
      5 minute input rate 1687 pkts/sec,  1770072 bytes/sec
      5 minute output rate 1347 pkts/sec,  533271 bytes/sec
      5 minute drop rate, 54 pkts/sec
Result of the command: "sho int g0/7"
Interface GigabitEthernet0/7 "inside", is up, line protocol is up
 141808177 packets input, 38923035653 bytes, 0 no buffer
 Received 8903388 broadcasts, 0 runts, 0 giants
 0 L2 decode drops
 209879573 packets output, 238755899157 bytes, 0 underruns
 input queue (blocks free curr/low): hardware (474/365)
 output queue (blocks free curr/low): hardware (474/400)
 141755240 packets input, 35998896329 bytes
 209879573 packets output, 234836832275 bytes
 7831077 packets dropped
      1 minute input rate 1437 pkts/sec,  524077 bytes/sec
      1 minute output rate 1744 pkts/sec,  1525040 bytes/sec
      1 minute drop rate, 57 pkts/sec
      5 minute input rate 1484 pkts/sec,  548278 bytes/sec
      5 minute output rate 1800 pkts/sec,  1795304 bytes/sec
      5 minute drop rate, 55 pkts/sec
Have you gone into ASDM and
Have you gone into ASDM and turned on the debug logging and had a look to see if you see a ton of red entries getting denies?  Also, depending on how your rules are ordered if your top talker rules are at the bottom of the stack that could slow stuff down.
That being said I agree it's probably hardware unless you've got some sort of weird QOS rate limiting going into the ASA or some shaping / policing device inline.
Based on the debug log it
I will look at dub log file during a an upload and copy here
Below is the debug log from
Below is the debug log from the ASA. At 10:41:20am I logged into a test site on sharepoint from my PC, WS010, at approximately 10:41:37am the upload was started - it was a 17MB folder, the upload speed was 200KB/sec, after the upload completed I logged off at about 10:43am. There were no Deny messages. I hope this is helpful. Thanks.
6|Nov 17 2014|10:43:51|305012|PC010 (My PC) (My PC)|49660|ASA Outside|49660|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49660 to ASA_outside:ASA Outside/49660 duration 0:00:04
6|Nov 17 2014|10:43:51|305012|PC010 (My PC) (My PC)|49661|ASA Outside|49661|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49661 to ASA_outside:ASA Outside/49661 duration 0:00:04
6|Nov 17 2014|10:43:51|305012|PC010 (My PC) (My PC)|49650|ASA Outside|49650|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49650 to ASA_outside:ASA Outside/49650 duration 0:00:12
6|Nov 17 2014|10:43:51|305012|PC010 (My PC) (My PC)|49653|ASA Outside|49653|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49653 to ASA_outside:ASA Outside/49653 duration 0:00:11
6|Nov 17 2014|10:43:51|305012|PC010 (My PC) (My PC)|49652|ASA Outside|49652|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49652 to ASA_outside:ASA Outside/49652 duration 0:00:11
6|Nov 17 2014|10:43:51|305012|PC010 (My PC) (My PC)|49651|ASA Outside|49651|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49651 to ASA_outside:ASA Outside/49651 duration 0:00:12
6|Nov 17 2014|10:43:51|305012|PC010 (My PC) (My PC)|49649|ASA Outside|49649|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49649 to ASA_outside:ASA Outside/49649 duration 0:00:12
6|Nov 17 2014|10:43:51|305012|PC010 (My PC) (My PC)|49665|ASA Outside|31296|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49665 to ASA_outside:ASA Outside/31296 duration 0:00:03
6|Nov 17 2014|10:43:51|305012|PC010 (My PC) (My PC)|49664|ASA Outside|49664|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49664 to ASA_outside:ASA Outside/49664 duration 0:00:03
6|Nov 17 2014|10:43:51|305012|PC010 (My PC) (My PC)|49663|ASA Outside|53449|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49663 to ASA_outside:ASA Outside/53449 duration 0:00:04
6|Nov 17 2014|10:43:51|305012|PC010 (My PC) (My PC)|49662|ASA Outside|49662|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49662 to ASA_outside:ASA Outside/49662 duration 0:00:04
6|Nov 17 2014|10:43:51|305012|PC010 (My PC) (My PC)|49659|ASA Outside|49659|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49659 to ASA_outside:ASA Outside/49659 duration 0:00:04
6|Nov 17 2014|10:43:51|305012|PC010 (My PC) (My PC)|49658|ASA Outside|33880|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49658 to ASA_outside:ASA Outside/33880 duration 0:00:04
6|Nov 17 2014|10:43:51|305012|PC010 (My PC) (My PC)|49657|ASA Outside|47883|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49657 to ASA_outside:ASA Outside/47883 duration 0:00:04
6|Nov 17 2014|10:43:51|305012|PC010 (My PC) (My PC)|49656|ASA Outside|45152|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49656 to ASA_outside:ASA Outside/45152 duration 0:00:04
6|Nov 17 2014|10:43:51|305012|PC010 (My PC) (My PC)|49655|ASA Outside|49655|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49655 to ASA_outside:ASA Outside/49655 duration 0:00:04
6|Nov 17 2014|10:43:51|305012|PC010 (My PC) (My PC)|49654|ASA Outside|49654|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49654 to ASA_outside:ASA Outside/49654 duration 0:00:04
6|Nov 17 2014|10:43:47|302013|PC010 (My PC) (My PC)|49665|155.154.153.15|443|Built outbound TCP connection 7877277 for ASA_outside:155.154.153.15/443 (155.154.153.15/443) to ASA Inside:PC010 (My PC) (My PC)/49665 (ASA Outside/31296)
6|Nov 17 2014|10:43:47|305011|PC010 (My PC) (My PC)|49665|ASA Outside|31296|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49665 to ASA_outside:ASA Outside/31296
6|Nov 17 2014|10:43:47|302013|PC010 (My PC) (My PC)|49664|155.154.153.15|443|Built outbound TCP connection 7877276 for ASA_outside:155.154.153.15/443 (155.154.153.15/443) to ASA Inside:PC010 (My PC) (My PC)/49664 (ASA Outside/49664)
6|Nov 17 2014|10:43:47|305011|PC010 (My PC) (My PC)|49664|ASA Outside|49664|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49664 to ASA_outside:ASA Outside/49664
6|Nov 17 2014|10:43:47|302013|PC010 (My PC) (My PC)|49663|145.144.143.14|443|Built outbound TCP connection 7877272 for ASA_outside:145.144.143.14/443 (145.144.143.14/443) to ASA Inside:PC010 (My PC) (My PC)/49663 (ASA Outside/53449)
6|Nov 17 2014|10:43:47|305011|PC010 (My PC) (My PC)|49663|ASA Outside|53449|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49663 to ASA_outside:ASA Outside/53449
6|Nov 17 2014|10:43:47|302013|PC010 (My PC) (My PC)|49662|145.144.143.14|443|Built outbound TCP connection 7877271 for ASA_outside:145.144.143.14/443 (145.144.143.14/443) to ASA Inside:PC010 (My PC) (My PC)/49662 (ASA Outside/49662)
6|Nov 17 2014|10:43:47|305011|PC010 (My PC) (My PC)|49662|ASA Outside|49662|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49662 to ASA_outside:ASA Outside/49662
6|Nov 17 2014|10:43:47|302013|PC010 (My PC) (My PC)|49661|125.124.123.12|80|Built outbound TCP connection 7877269 for ASA_outside:125.124.123.12/80 (125.124.123.12/80) to ASA Inside:PC010 (My PC) (My PC)/49661 (ASA Outside/49661)
6|Nov 17 2014|10:43:47|305011|PC010 (My PC) (My PC)|49661|ASA Outside|49661|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49661 to ASA_outside:ASA Outside/49661
6|Nov 17 2014|10:43:47|302013|PC010 (My PC) (My PC)|49660|125.124.123.12|80|Built outbound TCP connection 7877268 for ASA_outside:125.124.123.12/80 (125.124.123.12/80) to ASA Inside:PC010 (My PC) (My PC)/49660 (ASA Outside/49660)
6|Nov 17 2014|10:43:47|305011|PC010 (My PC) (My PC)|49660|ASA Outside|49660|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49660 to ASA_outside:ASA Outside/49660
6|Nov 17 2014|10:43:47|302013|PC010 (My PC) (My PC)|49659|178.177.176.17|80|Built outbound TCP connection 7877267 for ASA_outside:178.177.176.17/80 (178.177.176.17/80) to ASA Inside:PC010 (My PC) (My PC)/49659 (ASA Outside/49659)
6|Nov 17 2014|10:43:47|305011|PC010 (My PC) (My PC)|49659|ASA Outside|49659|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49659 to ASA_outside:ASA Outside/49659
6|Nov 17 2014|10:43:47|302013|PC010 (My PC) (My PC)|49658|178.177.176.17|80|Built outbound TCP connection 7877266 for ASA_outside:178.177.176.17/80 (178.177.176.17/80) to ASA Inside:PC010 (My PC) (My PC)/49658 (ASA Outside/33880)
6|Nov 17 2014|10:43:47|305011|PC010 (My PC) (My PC)|49658|ASA Outside|33880|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49658 to ASA_outside:ASA Outside/33880
6|Nov 17 2014|10:43:47|302013|PC010 (My PC) (My PC)|49657|157.56.248.54|443|Built outbound TCP connection 7877262 for ASA_outside:157.56.248.54/443 (157.56.248.54/443) to ASA Inside:PC010 (My PC) (My PC)/49657 (ASA Outside/47883)
6|Nov 17 2014|10:43:47|305011|PC010 (My PC) (My PC)|49657|ASA Outside|47883|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49657 to ASA_outside:ASA Outside/47883
6|Nov 17 2014|10:43:47|302013|PC010 (My PC) (My PC)|49656|157.56.248.54|443|Built outbound TCP connection 7877261 for ASA_outside:157.56.248.54/443 (157.56.248.54/443) to ASA Inside:PC010 (My PC) (My PC)/49656 (ASA Outside/45152)
6|Nov 17 2014|10:43:47|305011|PC010 (My PC) (My PC)|49656|ASA Outside|45152|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49656 to ASA_outside:ASA Outside/45152
6|Nov 17 2014|10:43:46|302013|PC010 (My PC) (My PC)|49655|125.124.123.12|80|Built outbound TCP connection 7877249 for ASA_outside:125.124.123.12/80 (125.124.123.12/80) to ASA Inside:PC010 (My PC) (My PC)/49655 (ASA Outside/49655)
6|Nov 17 2014|10:43:46|305011|PC010 (My PC) (My PC)|49655|ASA Outside|49655|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49655 to ASA_outside:ASA Outside/49655
6|Nov 17 2014|10:43:46|302013|PC010 (My PC) (My PC)|49654|125.124.123.12|80|Built outbound TCP connection 7877248 for ASA_outside:125.124.123.12/80 (125.124.123.12/80) to ASA Inside:PC010 (My PC) (My PC)/49654 (ASA Outside/49654)
6|Nov 17 2014|10:43:46|305011|PC010 (My PC) (My PC)|49654|ASA Outside|49654|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49654 to ASA_outside:ASA Outside/49654
6|Nov 17 2014|10:43:45|305012|PC010 (My PC) (My PC)|49636|ASA Outside|49636|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49636 to ASA_outside:ASA Outside/49636 duration 0:01:40
6|Nov 17 2014|10:43:45|305012|PC010 (My PC) (My PC)|49603|ASA Outside|49603|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49603 to ASA_outside:ASA Outside/49603 duration 0:01:53
6|Nov 17 2014|10:43:45|305012|PC010 (My PC) (My PC)|49602|ASA Outside|49602|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49602 to ASA_outside:ASA Outside/49602 duration 0:01:53
6|Nov 17 2014|10:43:45|305012|PC010 (My PC) (My PC)|49607|ASA Outside|18949|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49607 to ASA_outside:ASA Outside/18949 duration 0:01:52
6|Nov 17 2014|10:43:45|305012|PC010 (My PC) (My PC)|49606|ASA Outside|8626|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49606 to ASA_outside:ASA Outside/8626 duration 0:01:52
6|Nov 17 2014|10:43:45|305012|PC010 (My PC) (My PC)|49598|ASA Outside|49598|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49598 to ASA_outside:ASA Outside/49598 duration 0:01:53
6|Nov 17 2014|10:43:45|305012|PC010 (My PC) (My PC)|49599|ASA Outside|49599|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49599 to ASA_outside:ASA Outside/49599 duration 0:01:53
6|Nov 17 2014|10:43:45|106015|PC010 (My PC) (My PC)|49599|66.67.127.45|443|Deny TCP (no connection) from PC010 (My PC) (My PC)/49599 to 66.67.127.45/443 flags RST  on interface ASA Inside
6|Nov 17 2014|10:43:45|305012|PC010 (My PC) (My PC)|49601|ASA Outside|49601|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49601 to ASA_outside:ASA Outside/49601 duration 0:01:53
6|Nov 17 2014|10:43:45|305012|PC010 (My PC) (My PC)|49600|ASA Outside|49600|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49600 to ASA_outside:ASA Outside/49600 duration 0:01:53
6|Nov 17 2014|10:43:45|305012|PC010 (My PC) (My PC)|49635|ASA Outside|49635|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49635 to ASA_outside:ASA Outside/49635 duration 0:01:40
6|Nov 17 2014|10:43:45|305012|PC010 (My PC) (My PC)|49634|ASA Outside|49634|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49634 to ASA_outside:ASA Outside/49634 duration 0:01:40
6|Nov 17 2014|10:43:45|305012|PC010 (My PC) (My PC)|49632|ASA Outside|49632|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49632 to ASA_outside:ASA Outside/49632 duration 0:01:40
6|Nov 17 2014|10:43:45|305012|PC010 (My PC) (My PC)|49633|ASA Outside|49633|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49633 to ASA_outside:ASA Outside/49633 duration 0:01:40
6|Nov 17 2014|10:43:45|305012|PC010 (My PC) (My PC)|49638|ASA Outside|49638|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49638 to ASA_outside:ASA Outside/49638 duration 0:01:40
6|Nov 17 2014|10:43:45|305012|PC010 (My PC) (My PC)|49637|ASA Outside|49637|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49637 to ASA_outside:ASA Outside/49637 duration 0:01:40
6|Nov 17 2014|10:43:45|305012|PC010 (My PC) (My PC)|49645|ASA Outside|49645|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49645 to ASA_outside:ASA Outside/49645 duration 0:01:33
6|Nov 17 2014|10:43:45|305012|PC010 (My PC) (My PC)|49644|ASA Outside|49644|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49644 to ASA_outside:ASA Outside/49644 duration 0:01:34
6|Nov 17 2014|10:43:39|305012|PC010 (My PC) (My PC)|49604|ASA Outside|49604|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49604 to ASA_outside:ASA Outside/49604 duration 0:01:46
6|Nov 17 2014|10:43:39|305012|PC010 (My PC) (My PC)|49605|ASA Outside|35660|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49605 to ASA_outside:ASA Outside/35660 duration 0:01:46
6|Nov 17 2014|10:43:39|302013|PC010 (My PC) (My PC)|49653|178.177.176.17|80|Built outbound TCP connection 7876974 for ASA_outside:178.177.176.17/80 (178.177.176.17/80) to ASA Inside:PC010 (My PC) (My PC)/49653 (ASA Outside/49653)
6|Nov 17 2014|10:43:39|305011|PC010 (My PC) (My PC)|49653|ASA Outside|49653|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49653 to ASA_outside:ASA Outside/49653
6|Nov 17 2014|10:43:39|302013|PC010 (My PC) (My PC)|49652|178.177.176.17|80|Built outbound TCP connection 7876973 for ASA_outside:178.177.176.17/80 (178.177.176.17/80) to ASA Inside:PC010 (My PC) (My PC)/49652 (ASA Outside/49652)
6|Nov 17 2014|10:43:39|305011|PC010 (My PC) (My PC)|49652|ASA Outside|49652|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49652 to ASA_outside:ASA Outside/49652
6|Nov 17 2014|10:43:39|305012|PC010 (My PC) (My PC)|49595|ASA Outside|49595|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49595 to ASA_outside:ASA Outside/49595 duration 0:01:47
6|Nov 17 2014|10:43:39|305012|PC010 (My PC) (My PC)|49591|ASA Outside|12006|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49591 to ASA_outside:ASA Outside/12006 duration 0:01:48
6|Nov 17 2014|10:43:39|305012|PC010 (My PC) (My PC)|49592|ASA Outside|49592|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49592 to ASA_outside:ASA Outside/49592 duration 0:01:47
6|Nov 17 2014|10:43:39|305012|PC010 (My PC) (My PC)|49590|ASA Outside|49590|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49590 to ASA_outside:ASA Outside/49590 duration 0:01:48
6|Nov 17 2014|10:43:39|305012|PC010 (My PC) (My PC)|49597|ASA Outside|49597|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49597 to ASA_outside:ASA Outside/49597 duration 0:01:47
6|Nov 17 2014|10:43:39|305012|PC010 (My PC) (My PC)|49596|ASA Outside|49596|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49596 to ASA_outside:ASA Outside/49596 duration 0:01:47
6|Nov 17 2014|10:43:39|302013|PC010 (My PC) (My PC)|49651|152.198.197.19|443|Built outbound TCP connection 7876963 for ASA_outside:152.198.197.19/443 (152.198.197.19/443) to ASA Inside:PC010 (My PC) (My PC)/49651 (ASA Outside/49651)
6|Nov 17 2014|10:43:39|305011|PC010 (My PC) (My PC)|49651|ASA Outside|49651|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49651 to ASA_outside:ASA Outside/49651
6|Nov 17 2014|10:43:39|302013|PC010 (My PC) (My PC)|49650|152.198.197.19|443|Built outbound TCP connection 7876962 for ASA_outside:152.198.197.19/443 (152.198.197.19/443) to ASA Inside:PC010 (My PC) (My PC)/49650 (ASA Outside/49650)
6|Nov 17 2014|10:43:39|305011|PC010 (My PC) (My PC)|49650|ASA Outside|49650|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49650 to ASA_outside:ASA Outside/49650
6|Nov 17 2014|10:43:39|302013|PC010 (My PC) (My PC)|49649|152.198.197.19|443|Built outbound TCP connection 7876961 for ASA_outside:152.198.197.19/443 (152.198.197.19/443) to ASA Inside:PC010 (My PC) (My PC)/49649 (ASA Outside/49649)
6|Nov 17 2014|10:43:39|305011|PC010 (My PC) (My PC)|49649|ASA Outside|49649|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49649 to ASA_outside:ASA Outside/49649
6|Nov 17 2014|10:43:31|305012|PC010 (My PC) (My PC)|49586|ASA Outside|49586|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49586 to ASA_outside:ASA Outside/49586 duration 0:01:50
6|Nov 17 2014|10:43:31|305012|PC010 (My PC) (My PC)|49587|ASA Outside|49587|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49587 to ASA_outside:ASA Outside/49587 duration 0:01:50
6|Nov 17 2014|10:43:31|305012|PC010 (My PC) (My PC)|49641|ASA Outside|5850|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49641 to ASA_outside:ASA Outside/5850 duration 0:01:24
6|Nov 17 2014|10:43:31|305012|PC010 (My PC) (My PC)|49640|ASA Outside|49640|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49640 to ASA_outside:ASA Outside/49640 duration 0:01:24
6|Nov 17 2014|10:43:12|305012|PC010 (My PC) (My PC)|49648|ASA Outside|49648|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49648 to ASA_outside:ASA Outside/49648 duration 0:00:30
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49571|ASA Outside|61353|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49571 to ASA_outside:ASA Outside/61353 duration 0:01:32
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49560|ASA Outside|49560|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49560 to ASA_outside:ASA Outside/49560 duration 0:01:34
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49559|ASA Outside|49559|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49559 to ASA_outside:ASA Outside/49559 duration 0:01:34
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49589|ASA Outside|49589|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49589 to ASA_outside:ASA Outside/49589 duration 0:01:21
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49618|ASA Outside|49618|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49618 to ASA_outside:ASA Outside/49618 duration 0:01:11
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49620|ASA Outside|26887|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49620 to ASA_outside:ASA Outside/26887 duration 0:01:11
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49619|ASA Outside|49619|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49619 to ASA_outside:ASA Outside/49619 duration 0:01:11
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49593|ASA Outside|49593|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49593 to ASA_outside:ASA Outside/49593 duration 0:01:19
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49622|ASA Outside|49622|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49622 to ASA_outside:ASA Outside/49622 duration 0:01:11
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49585|ASA Outside|49585|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49585 to ASA_outside:ASA Outside/49585 duration 0:01:29
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49583|ASA Outside|49583|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49583 to ASA_outside:ASA Outside/49583 duration 0:01:29
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49580|ASA Outside|49580|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49580 to ASA_outside:ASA Outside/49580 duration 0:01:30
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49579|ASA Outside|49579|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49579 to ASA_outside:ASA Outside/49579 duration 0:01:30
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49577|ASA Outside|49577|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49577 to ASA_outside:ASA Outside/49577 duration 0:01:31
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49612|ASA Outside|18940|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49612 to ASA_outside:ASA Outside/18940 duration 0:01:11
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49581|ASA Outside|49581|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49581 to ASA_outside:ASA Outside/49581 duration 0:01:29
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49574|ASA Outside|49574|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49574 to ASA_outside:ASA Outside/49574 duration 0:01:31
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49578|ASA Outside|60687|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49578 to ASA_outside:ASA Outside/60687 duration 0:01:31
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49572|ASA Outside|11594|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49572 to ASA_outside:ASA Outside/11594 duration 0:01:31
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49624|ASA Outside|49624|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49624 to ASA_outside:ASA Outside/49624 duration 0:01:11
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49570|ASA Outside|40276|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49570 to ASA_outside:ASA Outside/40276 duration 0:01:32
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49625|ASA Outside|49625|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49625 to ASA_outside:ASA Outside/49625 duration 0:01:11
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49564|ASA Outside|65490|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49564 to ASA_outside:ASA Outside/65490 duration 0:01:33
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49562|ASA Outside|49562|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49562 to ASA_outside:ASA Outside/49562 duration 0:01:33
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49561|ASA Outside|49561|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49561 to ASA_outside:ASA Outside/49561 duration 0:01:33
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49558|ASA Outside|49558|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49558 to ASA_outside:ASA Outside/49558 duration 0:01:33
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49557|ASA Outside|52103|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49557 to ASA_outside:ASA Outside/52103 duration 0:01:33
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49553|ASA Outside|49553|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49553 to ASA_outside:ASA Outside/49553 duration 0:01:34
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49552|ASA Outside|4677|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49552 to ASA_outside:ASA Outside/4677 duration 0:01:34
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49550|ASA Outside|33291|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49550 to ASA_outside:ASA Outside/33291 duration 0:01:34
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49548|ASA Outside|49548|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49548 to ASA_outside:ASA Outside/49548 duration 0:01:34
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49626|ASA Outside|49626|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49626 to ASA_outside:ASA Outside/49626 duration 0:01:11
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49623|ASA Outside|49623|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49623 to ASA_outside:ASA Outside/49623 duration 0:01:11
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49615|ASA Outside|49615|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49615 to ASA_outside:ASA Outside/49615 duration 0:01:11
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49582|ASA Outside|53784|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49582 to ASA_outside:ASA Outside/53784 duration 0:01:29
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49556|ASA Outside|40678|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49556 to ASA_outside:ASA Outside/40678 duration 0:01:33
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49555|ASA Outside|49555|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49555 to ASA_outside:ASA Outside/49555 duration 0:01:33
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49551|ASA Outside|54514|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49551 to ASA_outside:ASA Outside/54514 duration 0:01:33
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49554|ASA Outside|49554|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49554 to ASA_outside:ASA Outside/49554 duration 0:01:33
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49563|ASA Outside|49563|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49563 to ASA_outside:ASA Outside/49563 duration 0:01:33
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49584|ASA Outside|43421|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49584 to ASA_outside:ASA Outside/43421 duration 0:01:29
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49588|ASA Outside|49588|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49588 to ASA_outside:ASA Outside/49588 duration 0:01:21
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49613|ASA Outside|15959|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49613 to ASA_outside:ASA Outside/15959 duration 0:01:11
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49614|ASA Outside|49614|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49614 to ASA_outside:ASA Outside/49614 duration 0:01:11
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49617|ASA Outside|49617|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49617 to ASA_outside:ASA Outside/49617 duration 0:01:11
6|Nov 17 2014|10:43:10|305012|PC010 (My PC) (My PC)|49616|ASA Outside|46250|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49616 to ASA_outside:ASA Outside/46250 duration 0:01:11
6|Nov 17 2014|10:42:42|302013|PC010 (My PC) (My PC)|49648|65.55.252.70|443|Built outbound TCP connection 7874531 for ASA_outside:65.55.252.70/443 (65.55.252.70/443) to ASA Inside:PC010 (My PC) (My PC)/49648 (ASA Outside/49648)
6|Nov 17 2014|10:42:42|305011|PC010 (My PC) (My PC)|49648|ASA Outside|49648|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49648 to ASA_outside:ASA Outside/49648
6|Nov 17 2014|10:42:41|305012|PC010 (My PC) (My PC)|49576|ASA Outside|49576|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49576 to ASA_outside:ASA Outside/49576 duration 0:01:02
6|Nov 17 2014|10:42:40|305012|PC010 (My PC) (My PC)|49575|ASA Outside|49575|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49575 to ASA_outside:ASA Outside/49575 duration 0:01:00
6|Nov 17 2014|10:42:39|305012|PC010 (My PC) (My PC)|49643|ASA Outside|49643|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49643 to ASA_outside:ASA Outside/49643 duration 0:00:30
6|Nov 17 2014|10:42:39|305012|PC010 (My PC) (My PC)|49568|ASA Outside|29271|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49568 to ASA_outside:ASA Outside/29271 duration 0:01:01
6|Nov 17 2014|10:42:38|305012|PC010 (My PC) (My PC)|49549|ASA Outside|49549|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49549 to ASA_outside:ASA Outside/49549 duration 0:01:02
6|Nov 17 2014|10:42:37|305012|PC010 (My PC) (My PC)|49566|ASA Outside|49566|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49566 to ASA_outside:ASA Outside/49566 duration 0:01:01
6|Nov 17 2014|10:42:36|305012|PC010 (My PC) (My PC)|49567|ASA Outside|49567|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49567 to ASA_outside:ASA Outside/49567 duration 0:01:00
6|Nov 17 2014|10:42:35|305012|PC010 (My PC) (My PC)|49565|ASA Outside|49565|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49565 to ASA_outside:ASA Outside/49565 duration 0:00:58
6|Nov 17 2014|10:42:23|302013|PC010 (My PC) (My PC)|49647|63.236.252.169|80|Built outbound TCP connection 7873714 for ASA_outside:63.236.252.169/80 (63.236.252.169/80) to ASA Inside:PC010 (My PC) (My PC)/49647 (ASA Outside/49647)
6|Nov 17 2014|10:42:23|305011|PC010 (My PC) (My PC)|49647|ASA Outside|49647|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49647 to ASA_outside:ASA Outside/49647
6|Nov 17 2014|10:42:16|302013|PC010 (My PC) (My PC)|49646|152.198.197.19|443|Built outbound TCP connection 7873417 for ASA_outside:152.198.197.19/443 (152.198.197.19/443) to ASA Inside:PC010 (My PC) (My PC)/49646 (ASA Outside/49646)
6|Nov 17 2014|10:42:16|305011|PC010 (My PC) (My PC)|49646|ASA Outside|49646|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49646 to ASA_outside:ASA Outside/49646
6|Nov 17 2014|10:42:16|305012|PC010 (My PC) (My PC)|49545|ASA Outside|59165|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49545 to ASA_outside:ASA Outside/59165 duration 0:02:57
6|Nov 17 2014|10:42:16|305012|PC010 (My PC) (My PC)|49544|ASA Outside|50579|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49544 to ASA_outside:ASA Outside/50579 duration 0:02:57
6|Nov 17 2014|10:42:16|305012|PC010 (My PC) (My PC)|49546|ASA Outside|49546|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49546 to ASA_outside:ASA Outside/49546 duration 0:02:57
6|Nov 17 2014|10:42:11|302013|PC010 (My PC) (My PC)|49645|185.189.187.12|443|Built outbound TCP connection 7873146 for ASA_outside:185.189.187.12/443 (185.189.187.12/443) to ASA Inside:PC010 (My PC) (My PC)/49645 (ASA Outside/49645)
6|Nov 17 2014|10:42:11|305011|PC010 (My PC) (My PC)|49645|ASA Outside|49645|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49645 to ASA_outside:ASA Outside/49645
6|Nov 17 2014|10:42:11|305012|PC010 (My PC) (My PC)|49642|ASA Outside|49642|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49642 to ASA_outside:ASA Outside/49642 duration 0:00:04
6|Nov 17 2014|10:42:10|302013|PC010 (My PC) (My PC)|49644|96.6.113.19|80|Built outbound TCP connection 7873077 for ASA_outside:96.6.113.19/80 (96.6.113.19/80) to ASA Inside:PC010 (My PC) (My PC)/49644 (ASA Outside/49644)
6|Nov 17 2014|10:42:10|305011|PC010 (My PC) (My PC)|49644|ASA Outside|49644|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49644 to ASA_outside:ASA Outside/49644
6|Nov 17 2014|10:42:09|302013|PC010 (My PC) (My PC)|49643|65.55.252.70|443|Built outbound TCP connection 7872963 for ASA_outside:65.55.252.70/443 (65.55.252.70/443) to ASA Inside:PC010 (My PC) (My PC)/49643 (ASA Outside/49643)
6|Nov 17 2014|10:42:09|305011|PC010 (My PC) (My PC)|49643|ASA Outside|49643|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49643 to ASA_outside:ASA Outside/49643
6|Nov 17 2014|10:42:07|305012|PC010 (My PC) (My PC)|49611|ASA Outside|5150|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49611 to ASA_outside:ASA Outside/5150 duration 0:00:13
6|Nov 17 2014|10:42:07|305012|PC010 (My PC) (My PC)|49610|ASA Outside|55303|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49610 to ASA_outside:ASA Outside/55303 duration 0:00:13
6|Nov 17 2014|10:42:07|305012|PC010 (My PC) (My PC)|49609|ASA Outside|49609|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49609 to ASA_outside:ASA Outside/49609 duration 0:00:13
6|Nov 17 2014|10:42:07|305012|PC010 (My PC) (My PC)|49608|ASA Outside|1382|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49608 to ASA_outside:ASA Outside/1382 duration 0:00:13
6|Nov 17 2014|10:42:07|302013|PC010 (My PC) (My PC)|49642|185.189.187.12|443|Built outbound TCP connection 7872878 for ASA_outside:185.189.187.12/443 (185.189.187.12/443) to ASA Inside:PC010 (My PC) (My PC)/49642 (ASA Outside/49642)
6|Nov 17 2014|10:42:07|305011|PC010 (My PC) (My PC)|49642|ASA Outside|49642|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49642 to ASA_outside:ASA Outside/49642
6|Nov 17 2014|10:42:06|302013|PC010 (My PC) (My PC)|49641|93.184.215.200|443|Built outbound TCP connection 7872876 for ASA_outside:93.184.215.200/443 (93.184.215.200/443) to ASA Inside:PC010 (My PC) (My PC)/49641 (ASA Outside/5850)
6|Nov 17 2014|10:42:06|305011|PC010 (My PC) (My PC)|49641|ASA Outside|5850|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49641 to ASA_outside:ASA Outside/5850
6|Nov 17 2014|10:42:06|302013|PC010 (My PC) (My PC)|49640|93.184.215.200|443|Built outbound TCP connection 7872875 for ASA_outside:93.184.215.200/443 (93.184.215.200/443) to ASA Inside:PC010 (My PC) (My PC)/49640 (ASA Outside/49640)
6|Nov 17 2014|10:42:06|305011|PC010 (My PC) (My PC)|49640|ASA Outside|49640|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49640 to ASA_outside:ASA Outside/49640
6|Nov 17 2014|10:42:06|305012|PC010 (My PC) (My PC)|49639|ASA Outside|49639|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49639 to ASA_outside:ASA Outside/49639 duration 0:00:00
6|Nov 17 2014|10:42:06|302013|PC010 (My PC) (My PC)|49639|93.184.215.200|443|Built outbound TCP connection 7872870 for ASA_outside:93.184.215.200/443 (93.184.215.200/443) to ASA Inside:PC010 (My PC) (My PC)/49639 (ASA Outside/49639)
6|Nov 17 2014|10:42:06|305011|PC010 (My PC) (My PC)|49639|ASA Outside|49639|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49639 to ASA_outside:ASA Outside/49639
6|Nov 17 2014|10:42:05|302013|PC010 (My PC) (My PC)|49638|66.67.8.9|443|Built outbound TCP connection 7872814 for ASA_outside:66.67.8.9/443 (66.67.8.9/443) to ASA Inside:PC010 (My PC) (My PC)/49638 (ASA Outside/49638)
6|Nov 17 2014|10:42:05|305011|PC010 (My PC) (My PC)|49638|ASA Outside|49638|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49638 to ASA_outside:ASA Outside/49638
6|Nov 17 2014|10:42:05|302013|PC010 (My PC) (My PC)|49637|66.67.8.9|443|Built outbound TCP connection 7872813 for ASA_outside:66.67.8.9/443 (66.67.8.9/443) to ASA Inside:PC010 (My PC) (My PC)/49637 (ASA Outside/49637)
6|Nov 17 2014|10:42:05|305011|PC010 (My PC) (My PC)|49637|ASA Outside|49637|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49637 to ASA_outside:ASA Outside/49637
6|Nov 17 2014|10:42:05|302013|PC010 (My PC) (My PC)|49636|111.155.12.137|80|Built outbound TCP connection 7872811 for ASA_outside:111.155.12.137/80 (111.155.12.137/80) to ASA Inside:PC010 (My PC) (My PC)/49636 (ASA Outside/49636)
6|Nov 17 2014|10:42:05|305011|PC010 (My PC) (My PC)|49636|ASA Outside|49636|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49636 to ASA_outside:ASA Outside/49636
6|Nov 17 2014|10:42:05|302013|PC010 (My PC) (My PC)|49635|66.67.127.45|443|Built outbound TCP connection 7872810 for ASA_outside:66.67.127.45/443 (66.67.127.45/443) to ASA Inside:PC010 (My PC) (My PC)/49635 (ASA Outside/49635)
6|Nov 17 2014|10:42:05|305011|PC010 (My PC) (My PC)|49635|ASA Outside|49635|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49635 to ASA_outside:ASA Outside/49635
6|Nov 17 2014|10:42:05|302013|PC010 (My PC) (My PC)|49634|66.67.127.45|443|Built outbound TCP connection 7872809 for ASA_outside:66.67.127.45/443 (66.67.127.45/443) to ASA Inside:PC010 (My PC) (My PC)/49634 (ASA Outside/49634)
6|Nov 17 2014|10:42:05|305011|PC010 (My PC) (My PC)|49634|ASA Outside|49634|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49634 to ASA_outside:ASA Outside/49634
6|Nov 17 2014|10:42:05|302013|PC010 (My PC) (My PC)|49633|66.67.127.45|443|Built outbound TCP connection 7872808 for ASA_outside:66.67.127.45/443 (66.67.127.45/443) to ASA Inside:PC010 (My PC) (My PC)/49633 (ASA Outside/49633)
6|Nov 17 2014|10:42:05|305011|PC010 (My PC) (My PC)|49633|ASA Outside|49633|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49633 to ASA_outside:ASA Outside/49633
6|Nov 17 2014|10:42:05|302013|PC010 (My PC) (My PC)|49632|66.67.127.45|443|Built outbound TCP connection 7872807 for ASA_outside:66.67.127.45/443 (66.67.127.45/443) to ASA Inside:PC010 (My PC) (My PC)/49632 (ASA Outside/49632)
6|Nov 17 2014|10:42:05|305011|PC010 (My PC) (My PC)|49632|ASA Outside|49632|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49632 to ASA_outside:ASA Outside/49632
6|Nov 17 2014|10:42:04|305012|PC010 (My PC) (My PC)|49631|ASA Outside|49631|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49631 to ASA_outside:ASA Outside/49631 duration 0:00:00
6|Nov 17 2014|10:42:04|305012|PC010 (My PC) (My PC)|49627|ASA Outside|49627|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49627 to ASA_outside:ASA Outside/49627 duration 0:00:00
6|Nov 17 2014|10:42:04|305012|PC010 (My PC) (My PC)|49628|ASA Outside|49628|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49628 to ASA_outside:ASA Outside/49628 duration 0:00:00
6|Nov 17 2014|10:42:04|305012|PC010 (My PC) (My PC)|49629|ASA Outside|49629|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49629 to ASA_outside:ASA Outside/49629 duration 0:00:00
6|Nov 17 2014|10:42:04|305012|PC010 (My PC) (My PC)|49630|ASA Outside|10992|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49630 to ASA_outside:ASA Outside/10992 duration 0:00:00
6|Nov 17 2014|10:42:04|305012|PC010 (My PC) (My PC)|49621|ASA Outside|49621|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49621 to ASA_outside:ASA Outside/49621 duration 0:00:04
6|Nov 17 2014|10:42:04|302013|PC010 (My PC) (My PC)|49631|160.166.22.242|443|Built outbound TCP connection 7872785 for ASA_outside:160.166.22.242/443 (160.166.22.242/443) to ASA Inside:PC010 (My PC) (My PC)/49631 (ASA Outside/49631)
6|Nov 17 2014|10:42:04|305011|PC010 (My PC) (My PC)|49631|ASA Outside|49631|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49631 to ASA_outside:ASA Outside/49631
6|Nov 17 2014|10:42:04|302013|PC010 (My PC) (My PC)|49630|160.166.22.242|443|Built outbound TCP connection 7872784 for ASA_outside:160.166.22.242/443 (160.166.22.242/443) to ASA Inside:PC010 (My PC) (My PC)/49630 (ASA Outside/10992)
6|Nov 17 2014|10:42:04|305011|PC010 (My PC) (My PC)|49630|ASA Outside|10992|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49630 to ASA_outside:ASA Outside/10992
6|Nov 17 2014|10:42:04|302013|PC010 (My PC) (My PC)|49629|160.166.22.242|443|Built outbound TCP connection 7872783 for ASA_outside:160.166.22.242/443 (160.166.22.242/443) to ASA Inside:PC010 (My PC) (My PC)/49629 (ASA Outside/49629)
6|Nov 17 2014|10:42:04|305011|PC010 (My PC) (My PC)|49629|ASA Outside|49629|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49629 to ASA_outside:ASA Outside/49629
6|Nov 17 2014|10:42:04|302013|PC010 (My PC) (My PC)|49628|160.166.22.242|443|Built outbound TCP connection 7872782 for ASA_outside:160.166.22.242/443 (160.166.22.242/443) to ASA Inside:PC010 (My PC) (My PC)/49628 (ASA Outside/49628)
6|Nov 17 2014|10:42:04|305011|PC010 (My PC) (My PC)|49628|ASA Outside|49628|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49628 to ASA_outside:ASA Outside/49628
6|Nov 17 2014|10:42:04|302013|PC010 (My PC) (My PC)|49627|160.166.22.242|443|Built outbound TCP connection 7872781 for ASA_outside:160.166.22.242/443 (160.166.22.242/443) to ASA Inside:PC010 (My PC) (My PC)/49627 (ASA Outside/49627)
6|Nov 17 2014|10:42:04|305011|PC010 (My PC) (My PC)|49627|ASA Outside|49627|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49627 to ASA_outside:ASA Outside/49627
6|Nov 17 2014|10:41:59|302013|PC010 (My PC) (My PC)|49626|160.166.25.120|443|Built outbound TCP connection 7872620 for ASA_outside:160.166.25.120/443 (160.166.25.120/443) to ASA Inside:PC010 (My PC) (My PC)/49626 (ASA Outside/49626)
6|Nov 17 2014|10:41:59|305011|PC010 (My PC) (My PC)|49626|ASA Outside|49626|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49626 to ASA_outside:ASA Outside/49626
6|Nov 17 2014|10:41:59|302013|PC010 (My PC) (My PC)|49625|152.198.197.19|443|Built outbound TCP connection 7872617 for ASA_outside:152.198.197.19/443 (152.198.197.19/443) to ASA Inside:PC010 (My PC) (My PC)/49625 (ASA Outside/49625)
6|Nov 17 2014|10:41:59|305011|PC010 (My PC) (My PC)|49625|ASA Outside|49625|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49625 to ASA_outside:ASA Outside/49625
6|Nov 17 2014|10:41:59|302013|PC010 (My PC) (My PC)|49624|152.198.197.19|443|Built outbound TCP connection 7872615 for ASA_outside:152.198.197.19/443 (152.198.197.19/443) to ASA Inside:PC010 (My PC) (My PC)/49624 (ASA Outside/49624)
6|Nov 17 2014|10:41:59|305011|PC010 (My PC) (My PC)|49624|ASA Outside|49624|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49624 to ASA_outside:ASA Outside/49624
6|Nov 17 2014|10:41:59|302013|PC010 (My PC) (My PC)|49623|152.198.197.19|443|Built outbound TCP connection 7872614 for ASA_outside:152.198.197.19/443 (152.198.197.19/443) to ASA Inside:PC010 (My PC) (My PC)/49623 (ASA Outside/49623)
6|Nov 17 2014|10:41:59|305011|PC010 (My PC) (My PC)|49623|ASA Outside|49623|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49623 to ASA_outside:ASA Outside/49623
6|Nov 17 2014|10:41:59|302013|PC010 (My PC) (My PC)|49622|152.198.197.19|443|Built outbound TCP connection 7872613 for ASA_outside:152.198.197.19/443 (152.198.197.19/443) to ASA Inside:PC010 (My PC) (My PC)/49622 (ASA Outside/49622)
6|Nov 17 2014|10:41:59|305011|PC010 (My PC) (My PC)|49622|ASA Outside|49622|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49622 to ASA_outside:ASA Outside/49622
6|Nov 17 2014|10:41:59|302013|PC010 (My PC) (My PC)|49621|160.166.22.242|443|Built outbound TCP connection 7872612 for ASA_outside:160.166.22.242/443 (160.166.22.242/443) to ASA Inside:PC010 (My PC) (My PC)/49621 (ASA Outside/49621)
6|Nov 17 2014|10:41:59|305011|PC010 (My PC) (My PC)|49621|ASA Outside|49621|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49621 to ASA_outside:ASA Outside/49621
6|Nov 17 2014|10:41:59|302013|PC010 (My PC) (My PC)|49620|152.198.197.19|443|Built outbound TCP connection 7872611 for ASA_outside:152.198.197.19/443 (152.198.197.19/443) to ASA Inside:PC010 (My PC) (My PC)/49620 (ASA Outside/26887)
6|Nov 17 2014|10:41:59|305011|PC010 (My PC) (My PC)|49620|ASA Outside|26887|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49620 to ASA_outside:ASA Outside/26887
6|Nov 17 2014|10:41:59|302013|PC010 (My PC) (My PC)|49619|152.198.197.19|443|Built outbound TCP connection 7872610 for ASA_outside:152.198.197.19/443 (152.198.197.19/443) to ASA Inside:PC010 (My PC) (My PC)/49619 (ASA Outside/49619)
6|Nov 17 2014|10:41:59|305011|PC010 (My PC) (My PC)|49619|ASA Outside|49619|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49619 to ASA_outside:ASA Outside/49619
6|Nov 17 2014|10:41:59|302013|PC010 (My PC) (My PC)|49618|152.198.197.19|443|Built outbound TCP connection 7872609 for ASA_outside:152.198.197.19/443 (152.198.197.19/443) to ASA Inside:PC010 (My PC) (My PC)/49618 (ASA Outside/49618)
6|Nov 17 2014|10:41:59|305011|PC010 (My PC) (My PC)|49618|ASA Outside|49618|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49618 to ASA_outside:ASA Outside/49618
6|Nov 17 2014|10:41:59|302013|PC010 (My PC) (My PC)|49617|66.67.127.45|443|Built outbound TCP connection 7872608 for ASA_outside:66.67.127.45/443 (66.67.127.45/443) to ASA Inside:PC010 (My PC) (My PC)/49617 (ASA Outside/49617)
6|Nov 17 2014|10:41:59|305011|PC010 (My PC) (My PC)|49617|ASA Outside|49617|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49617 to ASA_outside:ASA Outside/49617
6|Nov 17 2014|10:41:59|302013|PC010 (My PC) (My PC)|49616|66.67.127.45|443|Built outbound TCP connection 7872607 for ASA_outside:66.67.127.45/443 (66.67.127.45/443) to ASA Inside:PC010 (My PC) (My PC)/49616 (ASA Outside/46250)
6|Nov 17 2014|10:41:59|305011|PC010 (My PC) (My PC)|49616|ASA Outside|46250|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49616 to ASA_outside:ASA Outside/46250
6|Nov 17 2014|10:41:59|302013|PC010 (My PC) (My PC)|49615|160.166.167.168|443|Built outbound TCP connection 7872606 for ASA_outside:160.166.167.168/443 (160.166.167.168/443) to ASA Inside:PC010 (My PC) (My PC)/49615 (ASA Outside/49615)
6|Nov 17 2014|10:41:59|305011|PC010 (My PC) (My PC)|49615|ASA Outside|49615|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49615 to ASA_outside:ASA Outside/49615
6|Nov 17 2014|10:41:59|302013|PC010 (My PC) (My PC)|49614|66.67.127.45|443|Built outbound TCP connection 7872605 for ASA_outside:66.67.127.45/443 (66.67.127.45/443) to ASA Inside:PC010 (My PC) (My PC)/49614 (ASA Outside/49614)
6|Nov 17 2014|10:41:59|305011|PC010 (My PC) (My PC)|49614|ASA Outside|49614|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49614 to ASA_outside:ASA Outside/49614
6|Nov 17 2014|10:41:59|302013|PC010 (My PC) (My PC)|49613|66.67.127.45|443|Built outbound TCP connection 7872603 for ASA_outside:66.67.127.45/443 (66.67.127.45/443) to ASA Inside:PC010 (My PC) (My PC)/49613 (ASA Outside/15959)
6|Nov 17 2014|10:41:59|305011|PC010 (My PC) (My PC)|49613|ASA Outside|15959|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49613 to ASA_outside:ASA Outside/15959
6|Nov 17 2014|10:41:59|302013|PC010 (My PC) (My PC)|49612|152.198.197.19|443|Built outbound TCP connection 7872602 for ASA_outside:152.198.197.19/443 (152.198.197.19/443) to ASA Inside:PC010 (My PC) (My PC)/49612 (ASA Outside/18940)
6|Nov 17 2014|10:41:59|305011|PC010 (My PC) (My PC)|49612|ASA Outside|18940|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49612 to ASA_outside:ASA Outside/18940
6|Nov 17 2014|10:41:53|302013|PC010 (My PC) (My PC)|49611|185.189.187.12|443|Built outbound TCP connection 7872110 for ASA_outside:185.189.187.12/443 (185.189.187.12/443) to ASA Inside:PC010 (My PC) (My PC)/49611 (ASA Outside/5150)
6|Nov 17 2014|10:41:53|305011|PC010 (My PC) (My PC)|49611|ASA Outside|5150|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49611 to ASA_outside:ASA Outside/5150
6|Nov 17 2014|10:41:53|302013|PC010 (My PC) (My PC)|49610|185.189.187.12|443|Built outbound TCP connection 7872109 for ASA_outside:185.189.187.12/443 (185.189.187.12/443) to ASA Inside:PC010 (My PC) (My PC)/49610 (ASA Outside/55303)
6|Nov 17 2014|10:41:53|305011|PC010 (My PC) (My PC)|49610|ASA Outside|55303|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49610 to ASA_outside:ASA Outside/55303
6|Nov 17 2014|10:41:53|302013|PC010 (My PC) (My PC)|49609|185.189.187.12|443|Built outbound TCP connection 7872108 for ASA_outside:185.189.187.12/443 (185.189.187.12/443) to ASA Inside:PC010 (My PC) (My PC)/49609 (ASA Outside/49609)
6|Nov 17 2014|10:41:53|305011|PC010 (My PC) (My PC)|49609|ASA Outside|49609|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49609 to ASA_outside:ASA Outside/49609
6|Nov 17 2014|10:41:53|302013|PC010 (My PC) (My PC)|49608|185.189.187.12|443|Built outbound TCP connection 7872107 for ASA_outside:185.189.187.12/443 (185.189.187.12/443) to ASA Inside:PC010 (My PC) (My PC)/49608 (ASA Outside/1382)
6|Nov 17 2014|10:41:53|305011|PC010 (My PC) (My PC)|49608|ASA Outside|1382|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49608 to ASA_outside:ASA Outside/1382
6|Nov 17 2014|10:41:53|302013|PC010 (My PC) (My PC)|49607|122.123.124.125|443|Built outbound TCP connection 7872060 for ASA_outside:122.123.124.125/443 (122.123.124.125/443) to ASA Inside:PC010 (My PC) (My PC)/49607 (ASA Outside/18949)
6|Nov 17 2014|10:41:53|305011|PC010 (My PC) (My PC)|49607|ASA Outside|18949|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49607 to ASA_outside:ASA Outside/18949
6|Nov 17 2014|10:41:53|302013|PC010 (My PC) (My PC)|49606|122.123.124.125|443|Built outbound TCP connection 7872059 for ASA_outside:122.123.124.125/443 (122.123.124.125/443) to ASA Inside:PC010 (My PC) (My PC)/49606 (ASA Outside/8626)
6|Nov 17 2014|10:41:53|305011|PC010 (My PC) (My PC)|49606|ASA Outside|8626|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49606 to ASA_outside:ASA Outside/8626
6|Nov 17 2014|10:41:53|302013|PC010 (My PC) (My PC)|49605|178.177.176.17|443|Built outbound TCP connection 7872044 for ASA_outside:178.177.176.17/443 (178.177.176.17/443) to ASA Inside:PC010 (My PC) (My PC)/49605 (ASA Outside/35660)
6|Nov 17 2014|10:41:53|305011|PC010 (My PC) (My PC)|49605|ASA Outside|35660|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49605 to ASA_outside:ASA Outside/35660
6|Nov 17 2014|10:41:53|302013|PC010 (My PC) (My PC)|49604|178.177.176.17|443|Built outbound TCP connection 7872043 for ASA_outside:178.177.176.17/443 (178.177.176.17/443) to ASA Inside:PC010 (My PC) (My PC)/49604 (ASA Outside/49604)
6|Nov 17 2014|10:41:53|305011|PC010 (My PC) (My PC)|49604|ASA Outside|49604|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49604 to ASA_outside:ASA Outside/49604
6|Nov 17 2014|10:41:52|302013|PC010 (My PC) (My PC)|49603|160.166.22.242|443|Built outbound TCP connection 7872004 for ASA_outside:160.166.22.242/443 (160.166.22.242/443) to ASA Inside:PC010 (My PC) (My PC)/49603 (ASA Outside/49603)
6|Nov 17 2014|10:41:52|305011|PC010 (My PC) (My PC)|49603|ASA Outside|49603|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49603 to ASA_outside:ASA Outside/49603
6|Nov 17 2014|10:41:52|302013|PC010 (My PC) (My PC)|49602|160.166.22.242|443|Built outbound TCP connection 7872003 for ASA_outside:160.166.22.242/443 (160.166.22.242/443) to ASA Inside:PC010 (My PC) (My PC)/49602 (ASA Outside/49602)
6|Nov 17 2014|10:41:52|305011|PC010 (My PC) (My PC)|49602|ASA Outside|49602|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49602 to ASA_outside:ASA Outside/49602
6|Nov 17 2014|10:41:52|302013|PC010 (My PC) (My PC)|49601|160.166.167.168|443|Built outbound TCP connection 7871529 for ASA_outside:160.166.167.168/443 (160.166.167.168/443) to ASA Inside:PC010 (My PC) (My PC)/49601 (ASA Outside/49601)
6|Nov 17 2014|10:41:52|305011|PC010 (My PC) (My PC)|49601|ASA Outside|49601|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49601 to ASA_outside:ASA Outside/49601
6|Nov 17 2014|10:41:52|302013|PC010 (My PC) (My PC)|49600|160.166.167.168|443|Built outbound TCP connection 7871528 for ASA_outside:160.166.167.168/443 (160.166.167.168/443) to ASA Inside:PC010 (My PC) (My PC)/49600 (ASA Outside/49600)
6|Nov 17 2014|10:41:52|305011|PC010 (My PC) (My PC)|49600|ASA Outside|49600|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49600 to ASA_outside:ASA Outside/49600
6|Nov 17 2014|10:41:52|302013|PC010 (My PC) (My PC)|49599|66.67.127.45|443|Built outbound TCP connection 7871985 for ASA_outside:66.67.127.45/443 (66.67.127.45/443) to ASA Inside:PC010 (My PC) (My PC)/49599 (ASA Outside/49599)
6|Nov 17 2014|10:41:52|305011|PC010 (My PC) (My PC)|49599|ASA Outside|49599|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49599 to ASA_outside:ASA Outside/49599
6|Nov 17 2014|10:41:52|302013|PC010 (My PC) (My PC)|49598|66.67.127.45|443|Built outbound TCP connection 7871984 for ASA_outside:66.67.127.45/443 (66.67.127.45/443) to ASA Inside:PC010 (My PC) (My PC)/49598 (ASA Outside/49598)
6|Nov 17 2014|10:41:52|305011|PC010 (My PC) (My PC)|49598|ASA Outside|49598|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49598 to ASA_outside:ASA Outside/49598
6|Nov 17 2014|10:41:52|302013|PC010 (My PC) (My PC)|49597|152.198.197.19|443|Built outbound TCP connection 7871937 for ASA_outside:152.198.197.19/443 (152.198.197.19/443) to ASA Inside:PC010 (My PC) (My PC)/49597 (ASA Outside/49597)
6|Nov 17 2014|10:41:52|305011|PC010 (My PC) (My PC)|49597|ASA Outside|49597|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49597 to ASA_outside:ASA Outside/49597
6|Nov 17 2014|10:41:52|302013|PC010 (My PC) (My PC)|49596|152.198.197.19|443|Built outbound TCP connection 7871934 for ASA_outside:152.198.197.19/443 (152.198.197.19/443) to ASA Inside:PC010 (My PC) (My PC)/49596 (ASA Outside/49596)
6|Nov 17 2014|10:41:52|305011|PC010 (My PC) (My PC)|49596|ASA Outside|49596|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49596 to ASA_outside:ASA Outside/49596
6|Nov 17 2014|10:41:52|302013|PC010 (My PC) (My PC)|49595|152.198.197.19|443|Built outbound TCP connection 7871933 for ASA_outside:152.198.197.19/443 (152.198.197.19/443) to ASA Inside:PC010 (My PC) (My PC)/49595 (ASA Outside/49595)
6|Nov 17 2014|10:41:52|305011|PC010 (My PC) (My PC)|49595|ASA Outside|49595|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49595 to ASA_outside:ASA Outside/49595
6|Nov 17 2014|10:41:51|305012|PC010 (My PC) (My PC)|49594|ASA Outside|49594|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49594 to ASA_outside:ASA Outside/49594 duration 0:00:00
6|Nov 17 2014|10:41:51|302013|PC010 (My PC) (My PC)|49594|63.241.108.124|80|Built outbound TCP connection 7871912 for ASA_outside:63.241.108.124/80 (63.241.108.124/80) to ASA Inside:PC010 (My PC) (My PC)/49594 (ASA Outside/49594)
6|Nov 17 2014|10:41:51|305011|PC010 (My PC) (My PC)|49594|ASA Outside|49594|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49594 to ASA_outside:ASA Outside/49594
6|Nov 17 2014|10:41:51|302013|PC010 (My PC) (My PC)|49593|63.241.108.124|80|Built outbound TCP connection 7871911 for ASA_outside:63.241.108.124/80 (63.241.108.124/80) to ASA Inside:PC010 (My PC) (My PC)/49593 (ASA Outside/49593)
6|Nov 17 2014|10:41:51|305011|PC010 (My PC) (My PC)|49593|ASA Outside|49593|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49593 to ASA_outside:ASA Outside/49593
6|Nov 17 2014|10:41:51|302013|PC010 (My PC) (My PC)|49592|152.198.197.19|443|Built outbound TCP connection 7871909 for ASA_outside:152.198.197.19/443 (152.198.197.19/443) to ASA Inside:PC010 (My PC) (My PC)/49592 (ASA Outside/49592)
6|Nov 17 2014|10:41:51|305011|PC010 (My PC) (My PC)|49592|ASA Outside|49592|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49592 to ASA_outside:ASA Outside/49592
6|Nov 17 2014|10:41:51|302013|PC010 (My PC) (My PC)|49591|152.198.197.19|443|Built outbound TCP connection 7871855 for ASA_outside:152.198.197.19/443 (152.198.197.19/443) to ASA Inside:PC010 (My PC) (My PC)/49591 (ASA Outside/12006)
6|Nov 17 2014|10:41:51|305011|PC010 (My PC) (My PC)|49591|ASA Outside|12006|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49591 to ASA_outside:ASA Outside/12006
6|Nov 17 2014|10:41:51|302013|PC010 (My PC) (My PC)|49590|152.198.197.19|443|Built outbound TCP connection 7871854 for ASA_outside:152.198.197.19/443 (152.198.197.19/443) to ASA Inside:PC010 (My PC) (My PC)/49590 (ASA Outside/49590)
6|Nov 17 2014|10:41:51|305011|PC010 (My PC) (My PC)|49590|ASA Outside|49590|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49590 to ASA_outside:ASA Outside/49590
6|Nov 17 2014|10:41:49|302013|PC010 (My PC) (My PC)|49589|66.36.36.26|80|Built outbound TCP connection 7871695 for ASA_outside:66.36.36.26/80 (66.36.36.26/80) to ASA Inside:PC010 (My PC) (My PC)/49589 (ASA Outside/49589)
6|Nov 17 2014|10:41:49|305011|PC010 (My PC) (My PC)|49589|ASA Outside|49589|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49589 to ASA_outside:ASA Outside/49589
6|Nov 17 2014|10:41:49|302013|PC010 (My PC) (My PC)|49588|66.36.36.26|80|Built outbound TCP connection 7871694 for ASA_outside:66.36.36.26/80 (66.36.36.26/80) to ASA Inside:PC010 (My PC) (My PC)/49588 (ASA Outside/49588)
6|Nov 17 2014|10:41:49|305011|PC010 (My PC) (My PC)|49588|ASA Outside|49588|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49588 to ASA_outside:ASA Outside/49588
6|Nov 17 2014|10:41:41|302013|PC010 (My PC) (My PC)|49587|204.79.197.200|80|Built outbound TCP connection 7871369 for ASA_outside:204.79.197.200/80 (204.79.197.200/80) to ASA Inside:PC010 (My PC) (My PC)/49587 (ASA Outside/49587)
6|Nov 17 2014|10:41:41|305011|PC010 (My PC) (My PC)|49587|ASA Outside|49587|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49587 to ASA_outside:ASA Outside/49587
6|Nov 17 2014|10:41:41|302013|PC010 (My PC) (My PC)|49586|204.79.197.200|80|Built outbound TCP connection 7871368 for ASA_outside:204.79.197.200/80 (204.79.197.200/80) to ASA Inside:PC010 (My PC) (My PC)/49586 (ASA Outside/49586)
6|Nov 17 2014|10:41:41|305011|PC010 (My PC) (My PC)|49586|ASA Outside|49586|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49586 to ASA_outside:ASA Outside/49586
6|Nov 17 2014|10:41:41|302013|PC010 (My PC) (My PC)|49585|66.36.36.56|443|Built outbound TCP connection 7871354 for ASA_outside:66.36.36.56/443 (66.36.36.56/443) to ASA Inside:PC010 (My PC) (My PC)/49585 (ASA Outside/49585)
6|Nov 17 2014|10:41:41|305011|PC010 (My PC) (My PC)|49585|ASA Outside|49585|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49585 to ASA_outside:ASA Outside/49585
6|Nov 17 2014|10:41:41|302013|PC010 (My PC) (My PC)|49584|66.36.36.56|443|Built outbound TCP connection 7871353 for ASA_outside:66.36.36.56/443 (66.36.36.56/443) to ASA Inside:PC010 (My PC) (My PC)/49584 (ASA Outside/43421)
6|Nov 17 2014|10:41:41|305011|PC010 (My PC) (My PC)|49584|ASA Outside|43421|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49584 to ASA_outside:ASA Outside/43421
6|Nov 17 2014|10:41:41|302013|PC010 (My PC) (My PC)|49583|152.16.156.21|443|Built outbound TCP connection 7871351 for ASA_outside:152.16.156.21/443 (152.16.156.21/443) to ASA Inside:PC010 (My PC) (My PC)/49583 (ASA Outside/49583)
6|Nov 17 2014|10:41:41|305011|PC010 (My PC) (My PC)|49583|ASA Outside|49583|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49583 to ASA_outside:ASA Outside/49583
6|Nov 17 2014|10:41:41|302013|PC010 (My PC) (My PC)|49582|152.96.57.6|80|Built outbound TCP connection 7871344 for ASA_outside:152.96.57.6/80 (152.96.57.6/80) to ASA Inside:PC010 (My PC) (My PC)/49582 (ASA Outside/53784)
6|Nov 17 2014|10:41:41|305011|PC010 (My PC) (My PC)|49582|ASA Outside|53784|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49582 to ASA_outside:ASA Outside/53784
6|Nov 17 2014|10:41:41|302013|PC010 (My PC) (My PC)|49581|31.13.74.128|80|Built outbound TCP connection 7871343 for ASA_outside:31.13.74.128/80 (31.13.74.128/80) to ASA Inside:PC010 (My PC) (My PC)/49581 (ASA Outside/49581)
6|Nov 17 2014|10:41:41|305011|PC010 (My PC) (My PC)|49581|ASA Outside|49581|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49581 to ASA_outside:ASA Outside/49581
6|Nov 17 2014|10:41:40|302013|PC010 (My PC) (My PC)|49580|31.13.74.128|443|Built outbound TCP connection 7871309 for ASA_outside:31.13.74.128/443 (31.13.74.128/443) to ASA Inside:PC010 (My PC) (My PC)/49580 (ASA Outside/49580)
6|Nov 17 2014|10:41:40|305011|PC010 (My PC) (My PC)|49580|ASA Outside|49580|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49580 to ASA_outside:ASA Outside/49580
6|Nov 17 2014|10:41:40|302013|PC010 (My PC) (My PC)|49579|23.63.153.203|443|Built outbound TCP connection 7871308 for ASA_outside:23.63.153.203/443 (23.63.153.203/443) to ASA Inside:PC010 (My PC) (My PC)/49579 (ASA Outside/49579)
6|Nov 17 2014|10:41:40|305011|PC010 (My PC) (My PC)|49579|ASA Outside|49579|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49579 to ASA_outside:ASA Outside/49579
6|Nov 17 2014|10:41:39|302013|PC010 (My PC) (My PC)|49578|138.91.89.250|443|Built outbound TCP connection 7871304 for ASA_outside:138.91.89.250/443 (138.91.89.250/443) to ASA Inside:PC010 (My PC) (My PC)/49578 (ASA Outside/60687)
6|Nov 17 2014|10:41:39|305011|PC010 (My PC) (My PC)|49578|ASA Outside|60687|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49578 to ASA_outside:ASA Outside/60687
6|Nov 17 2014|10:41:39|302013|PC010 (My PC) (My PC)|49577|23.63.177.5|80|Built outbound TCP connection 7871299 for ASA_outside:23.63.177.5/80 (23.63.177.5/80) to ASA Inside:PC010 (My PC) (My PC)/49577 (ASA Outside/49577)
6|Nov 17 2014|10:41:39|305011|PC010 (My PC) (My PC)|49577|ASA Outside|49577|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49577 to ASA_outside:ASA Outside/49577
6|Nov 17 2014|10:41:39|305012|PC010 (My PC) (My PC)|49573|ASA Outside|49573|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49573 to ASA_outside:ASA Outside/49573 duration 0:00:00
6|Nov 17 2014|10:41:39|302013|PC010 (My PC) (My PC)|49576|221.222.252.23|443|Built outbound TCP connection 7871298 for ASA_outside:221.222.252.23/443 (221.222.252.23/443) to ASA Inside:PC010 (My PC) (My PC)/49576 (ASA Outside/49576)
6|Nov 17 2014|10:41:39|305011|PC010 (My PC) (My PC)|49576|ASA Outside|49576|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49576 to ASA_outside:ASA Outside/49576
6|Nov 17 2014|10:41:39|302013|PC010 (My PC) (My PC)|49575|204.79.197.200|80|Built outbound TCP connection 7871292 for ASA_outside:204.79.197.200/80 (204.79.197.200/80) to ASA Inside:PC010 (My PC) (My PC)/49575 (ASA Outside/49575)
6|Nov 17 2014|10:41:39|305011|PC010 (My PC) (My PC)|49575|ASA Outside|49575|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49575 to ASA_outside:ASA Outside/49575
6|Nov 17 2014|10:41:39|302013|PC010 (My PC) (My PC)|49574|204.79.197.200|80|Built outbound TCP connection 7871291 for ASA_outside:204.79.197.200/80 (204.79.197.200/80) to ASA Inside:PC010 (My PC) (My PC)/49574 (ASA Outside/49574)
6|Nov 17 2014|10:41:39|305011|PC010 (My PC) (My PC)|49574|ASA Outside|49574|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49574 to ASA_outside:ASA Outside/49574
6|Nov 17 2014|10:41:38|302013|PC010 (My PC) (My PC)|49573|131.253.61.98|443|Built outbound TCP connection 7871275 for ASA_outside:131.253.61.98/443 (131.253.61.98/443) to ASA Inside:PC010 (My PC) (My PC)/49573 (ASA Outside/49573)
6|Nov 17 2014|10:41:38|305011|PC010 (My PC) (My PC)|49573|ASA Outside|49573|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49573 to ASA_outside:ASA Outside/49573
6|Nov 17 2014|10:41:38|302013|PC010 (My PC) (My PC)|49572|138.91.89.250|443|Built outbound TCP connection 7871274 for ASA_outside:138.91.89.250/443 (138.91.89.250/443) to ASA Inside:PC010 (My PC) (My PC)/49572 (ASA Outside/11594)
6|Nov 17 2014|10:41:38|305011|PC010 (My PC) (My PC)|49572|ASA Outside|11594|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49572 to ASA_outside:ASA Outside/11594
6|Nov 17 2014|10:41:38|302013|PC010 (My PC) (My PC)|49571|184.73.191.34|80|Built outbound TCP connection 7871242 for ASA_outside:184.73.191.34/80 (184.73.191.34/80) to ASA Inside:PC010 (My PC) (My PC)/49571 (ASA Outside/61353)
6|Nov 17 2014|10:41:38|305011|PC010 (My PC) (My PC)|49571|ASA Outside|61353|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49571 to ASA_outside:ASA Outside/61353
6|Nov 17 2014|10:41:38|302013|PC010 (My PC) (My PC)|49570|173.194.46.123|443|Built outbound TCP connection 7871238 for ASA_outside:173.194.46.123/443 (173.194.46.123/443) to ASA Inside:PC010 (My PC) (My PC)/49570 (ASA Outside/40276)
6|Nov 17 2014|10:41:38|305011|PC010 (My PC) (My PC)|49570|ASA Outside|40276|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49570 to ASA_outside:ASA Outside/40276
6|Nov 17 2014|10:41:37|305012|PC010 (My PC) (My PC)|49569|ASA Outside|63860|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49569 to ASA_outside:ASA Outside/63860 duration 0:00:00
6|Nov 17 2014|10:41:37|302013|PC010 (My PC) (My PC)|49569|63.241.108.124|80|Built outbound TCP connection 7871218 for ASA_outside:63.241.108.124/80 (63.241.108.124/80) to ASA Inside:PC010 (My PC) (My PC)/49569 (ASA Outside/63860)
6|Nov 17 2014|10:41:37|305011|PC010 (My PC) (My PC)|49569|ASA Outside|63860|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49569 to ASA_outside:ASA Outside/63860
6|Nov 17 2014|10:41:37|302013|PC010 (My PC) (My PC)|49568|65.55.121.245|80|Built outbound TCP connection 7871216 for ASA_outside:65.55.121.245/80 (65.55.121.245/80) to ASA Inside:PC010 (My PC) (My PC)/49568 (ASA Outside/29271)
6|Nov 17 2014|10:41:37|305011|PC010 (My PC) (My PC)|49568|ASA Outside|29271|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49568 to ASA_outside:ASA Outside/29271
6|Nov 17 2014|10:41:36|302013|PC010 (My PC) (My PC)|49567|65.55.121.245|80|Built outbound TCP connection 7871150 for ASA_outside:65.55.121.245/80 (65.55.121.245/80) to ASA Inside:PC010 (My PC) (My PC)/49567 (ASA Outside/49567)
6|Nov 17 2014|10:41:36|305011|PC010 (My PC) (My PC)|49567|ASA Outside|49567|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49567 to ASA_outside:ASA Outside/49567
6|Nov 17 2014|10:41:36|302013|PC010 (My PC) (My PC)|49566|65.55.121.245|80|Built outbound TCP connection 7871149 for ASA_outside:65.55.121.245/80 (65.55.121.245/80) to ASA Inside:PC010 (My PC) (My PC)/49566 (ASA Outside/49566)
6|Nov 17 2014|10:41:36|305011|PC010 (My PC) (My PC)|49566|ASA Outside|49566|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49566 to ASA_outside:ASA Outside/49566
6|Nov 17 2014|10:41:36|302013|PC010 (My PC) (My PC)|49565|65.52.108.11|80|Built outbound TCP connection 7871147 for ASA_outside:65.52.108.11/80 (65.52.108.11/80) to ASA Inside:PC010 (My PC) (My PC)/49565 (ASA Outside/49565)
6|Nov 17 2014|10:41:36|305011|PC010 (My PC) (My PC)|49565|ASA Outside|49565|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49565 to ASA_outside:ASA Outside/49565
6|Nov 17 2014|10:41:36|302013|PC010 (My PC) (My PC)|49564|138.91.89.250|80|Built outbound TCP connection 7871138 for ASA_outside:138.91.89.250/80 (138.91.89.250/80) to ASA Inside:PC010 (My PC) (My PC)/49564 (ASA Outside/65490)
6|Nov 17 2014|10:41:36|305011|PC010 (My PC) (My PC)|49564|ASA Outside|65490|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49564 to ASA_outside:ASA Outside/65490
6|Nov 17 2014|10:41:36|302013|PC010 (My PC) (My PC)|49563|66.67.126.181|80|Built outbound TCP connection 7871137 for ASA_outside:66.67.126.181/80 (66.67.126.181/80) to ASA Inside:PC010 (My PC) (My PC)/49563 (ASA Outside/49563)
6|Nov 17 2014|10:41:36|305011|PC010 (My PC) (My PC)|49563|ASA Outside|49563|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49563 to ASA_outside:ASA Outside/49563
6|Nov 17 2014|10:41:36|302013|PC010 (My PC) (My PC)|49562|66.67.114.120|80|Built outbound TCP connection 7871135 for ASA_outside:66.67.114.120/80 (66.67.114.120/80) to ASA Inside:PC010 (My PC) (My PC)/49562 (ASA Outside/49562)
6|Nov 17 2014|10:41:36|305011|PC010 (My PC) (My PC)|49562|ASA Outside|49562|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49562 to ASA_outside:ASA Outside/49562
6|Nov 17 2014|10:41:36|302013|PC010 (My PC) (My PC)|49561|66.67.114.120|80|Built outbound TCP connection 7871134 for ASA_outside:66.67.114.120/80 (66.67.114.120/80) to ASA Inside:PC010 (My PC) (My PC)/49561 (ASA Outside/49561)
6|Nov 17 2014|10:41:36|305011|PC010 (My PC) (My PC)|49561|ASA Outside|49561|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49561 to ASA_outside:ASA Outside/49561
6|Nov 17 2014|10:41:36|302013|PC010 (My PC) (My PC)|49560|66.67.114.120|80|Built outbound TCP connection 7871133 for ASA_outside:66.67.114.120/80 (66.67.114.120/80) to ASA Inside:PC010 (My PC) (My PC)/49560 (ASA Outside/49560)
6|Nov 17 2014|10:41:36|305011|PC010 (My PC) (My PC)|49560|ASA Outside|49560|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49560 to ASA_outside:ASA Outside/49560
6|Nov 17 2014|10:41:36|302013|PC010 (My PC) (My PC)|49559|66.67.114.120|80|Built outbound TCP connection 7871132 for ASA_outside:66.67.114.120/80 (66.67.114.120/80) to ASA Inside:PC010 (My PC) (My PC)/49559 (ASA Outside/49559)
6|Nov 17 2014|10:41:36|305011|PC010 (My PC) (My PC)|49559|ASA Outside|49559|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49559 to ASA_outside:ASA Outside/49559
6|Nov 17 2014|10:41:36|302013|PC010 (My PC) (My PC)|49558|66.67.114.120|80|Built outbound TCP connection 7871131 for ASA_outside:66.67.114.120/80 (66.67.114.120/80) to ASA Inside:PC010 (My PC) (My PC)/49558 (ASA Outside/49558)
6|Nov 17 2014|10:41:36|305011|PC010 (My PC) (My PC)|49558|ASA Outside|49558|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49558 to ASA_outside:ASA Outside/49558
6|Nov 17 2014|10:41:36|302013|PC010 (My PC) (My PC)|49557|66.67.114.120|80|Built outbound TCP connection 7871130 for ASA_outside:66.67.114.120/80 (66.67.114.120/80) to ASA Inside:PC010 (My PC) (My PC)/49557 (ASA Outside/52103)
6|Nov 17 2014|10:41:36|305011|PC010 (My PC) (My PC)|49557|ASA Outside|52103|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49557 to ASA_outside:ASA Outside/52103
6|Nov 17 2014|10:41:36|302013|PC010 (My PC) (My PC)|49556|66.36.36.27|80|Built outbound TCP connection 7871127 for ASA_outside:66.36.36.27/80 (66.36.36.27/80) to ASA Inside:PC010 (My PC) (My PC)/49556 (ASA Outside/40678)
6|Nov 17 2014|10:41:36|305011|PC010 (My PC) (My PC)|49556|ASA Outside|40678|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49556 to ASA_outside:ASA Outside/40678
6|Nov 17 2014|10:41:36|302013|PC010 (My PC) (My PC)|49555|66.36.36.27|80|Built outbound TCP connection 7871126 for ASA_outside:66.36.36.27/80 (66.36.36.27/80) to ASA Inside:PC010 (My PC) (My PC)/49555 (ASA Outside/49555)
6|Nov 17 2014|10:41:36|305011|PC010 (My PC) (My PC)|49555|ASA Outside|49555|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49555 to ASA_outside:ASA Outside/49555
6|Nov 17 2014|10:41:36|302013|PC010 (My PC) (My PC)|49554|66.36.36.27|80|Built outbound TCP connection 7871125 for ASA_outside:66.36.36.27/80 (66.36.36.27/80) to ASA Inside:PC010 (My PC) (My PC)/49554 (ASA Outside/49554)
6|Nov 17 2014|10:41:36|305011|PC010 (My PC) (My PC)|49554|ASA Outside|49554|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49554 to ASA_outside:ASA Outside/49554
6|Nov 17 2014|10:41:36|302013|PC010 (My PC) (My PC)|49553|66.36.36.27|80|Built outbound TCP connection 7871124 for ASA_outside:66.36.36.27/80 (66.36.36.27/80) to ASA Inside:PC010 (My PC) (My PC)/49553 (ASA Outside/49553)
6|Nov 17 2014|10:41:36|305011|PC010 (My PC) (My PC)|49553|ASA Outside|49553|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49553 to ASA_outside:ASA Outside/49553
6|Nov 17 2014|10:41:36|302013|PC010 (My PC) (My PC)|49552|66.36.36.27|80|Built outbound TCP connection 7871123 for ASA_outside:66.36.36.27/80 (66.36.36.27/80) to ASA Inside:PC010 (My PC) (My PC)/49552 (ASA Outside/4677)
6|Nov 17 2014|10:41:36|305011|PC010 (My PC) (My PC)|49552|ASA Outside|4677|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49552 to ASA_outside:ASA Outside/4677
6|Nov 17 2014|10:41:36|302013|PC010 (My PC) (My PC)|49551|66.36.36.27|80|Built outbound TCP connection 7871122 for ASA_outside:66.36.36.27/80 (66.36.36.27/80) to ASA Inside:PC010 (My PC) (My PC)/49551 (ASA Outside/54514)
6|Nov 17 2014|10:41:36|305011|PC010 (My PC) (My PC)|49551|ASA Outside|54514|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49551 to ASA_outside:ASA Outside/54514
6|Nov 17 2014|10:41:36|302013|PC010 (My PC) (My PC)|49550|66.36.36.10|80|Built outbound TCP connection 7871119 for ASA_outside:66.36.36.10/80 (66.36.36.10/80) to ASA Inside:PC010 (My PC) (My PC)/49550 (ASA Outside/33291)
6|Nov 17 2014|10:41:36|305011|PC010 (My PC) (My PC)|49550|ASA Outside|33291|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49550 to ASA_outside:ASA Outside/33291
6|Nov 17 2014|10:41:36|302013|PC010 (My PC) (My PC)|49549|221.222.252.23|80|Built outbound TCP connection 7871117 for ASA_outside:221.222.252.23/80 (221.222.252.23/80) to ASA Inside:PC010 (My PC) (My PC)/49549 (ASA Outside/49549)
6|Nov 17 2014|10:41:36|305011|PC010 (My PC) (My PC)|49549|ASA Outside|49549|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49549 to ASA_outside:ASA Outside/49549
6|Nov 17 2014|10:41:36|302013|PC010 (My PC) (My PC)|49548|111.155.12.137|80|Built outbound TCP connection 7871114 for ASA_outside:111.155.12.137/80 (111.155.12.137/80) to ASA Inside:PC010 (My PC) (My PC)/49548 (ASA Outside/49548)
6|Nov 17 2014|10:41:36|305011|PC010 (My PC) (My PC)|49548|ASA Outside|49548|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49548 to ASA_outside:ASA Outside/49548
6|Nov 17 2014|10:41:20|305012|PC010 (My PC) (My PC)|49547|ASA Outside|49547|Teardown dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49547 to ASA_outside:ASA Outside/49547 duration 0:00:00
6|Nov 17 2014|10:41:20|302013|PC010 (My PC) (My PC)|49547|152.198.197.19|443|Built outbound TCP connection 7870053 for ASA_outside:152.198.197.19/443 (152.198.197.19/443) to ASA Inside:PC010 (My PC) (My PC)/49547 (ASA Outside/49547)
6|Nov 17 2014|10:41:20|305011|PC010 (My PC) (My PC)|49547|ASA Outside|49547|Built dynamic TCP translation from ASA Inside:PC010 (My PC) (My PC)/49547 to ASA_outside:ASA Outside/49547
114
