ASA5540s failover automatically switchover issue (Ac/Standby)
Hello Pro,
I have two asa5540 configured in standard Ac/Standby failover mode, but often switchover automaticlly. Probably in 30 minutes switchover to secondary asa5540 up. when I manually switchover back to primary asa5540 by issing failover active. I get the following errors:
Beijing-ASA5540-A# failover active
vPif_getVpif: bad vPifNum(0xffffffff) from 88592C1 from 84BBBAD
Switching to Active
Beijing-ASA5540-A# vPif_getVpif: bad vPifNum(0xffffffff) from 88592C1 from 84BBBAD
Could you tell this is related to a hardware issue or software issue, and how do I eradicate it ? Thank you very much
1 REPLY
Anonymous
N/A
Re: ASA5540s failover automatically switchover issue (Ac/Standby
You may try deleting the "management-access" command on the outside interface if you have configured it.
343
