ASA5550 port channel configuration ERROR: nameif not allowed on empty etherchannel interface
Hi All,
I am having problem when configure port channel on asa5550
IOS ver asa914-k8.bin also in ver 9.02   and 8.47.
Please let me know how can I solve this problem.
UK-LON-FW(config)# int port-channel 3
UK-LON-FW(config-if)# vlan 245
ERROR: % Invalid input detected at '^' marker.
UK-LON-FW(config-if)# nameif secure
ERROR: nameif not allowed on empty etherchannel interface.
here is my interfaces configuration:
interface GigabitEthernet0/0
description fw1:G0/0 to uk-lon-gw1:e1/8 fw2:G0/0 to uk-lon-gw2:e1/9 outside zone
channel-group 1 mode on
no nameif
no security-level
no ip address
interface GigabitEthernet0/1
description fw1:G0/1 to uk-lon-gw2:e1/8 fw2:G0/1 to uk-lon-gw1:e1/9 outside zone
no nameif
no security-level
no ip address
interface GigabitEthernet0/2
description fw1:G0/2 to uk-lon-sw1a:1 fw2:G0/2 to uk-lon-sw1a:2 dmz
channel-group 2 mode on
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
description fw1:G0/3 to uk-lon-sw1b: fw2:G0/3 to uk-lon-sw1b:2 dmz
no nameif
no security-level
no ip address
interface Management0/0
management-only
nameif management
security-level 0
ip address 10.10.51.18 255.255.254.0
interface GigabitEthernet1/0
description fw1:G1/0 to uk-lon-sw1a:3 fw2:G1/0 to uk-lon-sw1a:4 secure zone
no nameif
no security-level
no ip address
interface GigabitEthernet1/1
description fw1:G1/1 to uk-lon-sw1b:3 fw2:G1/1 to uk-lon-sw1b:4 secure zone
no nameif
no security-level
no ip address
interface GigabitEthernet1/2
description LAN Failover Interface
no nameif
no security-level
no ip address
interface GigabitEthernet1/3
description STATE Failover Interface
no nameif
no security-level
no ip address
interface Port-channel1
description outside zone
no nameif
no security-level
no ip address
interface Port-channel1.5
description outside zone Bundle FW:G0/0-G0/1 connect to GW1:e1/8-GW2:e1/8
vlan 5
nameif outside
security-level 0
ip address 216.239.105.5 255.255.255.128 standby 216.239.105.6
interface Port-channel2
description dmz Bunlde uk-lon-fw:G0/2-3 to sw1a:1-2 sw1b:1-2
no nameif
no security-level
no ip address
interface Port-channel2.105
description dmz
vlan 105
nameif dmz
security-level 50
ip address 216.239.105.193 255.255.255.192 standby 216.239.105.194
interface Port-channel3
description secure zone Bunlde uk-lon-fw:G1/0-1 to sw1a:3-3 sw1b:3-4
no nameif
security-level 100
ip address 10.254.105.1 255.255.255.0 standby 10.254.105.2
Hall of Fame Super Silver
Re: ASA5550 port channel configuration ERROR: nameif not allowed
Your logical interface port-channel 3 has no physical members assigned to it. Assign some (i.e one or more physical ports should have "channel-group 3" command).
Also, you would normally assign a VLAN to a subinterface on this size of firewall - not to the port-channel parent.
Hi Marvin,
Thank you for your answer.  I did everything but it did not work. Turn out it is a bug ver 8.45 will let you created the sub logical interface but actually it did not work right.  Verson 9.x  doesn't let you create more than 2 port channel (limitation of ASA5550 hardware).
https://tools.cisco.com/bugsearch/bug/CSCtq62715/?reffering_site=dumpcr
Also, you can see the 8.4 release notes were you can see that it is not supported:
http://www.cisco.com/c/en/us/td/docs/security/asa/asa84/release/notes/asarn84.html#pgfId-522232
Interface Features
EtherChannel support (ASA 5510 and higher)
You can configure up to 48 802.3ad EtherChannels of eight active interfaces each.
Note You cannot use interfaces on the 4GE SSM, including the integrated 4GE SSM in slot 1 on the ASA 5550, as part of an EtherChannel.
We introduced the following commands: channel-group , lacp port-priority , interface port-channel , lacp max-bundle , port-channel min-bundle , port-channel load-balance , lacp system-priority , clear lacp counters , show lacp , show port-channel .
Thanks for updating us on the root cause of the problem.
I had overlooked the two portchannel limitation. That's a good one to remember.
642
