ASA5580-20 high cpu utilization in system context
We have an active-active pair of cisco ASA5580-20 with software version 8.4(1)9.
There are 8 contexts on it (including admin and system). 1 context is active on Primary node and other 7 are active on Secondary node.
User traffic is going through this 1 context (2 interfaces - inside to users, outside to internet) and there are peaks to 1.16M concurrent connections, max bandwidth is 1.25Gbps. CPU usage for this context in peak hours is 63%, but we noticed that when we run "show cpu usage context all" from system it shows that system context is using 25% of CPU and "Total CPU utilization" (form output of show cpu detailed - on system context) is 88% which is bad.
In non peak hours - user context use 33.6% CPU, system use 14.5%, total CPU usage is 50.5%
So, is it normal this cpu utilization on system context (system on Primary node)?
BR,
Plamen
1 REPLY
Hi Plamen,
The answer to your question depends on why the CPU utilization is high. If the CPU is high because of an increased amount of traffic processing during peak hours, then the increase could indeed be normal. I would suggest opening a TAC case to have this investigated further.
-Mike
575
