ASA5580 - inside shared interface causing syslog issues
We have two ASA5580s in HA mode and are having the same issue as reported in June 2009.  (Heading - ASA5520 inside shared interface).
Until recently we have been receiving all syslog messages correctly. However now the syslog server is not receiving logs for traffic entering from
other contexts.
The two interfaces external and campus (internal) share the same interfaces.  Unique mac-addresses have been assigned automatically as per best
practices.
The configurations are as below:
System context
mac-address auto
context sys
  allocate-interface Management0/0 mgmtsys
  allocate-interface TenGigabitEthernet7/0 external
  allocate-interface TenGigabitEthernet7/1.2 campus
  allocate-interface TenGigabitEthernet7/1.17 app
  allocate-interface TenGigabitEthernet8/0.18 db
  allocate-interface TenGigabitEthernet8/0.118 keep
  config-url disk0:/sys.cfg
context assembly
  allocate-interface Management0/0 mgmtass
  allocate-interface TenGigabitEthernet7/1.19 app
  allocate-interface TenGigabitEthernet8/0.20 db
  allocate-interface TenGigabitEthernet8/0.120 keep
  config-url disk0:/assembly.cfg
  join-failover-group 1
Syslog Configs
sys context - traffic from sys to assembly
Nov 29 17:28:42 10.91.21.7 %ASA-6-106100: access-list keepin permitted tcp keep/10.91.118.33(48923) -> campus/10.91.20.31(22) hit-cnt 1 300-second
interval [0x1985579a, 0x17098ed8]
assembly context
No syslog result is seen coming into assembly however rule works.  (We tested by disabling the rule).
According to the original answer we have to add a global command to each context but I'm not sure how this is done.  I have read the doco but I'm
still not completely sure.
Is the below correct?
sys context
Existing
interface external
nameif external
security-level 0
ip address x.x.x.x 255.255.255.0 standby y.y.y.y
interface campus
nameif campus
security-level 30
interface app
nameif app
security-level 50
interface db
nameif db
security-level 100
interface keep
nameif keep
security-level 70
interface mgmtsys
nameif mgmt
security-level 100
management-only
access-list 101 extended permit ip any any (not applied anywhere)
Required
global (campus) 1 interface
Do we need to add static NATs?  Will this not change how the IP addresses are seen elsewhere?
Thanks in advance and hope this all makes sense.
Bryce
Re: ASA5580 - inside shared interface causing syslog issues
Hi Bryce,
Unfortunately its not quite clear what the problem is. I understand there is an issue with syslogs? A topology will help in better understanding the problem.
Prapanch
Prapanch,
Sorry for not getting back to you earlier.
I think our issue is to do with having the same shared inside interface (in this case campus)
When I do a packet-tracer command I get the following responses (rules are in and connectivity is working).
From context sys to context assembly.
internal-asa-1/act/sys# packet-tracer input keep tcp 10.91.118.33 48552 10.91.20.31 22
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Found no matching flow, creating a new flow
Phase: 3
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   10.0.0.0        255.0.0.0       campus
Phase: 4
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group keepin in interface keep
access-list keepin extended permit object-group svc-ssh object-group grp-keepdb-syst object-group grp-db2-ass log
object-group service svc-ssh
service-object tcp eq ssh
object-group network grp-keepdb-syst
network-object host 10.91.118.33
object-group network grp-db2-ass
network-object host 10.91.20.31
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: FOVER
Subtype: standby-update
Result: ALLOW
Config:
Phase: 7
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 8
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 2887113746, packet dispatched to next module
Result:
input-interface: keep
input-status: up
input-line-status: up
output-interface: campus
output-status: up
output-line-status: up
Action: allow
Into context assembly from context sys
internal-asa-1/act/sys# chan cont ass
internal-asa-1/act/assembly# packet-tracer input campus tcp 10.91.118.33 48552 10.91.20.31 22
Result:
input-interface: campus
input-status: up
Action: drop
Drop-reason: (ifc-classify) Virtual firewall classification failed
internal-asa-1/act/assembly# exit
According to Cisco documentation to rectify this we need to add static NATs.  But will this not change how the IP addresses are seen elsewhere?
Hope this adds a bit more light into what we are trying to do.
Bryce.
Hi Bryce,
Do you have the mac-address auto command configured on your ASA? This might help us in our situation. Let me know how it goes.
Thanks and Regards,
Prapanch
Prapanch,
Mac-address auto is configured on the system context.
Hi Bryce,
I would suggest opening up a TAC case to take a look into this. Unfortunately, i am still unable to get a clear picture of the topology and live access to the device will certainly help.
Do let us know how it goes for the benefit of the community!
Cheers,
Prapanch
568
