Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
ASDM 6.6 - AnyConnect Wizard Issue
I'm facing with a strange issue with ASDM version 6.6. I'm trying to configure ANYConnect VPN by ASDM Consol, but the wizards about make/choose Profile and NAT are gray(empty) and there is no any options. had anybody same as this experience ?
ASA Version : 8.6(1)2
ASDM Version : 6.6(1)
Thank You
A. Ladani
1 ACCEPTED SOLUTION
VIP Green
Re: ASDM 6.6 - AnyConnect Wizard Issue
When you say cisco user/password do you mean for the cisco software download website?  If so, then you would need a service contract with Cisco in order to be able to download (creating a user account is free though) or you need to contact your local Cisco reseller.
If it is the password to access the ASDM then you can try entering pix for the username and your enable password as the password
Otherwise to upgrade the ASDM you just need to copy it to the flash from a TFTP server:
copy tftp flash
and then fill in the required fields when prompted (this includes TFTP server IP, the file name on the TFTP server including file type such as .bin, and the name you would like to save the file as on the flash (just hit enter here to keep the same file name.)
Then to start using the new ASDM image enter the following command:
asdm image
and you are good to go.
Here is a link you can read through on upgrading software on an ASA.
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008067e9f9.shtml#maintask2
Please remember to rate and select a correct answer
VIP Green
That is odd.  Is it just the Profile page and/or NAT exempt page that are blank?   The screenshot you posted is just blank.  Are you in a position where you can restart the ASA and then test?
Have you tried replacing the existing ASDM image with a fresh copy?
If those dont work then you may have to upgrade the ASDM image.  However, before you do that, configuring AnyConnect isn't very difficult through the CLI or ASDM (non-wizard), so you may want to consider that before investing time and money in trying to fix this problem.
Here is some reading on configuring AnyConnect using the ASDM
http://www.cisco.com/en/US/docs/security/vpn_client/anyconnect/anyconnect25/administration/guide/ac02asaconfig.html
I tried to upgrade the ASDM, but it asks me cisco user/pass, i don't have. Is there any other solution to do that ?
Its not only about AnyConnect wizard Profile and Nat, same problem is about IPSec VPN Wizards. After opening IPSec wizard there is no any function when i press next button.
Please send me any link regarding ASDM Upgrading or replacing with fresh one if you have.
Thank You
VIP Green
copy tftp flash
asdm image
Thank You
Perfect!!!
185
