asdm asdm-634.bin x asa708-k8
Is possible to use this version asa708 with asdm version 643 ?
I did try install it but didn´t work.
Do it have some compatibility matrix avaiable ?
regards
AB
Re: asdm asdm-634.bin x asa708-k8
Hello!!
Mike here, yes there is. For 7.0(8) latest is 5.0 (8). Here is the matrix that you are looking for.
http://www.cisco.com/en/US/docs/security/asa/compatibility/asamatrx.html
Hope it helps.
Mike
Mike
so ,, ???
shoudn´t have problem ??
br
Ab
Jose Alfonso,
ASA version 7.0 can only support ASDM 5.0, if you want to run ASDM 6.3.4 please upgrade to 8.0.
Check on the Matrix for more info.
Mike
Mike
950
