Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASDM Authentication Issue
Running ASDM Launcher ver 1.5. on ASA 7.2 When I enter Userid and Psw which I have used for sometime, it now comes up with new window Authenication Required". Entering the same info as before is NO GO. Canceling window produces Error:Unable to launch ASDM from xxx.xxx.xxx.xxx:Authenication failed.
Anyone have any ideas?
Thanks Mucho!!
1 ACCEPTED SOLUTION
Community Member
Re: ASDM Authentication Issue
Try leaving the username blank and then entering your regular password. I'm working on getting an ASA 5505 set up via the ASDM, and that's what it takes to get me back in for another attempt. Hope that helps you out, though!
Community Member
Community Member
Hey, that did the trick!!!
Thanks Mucho!!!!
Community Member
Thank you this helped had the same issue with a 4100 asa cluster, I changed the user name and enable password from cli and this box began coming up when opening asdm
Community Member
You're welcome; glad I could help.
1036
