Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASDM error after changing privilege level from 2 to 15
After basic installation (local) with nat,some ACLs and ssh-access I changed in ASDM the privilege level from my username from level 2 to level 15.
The result is that I can´t load configuration with ASDM and the following error message appears:
ASDM did not get a response from the ASA in the last 60 seconds. Please check the configuration and your connection and then try again by clicking Refresh
What´s going wrong? SSH is working fine with this username.
1 REPLY
Community Member
Re: ASDM error after changing privilege level from 2 to 15
SORRY: ASA 5505, Version 8.2(5), ASDM version 6.4(5)
Another problem occurs after configuring aaa authorization command LOCAL (see attachement)
So I tried ASDM version 6.4(7) but with the same result.
728
