Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
ASDM error - Unconnected sockets not implemented
Having a bit of trouble understanding the simplicity of this error message. Browsed around and found nothing specifically related to the issue at hand.
I ran the ASDM software and device/user/password box comes up. I type in my user/pass with the device already saved. Select OK and then the error message displays "ASDM cannot be loaded. Click OK to exit ASDM. Unconnected sockets not implemented"
However this only happens on one pc (mine) and is a bit frustrating to have to go to another pc anytime I need to access the asa through asdm. I have tried reinstalling the asdm software and running it from the java web console.
Re: ASDM error - Unconnected sockets not implemented
Anthony,
I would check which java version you have installed on the PC. I had the same problem when my PC was upgraded to Java version 6 update 10. I downgraded back to Java version 6 update 7 and it resolved the issue.
HTH,
Mark
that was the fix. thank you for the help
131
