05-01-2007 03:09 AM - edited 03-11-2019 03:07 AM
I'm trying to get the ASDM going on a PIX 515e. this is the output of a sh flash
Directory of flash:/
4 -rw- 10482 04:26:56 Oct 13 2006 downgrade.cf
7 -rw- 5107768 04:27:59 Oct 13 2006 image.bin
11 -rw- 8202240 04:35:05 Oct 13 2006 pix721.bin
Now i think i need the asdm-522.bin which i have but there's not enough space.
As far as i can see there are two IOS images (image and PIX) and from this config line
boot system flash:/pix721.bin
I assume this pix is booting from the pix.721.bin file not image.bin.
What i want to is erase the flash, tftp back the the .cfg and the .bin and then add asdm-522.bin.
My problem is I can't back up the image.bin file
%Error copying flash:/image.bin (Inappropriate file type or format)
Can anyone advise? I don't want to get into a situation where i can't roll back.
Also can i confirm i'm on the right track with the ASDM?
Here's the show version
Cisco PIX Security Appliance Software Version 7.0(2)
Compiled on Fri 15-Jul-05 22:55 by builders
System image file is "Unknown, monitor mode tftp booted image"
Config file at boot was "startup-config"
pix up 49 days 17 hours
Hardware: PIX-515E, 64 MB RAM, CPU Pentium II 433 MHz
Flash E28F128J3 @ 0xfff00000, 16MB
BIOS Flash AM29F400B @ 0xfffd8000, 32KB
0: Ext: Ethernet0 : address is 000c.3035.a10a, irq 10
1: Ext: Ethernet1 : address is 000c.3035.a10b, irq 11
2: Ext: Ethernet2 : address is 00d0.b720.c045, irq 11
Licensed features for this platform:
Maximum Physical Interfaces : 3
Maximum VLANs : 10
Inside Hosts : Unlimited
Failover : Disabled
VPN-DES : Enabled
VPN-3DES-AES : Disabled
Cut-through Proxy : Enabled
Guards : Enabled
URL Filtering : Enabled
Security Contexts : 0
GTP/GPRS : Disabled
VPN Peers : Unlimited
This platform has a Restricted (R) license.
Serial Number: 807076662
Running Activation Key: xxx
Configuration last modified by enable_15 at 01:41:41.131 UTC Tue May 1 2007
Kind regards
J Mack
05-01-2007 03:39 AM
Does anyone think this could be because image.bin has been deleted but the PIX not Reloaded?
05-01-2007 05:25 AM
I agree a reload is required.
I suspect that the new software has beel loaded, and the PIX instructed to use it at next reboot. But the rebbot hasn't been completed.
The image on flash is named 721.bin, which implies version 7.2(1)- The file *could* be incorrectly named.
The booted system is running 7.0(2)
I recomend that you upgrade again, place the updated image in image.bin, redirect the boot command and remove 721.bin.
IMHO it is better to keep PIX image named generic
05-01-2007 11:24 PM
Thanks, after a reboot ios has indeed changed to 7.2.1. I still cannot tftp image.bin? Is this file likely to be doing anything or do you should i assume it's safe to get rid of so i can free space to load the asdm.bin file.
05-02-2007 12:10 AM
Hi Johnny
Excerpt from ASA configuration doc.
By default, the security appliance boots the first application image it finds in internal Flash memory. It also boots the first ASDM image it finds in internal Flash memory, or of none exists there, then in external Flash memory. If you have more than one image, you should specify the image you want to boot. In the case of the ASDM image, if you do not specify the image to boot, even if you have only one image installed, then the security appliance inserts the asdm image command into the running configuration. To avoid problems with Auto Update (if configured), and to avoid the image search at each startup, you should specify the ASDM image you want to boot in the startup configuration.
?To configure the application image to boot, enter the following command:
hostname(config)# boot system "url"
This would suggest that as long as you are sure that your boot statement in your config matches exactly the pix7.2.1 image in flash then you should be able to delete the image file.
Jon
