Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASDM - How to run multi versions
We have serveral ASAs installed and adding more. Of course the new boxes have a new version of ASDM. How can I access both the older and newer versions of ASDM?
Thanks Mucho!!!!
1 ACCEPTED SOLUTION
Re: ASDM - How to run multi versions
Here's an example-
Cisco ASDM 6.1(5) is a web-based application to configure and monitor the ASA/PIX security appliance running version 8.0 or 8.1. ASDM 6.1(5)51 is an engineering build based on the ASDM 6.1(5) release.
You would have to change the config to point to the one you want.
asdm image disk0:/asdm-613.bin
or
asdm image disk0:/asdm-603.bin
Why not upgrade all the boxes to the latest or a version you're comfortable with?
Community Member
Collin, thanks for your reply! Is the ASDM Image dependent on the version of code that the ASA is running?
Yes, you will have to read the release notes. It will tell you which versions are supported.
Here's an example-
Community Member
Collin, thanks for your help with this issue!!!
No problem.
149
