ASDM Interface
My setup is :PIX 515E, IOS 8.0(4)28, ASDM 6.1(5)57, Firewall mode routed, 6 interfaces, 128Mb.
My question is, can ASDM be accessed through any interface on the PIX besides ethernet1? I'd prefer to run ASDM through ethernet5 but it refuses to run. I have tried deconfiguring eth1 and copying its config to eth5 to no avail. The basic setup on eth1 that works is:
interface Ethernet1
 nameif Management
 security-level 100
 ip address 100.100.100.18 255.255.255.0
This doesn't work on eth5.
Matt.
2 ACCEPTED SOLUTIONS
Hi,Would you be able to reply
Would you be able to reply with these outputs from the PIX:-
1) show asp table socket
2) show run interface eth5
Also , is the IP from which you are trying to access the ASDM in the same Network as the range configured on the Interface ?
Thanks and Regards,
Vibhor Amrodia
Hi,So , were you able to
So , were you able to resolve this issue ?
Thanks and Regards,
Vibhor Amrodia
Thanks and Regards,
Vibhor Amrodia
The responses are as follows
The responses are as follows:
PIX515E#  show asp table socket
Protocol  Socket    Local Address               Foreign Address         State
TCP       0002082c  100.100.100.18:23           0.0.0.0:*              LISTEN
SSL       0002e9ec  100.100.100.18:443         0.0.0.0:*               LISTEN
SSL       0008993c  100.100.100.18:443         Miffy:1063            ESTAB
PIX515E# show run interface eth5
interface Ethernet5
 description MGT_INTERFACE
 speed 100
 duplex full
 nameif Management
 security-level 0
I figured it out. I was allowing telnet/http access to the inside interface, not the management interface. Inside is Eth1, Management is Eth5.
A force of habit. As this PIX has 6 Eth interfaces I thought I'd dedicate one to management. Now to interface between my 877 & 1751-V!
Thanks for your help Vibhor.
Thanks and Regards,
Vibhor Amrodia
Yes thanks Vibhor. I was
Yes thanks Vibhor. I was reminded of a valuable lesson, it's all in the logic. The answer, as usual, was staring me in the face. ASDM can be accessed from any interface. In the process I also figured out that you can't telnet into these PIX. One must set up SSH2 to do this.
33
