Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASDM issues
Hello all,
I don't personally use the ASDM and so have little experience with it, but I need to get it working for others to perform basic admin duties.
I am running 8.0(5) and ASDM version 6.1(5) on all firewalls, and it is working without problem on 98/100. I have 2 firewalls that the ASDM will not load for. When browsing to the web page, I get the initial security warning regarding the certificate being potentially unsafe, but when I click "continue anyway" I immediately receive a http 404 not found connecting to either the inside or outside interface.
The image location is set explicitily in the config, and the relevant statements are in the config allowing access from my management networks. SSL webvpn is not enabled on the device.
The config in place:
boot system disk0:/asa805-k8.bin
asdm image disk0:/asdm-615.bin
http server enable
http myexternalnetwork 255.255.255.0 outside
http myinternalnetwork 255.255.255.0 inside
Hostname# sh disk0:
--#--  --length--  -----date/time------  path
   79  8192        Aug 21 2008 12:45:18  crypto_archive
  148  13934592    Jan 18 2010 15:13:22  asa805-k8.bin
  151  1339056     Jan 18 2010 16:04:30  asdm-615.bin
management-access inside
In sh ver I do not see any Device Manager Image statement where it would usually be expected:
Hostnameg# sh ver
Cisco Adaptive Security Appliance Software Version 8.0(5)
Compiled on Mon 02-Nov-09 21:22 by builders
System image file is "disk0:/asa805-k8.bin"
Config file at boot was "startup-config"
I have enabled logging, and can see the connection being established but it is immediately terminated:
Feb 05 2010 12:03:40: %ASA-6-302013: Built inbound TCP connection 18865 for outside:sourceIP/57225 (sourceIP/57225) to identity:destinationIP/443 (destinationIP/443)
Feb 05 2010 12:03:40: %ASA-6-725001: Starting SSL handshake with client outside:sourceIP/57225 for TLSv1 session.
Feb 05 2010 12:03:40: %ASA-6-725003: SSL client outside:sourceIP/57225 request to resume previous session.
Feb 05 2010 12:03:40: %ASA-6-725002: Device completed SSL handshake with client outside:sourceIP/57225
Feb 05 2010 12:03:40: %ASA-6-725007: SSL session with client outside:sourceIP/57225 terminated.
Feb 05 2010 12:03:40: %ASA-6-302013: Built inbound TCP connection 18867 for outside:sourceIP/57226 (sourceIP/57226) to identity:destinationIP/443
Feb 05 2010 12:03:40: %ASA-6-302014: Teardown TCP connection 18865 for outside:sourceIP/57225 to identity:destinationIP/443 duration 0:00:00 bytes 126 TCP Reset-I
I have tried changing the port used by using the following:
http server enable 8843
but the issue persists.
If anyone has any ideas on how to fix this issue please advise, because I am all out. I would prefer not to have to roll back either software version as I would like to have them all standardized on the same images, and the combination is working correctly everywhere else.
Many thanks in advance.
1 ACCEPTED SOLUTION
Community Member
Re: ASDM issues
Verify your asdm-image. It looks too small...
Br Jimmy.
http://blogg.kvistofta.nu
Re: ASDM issues
Hi Gatling
Do you say, it works 98/100 times, and just times out rarely ? or it doesnt work at all ?
Raj
Re: ASDM issues
what do
sh run ssl
and
sh run | i VPN-
say?
ASA# sh ver | i VPN-
VPN-DES                      : Enabled
VPN-3DES-AES                 : Enabled
ASA# sh run ssl
ssl encryption aes128-sha1 3des-sha1
Does it say the above?
-KS
Community Member
Re: ASDM issues
Br Jimmy.
Community Member
Re: ASDM issues
Thanks for all the replies.
Raj, I meant it works on 98/100 firewalls (99/100 now as I resolved the issue on another), but it never loads on this firewall.
KS, I don't see "ssl encryption aes128-sha1 3des-sha1" under sh run ssl.. but I'm not sure this is required as Br Jimmy is spot on the money with the ASDM image size. Surprised I didn't notice that myself..
Thanks again for the help, much appreciated.
Chris
Re: ASDM issues
Hi Chris
Did you try re-installing your ASDM file  ?
The asdm-615 bin file is almost 7 MB (7598456 bytes)
Cisco Adaptive Security Device Manager for ASA 8.0(2), 8.0(3), 8.0(4), 8.1(1) and 8.1(2).
You also have the the new version ASDM 6.2.5
asdm-625.bin
Release Date: 11/Jan/2010
Cisco Adaptive Security Device Manager for ASA 8.0, 8.1 and 8.2.
Size: 11584.20 KB  (11862220 bytes)
Check the appropriate ASDM image and you can install and check if it works good.
Hope this helps.. all the best
Raj
1319
