ASDM Launcher starts in a small window
When I launch the ASDM, whether in JAVA or as an MSI installation, the window starts "too small".  I can't see anything but the minimize and close button.  (see the attached screenshot)
I am running Java v1.4.2_03.  I tried the most current release of Java and it had same results, so I uninstalled it and am back on 1.4.2_03.
...any ideas?
-Kevin
Everyone's tags (3)
Did you ever find a solution to this problem?  I am experiencing the same thing and can't figure it out.  ASDM starts in a tiny windows that I can only minimize or close.
Red
Hi Eric,
Kindfly provide the below information:
version of ASDM that you are running
version of ASA software
which OS are you using
Is it a 64-bit or 32-bit OS
This info would be helpful to resolve the issue.
Varun
Thanks, Varun Rao Security Team, Cisco TAC
ASDM Launcher Version is 1.5(50)
ASDM Version is 6.3(5)
ASA version 8.3(2)
Windows 7
64-bit
Works fine on other Windows XP and Windows 7 - 32-bit computers I have.
Red
Hi Eric,
It seems to be  ajava compatibility issue, try installing the 32-bit java version on your 64-bit machine, and then try he asdm. One more thing, on the 64-bit, open up a browser and type the url "https:// (you should be able to access the asdm.
Hope this helps
Varun
The above answer is the right one
1910
