ASDM Upgrade Issues
I am trying to upgrade ASDM? Having issues upgrading ASDM image. I am connected to TFTP server and it has the ASDM image.
when i run command copy tftp disk0:
specify ipaddress and bin file process starts than i get an error message "md5(0xe369c14f 0x3fa969b4 0xdef65c91 0xfc3e7cb4)
Failed to verify ASDM file hash"
Is there a solution to resolve this?
ALI
TEKMARK GLOBAL SOLUTIONS
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: ASDM Upgrade Issues
Ali
It sounds like there is a problem with the ASDM file on your TFTP server. Is it possible that there was a problem in copying the file when it loaded onto your TFTP server?
I would suggest that you go back and get a new copy of the ASDM file from Cisco to load on your TFTP server. Then try loading the new file to the disk0.
Rick
1 REPLY
Ali
Rick
235
