ASDM versions and ASA images
if i have 2 ASA to manage, one runnig version 7.2 and the other 8.0.4 , can i manage them with the same ASDM on the same PC ? which version ?
1 REPLY
Re: ASDM versions and ASA images
Joseph,
You will need to install both versions of ASDM. The newest version will let you know that when you try to connect to your 7.2 device.
Hope this helps!
229
