ASDM wont load
Trying to load ASDM on a new ASA5550. I've done so far the stuff which is listed in the manual. Settings posted are default.
I can ping the ASA.
Plugged to the Managamenet0/0:
interface Management0/0
nameif management
security-level 100
management-only
http server enable
http 192.168.1.0 255.255.255.0 management
And my management PC also get an IP in this range.
It still looks that a HTTPS request is blocked or something by the ASA.
AES/DES Licence looks also good.
And the file is located on the disk:
asdm image disk0:/asdm-613.bin
Any idea why my ASDM wont load? (its not the browser or java)
Re: ASDM wont load
Try ASDM 6.1.5(57)
Re: ASDM wont load
The first problem was more my own dumbness, i had set a proxy in my browser...
but upgrading to the new version solved the problem i had as next :)
Re: ASDM wont load
Glad to be of assistance.
Re: ASDM wont load
also keeping your java at release 6 update 7 will let it work with older versions of the ASDM if upgrading isn't possible.
196
