Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Attack to interface outside ASA 5510
Hi, We are to pain very attack of DoS.
We want to know:
1. If we can see in the ASA which IP's and the percentage of total bandwidth usage in real time
2. or a software of Cisco or third to this.
1 REPLY
Re: Attack to interface outside ASA 5510
Also about the bandwidth utilisation unfortunately that cant be found out on Pix/ASA
It is not possible to check with the bandwidth using syslogs at all. However, if the
bandwidth drops to 0 the Pix/ASA would report an error in syslog with the ID: 613002 and for
this you need to enable logging to level 6 (informational).
However, on PDM, it would show the system resources as well as the traffic passing
through the Pix/ASA.
I do understand that it is difficult to interpret the the output of syslogs as it always
would be huge and a bit confusing but there is no way out and just to copy them on a
notepad/wordpad and with the help of search can check with any ip address or any other
string. However, you can use some 3rd party softwares and refine the search based on ip
addresses or any other paramenters which are predifined on the softwares and it would
return you a clean output of the thing you are looking for. Below are the two links for
two different softwares.
1)
http://www.reportgen.com/index.htm
2)
http://www.wingrep.com/download.html
For this kind of reporting, you will need to
have a software with reporting capability. The following are options for
you:
Cisco Products:
CS-MARS -
http://www.cisco.com/en/US/products/ps6241/products_user_guide_chapter09186a
00804f1622.html
Monitoring Center for Performance (MCP)
http://www.cisco.com/en/US/products/sw/cscowork/ps5387/products_qanda_item09
186a00801d2f47.shtml
Some other third party products:
Network Intelligence Engine from Network Intelligence
(http://www.network-intelligence.com)
Network Security Analyzer and FirewallAnalyzer Enterprise from eIQnetworks
(http://www.eiqnetworks.com)
Sawmill Log Analyzer from FlowerFire
(http://www.sawmill.net)
These are just some to name. You can do a search on Google for other
applications.
132
