Auto NAT and outside pool ip address
Hi Everyone,
If i do Auto NAT  from DMZ  interface to outside  interface using config below
object network Auto_NAT
subnet 192.168.70.0 255.255.255.0                           *********************DMZ  subnet
description Auto NAT  DMZ Interface
object network Outside_pool
range 192.168.51.3 192.168.51.100
nat (DMZ,outside) dynamic Outside_pool
My outside interface has IP  of 192.168.71.2
I am unable to access the internet using above config
when i change the range in outside_pool  to 192.168.71.3 192.168.71.100  i am able to access the internet.
Does this mean that using auto nat using dynamic NAT  the outside pool range should be in same subnet as outside interface  ip address?
MAhesh
13 ACCEPTED SOLUTIONS
Super Bronze
Hi Mahesh,
The NAT Pool doesnt have to be the same network as the "outside" interfaces network.
But in that case you have to make sure that the router infront of the ASA knows about this NAT Pool network.
The router either needs
  • A route for the network used as the NAT Pool pointing towards the current "outside" interface IP address of the ASA
  • OR the router interface facing ASA needs an "secondary" address configured in the network that includes the NAT Pool used
    • In this case you also need the command "arp permit-nonconnected" enabled on the ASA
- Jouni
Re: Auto NAT and outside pool ip address
Hello Mahesh,
No it does not,
That behavior let us know that there is an ARP issue with those IP addresses,
Does the ISP side know that you have that range of IP addresses 192.168.51.x.
Also what version are you running as Proxy-ARP is disabled in some versions (8.4.3 and 8.6 if I am not wrong ) so the ASA will not proxy-arp for IP addresses not connected or on the same subnet than the ASA.
Check my blog at http:laguiadelnetworking.com for further information.
Cheers,
Julio Carvajal Segura
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
The command that jounni recommend (arp permit non-connected) is available on that version
Cheers,
Julio Carvajal
Hello Mahesh,
The configuration on the ASA should remain the same.
On the Upstream device it should be:
no ip route 192.168.72.0 255.255.255.0 192.168.71.2
ip route 192.168.51.0 255.255.255.0 192.168.71.2
Cheers,
Julio Carvajal
Hello Mahesh,
Okey,
Please share both the config from L3 switch and ASA at the moment,
I will need to analize the configuration
Cheers,
Julio Carvajal
Looks like we are receiving a Reset pacekt from the device on the lower security level.
The Deny TCP no connection could mean 2 things
1)Asymetric routing
2) Server is sending information after the connection was released on the ASA
Cheers,
Julio Carvajal
Hello Mahesh,
But I mean that traffic is on the same subnet, I mean 70.3 to 70.1...
Can you share the configuration please Or you can email me the setup
Cheers,
Julio Carvajal
Hello Mahesh,
Configuration looks good ( I did not see something wrong)
Add
fixup protocol icmp
cap capin interface inside match icmp any any eq 4.2.2.2
cap capout interface outside match icmp any any eq 4.2.2.2
Then ping from an inside PC to 4.2.2.2
and provide
show cap capin
show cap capout
Cheers,
Julio Carvajal
Hello Mahesh,
I must have been really tired when I send the capture syntax lol. It's completely wrong.
It should be
cap capdmz interface dmz match icmp any host 4.2.2.2
cap capout interface outside match icmp any host 4.2.2.2
I am sorry
Cheers,
Julio Carvajal
There are no packets comming back from the Switch.
Add the following to the ASA
Can you share the show ip route from the Switch (I just need the entry for the 192.168.72.0)
also show arp | include 192.168.72.
Cheers,
Julio Carvajal
Hello.
Do the following on the ASA side
arp permit non-connected and then try again
Cheers,
Julio Carvajal
At the moment, the only thing that I could possibly think of is make sure that the router 192.168.5.3 has a route to the 192.168.72 subnet and that it's  also Natting this Subnet range
Cheers,
Julio Carvajal
Hello Mahesh,
Well basically:
  • The ASA had the right configuration (we could see the packets going out to the outside interface)
  • We make sure the ASA reply to ARP packets not on the same subnet that it's interfaces (arp permit non-conected)
  • We make sure the Switch knew how to get to the subnet being used by the DMZ
  • I check the switch to see if the NAT was being done there but that was not the case so only 2 options more :A-the device doing the NAT does not include the subnet used by the DMZ.B- The device on the edge of the network does not know how to get to that subnet on the DMZ.
Long troubleshooting Mahesh But we did it.
Cheers,
Julio Carvajal
Super Bronze
Hi Mahesh,
- Jouni
Hi Julio,
Something new learn today .
I will test that tomorrow.
Best regards
MAhesh
Hello Mahesh,
No it does not,
Cheers,
Julio Carvajal
Hi Julio,
IOS  is
Cisco Adaptive Security Appliance Software Version 9.1(1)
Device Manager Version 7.1(2)
I will test it tomorrow after work
MAhesh
Cheers,
Julio Carvajal
Hi jouni,
I config the Outside pool ip which was not from the outside interface of ASA.
Also on Switch which has direct connection to ASA outside interface ip i config command
3550SMIA(config)#ip route 192.168.72.0 255.255.255.0 192.168.71.2
where 192.168.71.2 is ASA outside interface ip.
Now i can not access the internet.
ciscoasa# sh xlate
1 in use, 3 most used
Flags: D - DNS, e - extended, I - identity, i - dynamic, r - portmap,
       s - static, T - twice, N - net-to-net
NAT from DMZ:192.168.70.3 to outside:192.168.72.56 flags i idle 0:00:00 timeout 3:00:00
Mahesh
Hello Mahesh,
Cheers,
Julio Carvajal
Hi Julio,
I change the outside_pool ip to subnet 192.168.72.0
object network Auto_NAT_DMZ
range 192.168.72.3 192.168.72.100
MAhesh
Hello Mahesh,
Okey.
And what happens, same thing?
Cheers,
Julio Carvajal
Yea samething no internet from pc
but from asa i can ping internet
Hello Mahesh,
Okey,
Cheers,
Julio Carvajal
Hi Julio,
Here is log from ASA
Aug 15 2013 22:09:08: %ASA-6-302014: Teardown TCP connection 8398 for DMZ:192.168.70.3/5703 to identity:192.168.70.1/443 duration 0:00:00 bytes 3619 TCP Reset-O
Aug 15 2013 22:09:08: %ASA-6-106015: Deny TCP (no connection) from 192.168.70.3/5703 to 192.168.70.1/443 flags FIN ACK  on interface D
Config is attached with original post.
Mahesh
1)Asymetric routing
Cheers,
Julio Carvajal
Hi Julio,
As per this message seems its natting issue
Aug 15 2013 22:11:59: %ASA-6-110003: Routing failed to locate next hop for TCP from identity:192.168.70.1/443 to DMZ:192.168.70.3/5712
where 70.3  is pc ip
70.1  is DMZ  interface
mahesh
Hello Mahesh,
Cheers,
Julio Carvajal
Hi Julio,
config is atatched under the original post.
Mahesh
Hello Mahesh,
Add
fixup protocol icmp
and provide
show cap capin
show cap capout
Cheers,
Julio Carvajal
Hi Julio,
I will test that later today and will update you.
Yesterday i ran the packet capture when i did ping to 4.2.2.2    and  i did show packet for inside  interface it was 0 packets
but outside interface  was showing some output.
I will do again today after putting the command fixup protocol icmp.
Mahesh
Hello Mahesh,
Then it would be a problem with the LAN as the traffic is not reaching the ASA, make sure the computers have the right default gateway.
Note: we are testing from a 10.x.x.x host right?
Let us know any update
Cheers,
Julio Carvajal
Hi Julio,
Below command does not work
ap capture  interface  DMZ match  icmp  any any  eq 4.2.2.2
ERROR: % Invalid Hostname
Also i am behind the DMZ  subnet  192.168.70.x
Also here is more info
ciscoasa# debug icmp trace
debug icmp trace enabled at level 1
ciscoasa# ICMP echo request from DMZ:192.168.70.4 to outside:4.2.2.2 ID=1 seq=17
len=32
ICMP echo request translating DMZ:192.168.70.4 to outside:192.168.72.63
ICMP echo request from DMZ:192.168.70.4 to outside:4.2.2.2 ID=1 seq=18 len=32
ICMP echo request from DMZ:192.168.70.4 to outside:4.2.2.2 ID=1 seq=19 len=32
ICMP echo request from DMZ:192.168.70.4 to outside:4.2.2.2 ID=1 seq=20 len=32
ICMP echo request from DMZ:192.168.70.4 to outside:4.2.2.2 ID=1 seq=21 len=32
ICMP echo request from DMZ:192.168.70.4 to outside:4.2.2.2 ID=1 seq=22 len=32
ICMP echo request from DMZ:192.168.70.4 to outside:4.2.2.2 ID=1 seq=23 len=32
ICMP echo request from DMZ:192.168.70.4 to outside:4.2.2.2 ID=1 seq=24 len=32
Where 192.168.70.4  is PC  IP
Mahesh
Hello Mahesh,
It should be
I am sorry
Cheers,
Julio Carvajal
Hi  Julio,
Thanks  for replying back
ciscoasa# sh cap capdmz
4 packets captured
   1: 23:36:38.000350       802.1Q vlan#3 P0 192.168.70.6 > 4.2.2.2: icmp: echo
request
   2: 23:36:42.849779       802.1Q vlan#3 P0 192.168.70.6 > 4.2.2.2: icmp: echo
request
   3: 23:36:47.841860       802.1Q vlan#3 P0 192.168.70.6 > 4.2.2.2: icmp: echo
request
   4: 23:36:52.849428       802.1Q vlan#3 P0 192.168.70.6 > 4.2.2.2: icmp: echo
request
4 packets shown
ciscoasa# sh cap capout
36 packets captured
   1: 22:03:42.616057       802.1Q vlan#1 P0 192.168.72.56 > 4.2.2.2: icmp: echo
request
   2: 22:03:47.348538       802.1Q vlan#1 P0 192.168.72.56 > 4.2.2.2: icmp: echo
request
   3: 22:03:52.340741       802.1Q vlan#1 P0 192.168.72.56 > 4.2.2.2: icmp: echo
request
   4: 22:03:57.348233       802.1Q vlan#1 P0 192.168.72.56 > 4.2.2.2: icmp: echo
request
   5: 22:06:25.034544       802.1Q vlan#1 P0 192.168.72.56 > 4.2.2.2: icmp: echo
request
   6: 22:06:29.839144       802.1Q vlan#1 P0 192.168.72.56 > 4.2.2.2: icmp: echo
request
   7: 22:06:34.846864       802.1Q vlan#1 P0 192.168.72.56 > 4.2.2.2: icmp: echo
request
   8: 22:06:39.838854       802.1Q vlan#1 P0 192.168.72.56 > 4.2.2.2: icmp: echo
request
   9: 22:08:08.405313       802.1Q vlan#1 P0 192.168.72.56 > 4.2.2.2: icmp: echo
request
  10: 22:08:13.345929       802.1Q vlan#1 P0 192.168.72.56 > 4.2.2.2: icmp: echo
request
  11: 22:08:18.337842       802.1Q vlan#1 P0 192.168.72.56 > 4.2.2.2: icmp: echo
request
  12: 22:08:23.345486       802.1Q vlan#1 P0 192.168.72.56 > 4.2.2.2: icmp: echo
request
  13: 22:08:28.337491       802.1Q vlan#1 P0 192.168.72.56 > 4.2.2.2: icmp: echo
request
  14: 22:51:16.824237       802.1Q vlan#1 P0 192.168.72.56 > 4.2.2.2: icmp: echo
request
  15: 22:51:21.333799       802.1Q vlan#1 P0 192.168.72.56 > 4.2.2.2: icmp: echo
request
  16: 22:51:26.333066       802.1Q vlan#1 P0 192.168.72.56 > 4.2.2.2: icmp: echo
request
  17: 22:51:31.334409       802.1Q vlan#1 P0 192.168.72.56 > 4.2.2.2: icmp: echo
request
  18: 22:52:32.936276       802.1Q vlan#1 P0 192.168.72.56 > 4.2.2.2: icmp: echo
request
  19: 22:52:37.844743       802.1Q vlan#1 P0 192.168.72.56 > 4.2.2.2: icmp: echo
request
  20: 22:52:42.834734       802.1Q vlan#1 P0 192.168.72.56 > 4.2.2.2: icmp: echo
request
  21: 22:52:47.834185       802.1Q vlan#1 P0 192.168.72.56 > 4.2.2.2: icmp: echo
request
  22: 22:52:52.834307       802.1Q vlan#1 P0 192.168.72.56 > 4.2.2.2: icmp: echo
request
  23: 22:52:57.834643       802.1Q vlan#1 P0 192.168.72.56 > 4.2.2.2: icmp: echo
request
  24: 22:53:02.834917       802.1Q vlan#1 P0 192.168.72.56 > 4.2.2.2: icmp: echo
request
  25: 22:53:07.834246       802.1Q vlan#1 P0 192.168.72.56 > 4.2.2.2: icmp: echo
request
  26: 22:53:12.834536       802.1Q vlan#1 P0 192.168.72.56 > 4.2.2.2: icmp: echo
request
  27: 22:53:17.845979       802.1Q vlan#1 P0 192.168.72.56 > 4.2.2.2: icmp: echo
request
  28: 22:53:22.834154       802.1Q vlan#1 P0 192.168.72.56 > 4.2.2.2: icmp: echo
request
  29: 22:53:27.834475       802.1Q vlan#1 P0 192.168.72.56 > 4.2.2.2: icmp: echo
request
  30: 22:53:32.834780       802.1Q vlan#1 P0 192.168.72.56 > 4.2.2.2: icmp: echo
request
  31: 22:53:37.834078       802.1Q vlan#1 P0 192.168.72.56 > 4.2.2.2: icmp: echo
request
  32: 22:53:42.833422       802.1Q vlan#1 P0 192.168.72.56 > 4.2.2.2: icmp: echo
request
  33: 23:36:38.000671       802.1Q vlan#1 P0 192.168.72.73 > 4.2.2.2: icmp: echo
request
  34: 23:36:42.850084       802.1Q vlan#1 P0 192.168.72.73 > 4.2.2.2: icmp: echo
request
  35: 23:36:47.842104       802.1Q vlan#1 P0 192.168.72.73 > 4.2.2.2: icmp: echo
request
  36: 23:36:52.849733       802.1Q vlan#1 P0 192.168.72.73 > 4.2.2.2: icmp: echo
request
36 packets shown
ciscoasa#
Mahesh
Cheers,
Julio Carvajal
Hi Julio,
Here is info
3550SMIA#show arp | include 192.168.72.56
3550SMIA#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 192.168.5.3 to network 0.0.0.0
S    192.168.72.0/24 [1/0] via 192.168.71.2
     100.0.0.0/32 is subnetted, 1 subnets
O       100.100.100.100 [110/3] via 192.168.5.3, 5d02h, FastEthernet0/11
     3.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
O       3.3.3.3/32 [110/2] via 192.168.5.3, 5d02h, FastEthernet0/11
C       3.4.4.0/24 is directly connected, Loopback0
C    192.168.30.0/24 is directly connected, Vlan30
     64.0.0.0/32 is subnetted, 1 subnets
O E2    64.59.135.150 [110/300] via 192.168.5.3, 5d02h, FastEthernet0/11
S    192.168.77.0/24 [1/0] via 192.168.10.2
C    192.168.10.0/24 is directly connected, Vlan10
     172.31.0.0/24 is subnetted, 4 subnets
O E2    172.31.3.0 [110/300] via 192.168.5.3, 5d02h, FastEthernet0/11
O E2    172.31.2.0 [110/300] via 192.168.5.3, 5d02h, FastEthernet0/11
O E2    172.31.1.0 [110/300] via 192.168.5.3, 5d02h, FastEthernet0/11
O E2    172.31.0.0 [110/300] via 192.168.5.3, 5d02h, FastEthernet0/11
O    192.168.98.0/24 [110/2] via 192.168.99.1, 5d02h, FastEthernet0/8
C    192.168.99.0/24 is directly connected, FastEthernet0/8
C    192.168.20.0/24 is directly connected, Vlan20
     192.168.5.0/31 is subnetted, 1 subnets
C       192.168.5.2 is directly connected, FastEthernet0/11
     192.168.6.0/31 is subnetted, 1 subnets
O       192.168.6.2 [110/2] via 192.168.5.3, 5d02h, FastEthernet0/11
S    192.168.69.0/24 [1/0] via 192.168.10.2
C    192.168.71.0/24 is directly connected, FastEthernet0/22
O*E2 0.0.0.0/0 [110/1] via 192.168.5.3, 5d02h, FastEthernet0/11
3550SMIA#
MAhesh
Hello.
Cheers,
Julio Carvajal
No luck
Cheers,
Julio Carvajal
Hi Julio,
Seems adding static route did the magic to the router
2691Router(config)#ip route 192.168.72.0 255.255.255.0 192.168.5.2
2691Router(config)#end
2691Router#
Now i can access the internet from pc and also ping works fine.
Can you tell how adding route to router made the difference?
MAhesh
Hello Mahesh,
Well basically:
Cheers,
Julio Carvajal
701
