AVAYA voice problem via VPN
A client is trying to test voice over IP connectivity between 2 Avaya PBX's in 2 different branches.
IPSEC 3DES VPN is configured between the 2 branches, HO has an ASA5510 and branch has a PIX515 (version 6.2)
Full IP connectivity between the 2 sites is configured and tested.
The problem is that the AVAYA PBX in the HO (ASA) is able to call and talk to the other pbx in the branch(PIX), but when initiating the call from the branch,
the call setup is not working, and he gets directly a busy tone.
I tried to remove all the inspections on both firewall, but still had the same problem
Re: AVAYA voice problem via VPN
Can you post your fixup portion configs from the PIX?
John
HTH, John *** Please rate all useful posts ***
fixup protocol dns maximum-length 512
fixup protocol ftp 21
no fixup protocol h323 h225 1720
no fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
no fixup protocol sip 5060
no fixup protocol sip udp 5060
no fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
Note that i removed all the FIXUPs while doing the test and the problem was not solved.
Best regards,
Maybe this can point you in the right direction:
http://www.avaya.com/master-usa/en-us/resource/assets/applicationnotes/vpnphon_pix.pdf
John
Dar Jhon,
thank you for your reply,
But this is not the scenario that I have as
the voice packets are passing between two branches in IPSEC VPN tunnel terminated one side on a PIX and the other side on an ASA.
So it is a remote Access VPN where the AVAYA IP Phone connected via internet to the pix.
Best regards,
Is your phone switch on the ASA side or the PIX side? Is the phone on the PIX side?
Its not just 1 phone
In the HO(behind the ASA), their is an AVAYA PBX and in the branch (behind the PIX) their is an IP office(some kind of small pbx)
264
