Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Bandwidth Management on ASA 9.1
Hi All,
could you help me, i need configure cisco asa QOS and the rule like below :
i have 3 subnet behind the asa and i need configure QOS with rule like 1 subnet i give 50% bandwidht and 2 subnet i give 25 % each. but if the traffic to internet is empty each subnet can used 100 % bandwidth .
VIP Purple
That's not possible with the
That's not possible with the ASA. The QoS features on the ASA are very limited. Do you have control over the WAN-router in front of the firewall? If that's an IOS router it will be possible.
Hi Karsten, Ok thanks for
Hi Karsten,
Ok thanks for your explanation
if you can define time range
if you can define time range for example from 9-00 till 12-00 when traffic is maximum so you configure time range based  QOS with rule like 1 subnet  give 50% bandwidht and 2 subnet i give 25 % each
in another time it will not work
another option is executing script on some server or router
here is example how to execute eem script on 3750 and ssh to asa
https://supportforums.cisco.com/discussion/12292956/eem-ssh-asa-and-issue-commands
and dont forget to rate post
159
