Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
bandwidth monitoring Forensics
Looking for a command line tool that can show which IP is utilizing most of the bandwidth
I have PRTG running and monitoring the outside interface.
When it spikes to 15 Mbps and sustains for over 10 minutes I get an email. Next step is trying to narrow down who the offenders are
Re: bandwidth monitoring Forensics
If you have the ASA5580 you can use Netflow. I believe the ASDM monitor will show you the info as well (on any model). I don't use ASDM so I'm not 100% sure where to look.
Hope that helps.
Community Member
I'm running 5520 and it does not support netflow
I'm already monitoring the internal interface VLAN with netflow and getting some info
I would like to know if there are any ASA built in commands that would display activity
I'm aware of the show conn but looking for something more specific
Thanks for your input
Not that I've ever heard of. I recently found a product that connects to the ASA and provides the info you're looking for.
Community Member
This is great thanks a lot
