Basic ASA 5505 Transparent Mode
As a begineer in ASA, I'm trying to configure a 5505 to allow 3 hosts to access 4 servers in different routed networks. The 3 hosts are on the same vlan so I would think transparent firewall would work for this. The example below is from Config notes and I can't seem to define nameif as outside/inside on the two E0/0 or E0/1 interfaces.
The Error is: only vlan interface can be defined nameif.
Using 7.2 code and using base ASA 5505.
I must be missing something real simple ;-))). Any example of a tranparent mode config would be great!
ciscoasa#show running-config
: Saved
ASA Version 8.0(2)
!--- In order to set the firewall mode to transparent mode
firewall transparent
hostname ciscoasa
enable password xxx
names
interface Ethernet0/0
nameif outside
security-level 0
interface Ethernet0/1
nameif inside
security-level 100
interface Ethernet0/2
shutdown
no nameif
no security-level
interface Ethernet0/3
shutdown
no nameif
no security-level
interface Management0/0
shutdown
no nameif
no security-level
management-only
passwd xxx
ftp mode passive
pager lines 24
mtu outside 1500
mtu inside 1500
!--- IP Address for the Management.
!--- Avoid using this IP Address as a default gateway.
!--- The security appliance uses this address as the source address
!--- for traffic originating on the security appliance, such as system
!--- messages or communications with AAA servers. You can also use this
!--- address for remote management access.
no failover
icmp unreachable rate-limit 1 burst-size 1
!--- Output Suppressed
service-policy global_policy global
prompt hostname context
Cryptochecksum:xxx
: end
ciscoasa(config)#
Re: Basic ASA 5505 Transparent Mode
Hi, try this ..
interface Vlan10
nameif inside
security-level 100
interface Vlan20
nameif outside
security-level 0
switchport access vlan 20
no shut
switchport access vlan 10
no shut
yep- it was simple
now if my extended access list will just work
I do have extra question.
5505 does not accept nameif for the ethernet port and we have to use vlan for nameif.  There will be at least two vlan, each for one interface inside and outside. I have to provide to configure two subnets, one for each VLAN. Then, is this really transparent. With 5510 and higher it is possible to use single network for both interfaces, but not with 5505. Any suggestions?
3720
