basic nat not working
I am trying to set up a basic configuration and cant figure out why nat is not working.
my  outside vlan 2 ping public ip address
my inside  vlan 1 does not ping anything public ,
i have
nat (inside) 1 192.168.1.0 255.255.255.0
global (outside) 1 interface
not sure why it does not work. do I need acls?
Pleaes see my config attached
Everyone's tags (2)
1 ACCEPTED SOLUTION
Hello Alex,
Thanks for letting us know the solution
Please mark the question as answered so future users can learn from the same issue you had.
Julio
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
Super Bronze
Please add inspect icmp:
policy-map global_policy
class inspection_default
     inspect icmp
Hi Jennifer thank you
my that did not fix my issue.  I can ping my inside hosts from the ASA without specifying an interface and I can ping public ip addresses without specifying an interface
It appears my internal hosts cant reach the internet ,  if i try to ping 208.67.222.222( public dns) from my internal host 192.168.1.20,( server,)  i get no response.
any ideas?
Hello Alex,
Can you provide us the Ipconfig from your PC.
As Jennifer stated you were missing the ICMP stateful inspection, now that you have it you should be able to ping it.
Also provide us the following:
packet-tracer input inside icmp 192.168.1.20 8 0 4.2.2.2
Also add the following capture
capture asp type asp-drop all
Then try to ping from your PC  to 4.2.2.2 and finally provide us the output of :
show capture asp | include 4.2.2.2
Julio
Security Engineer
Do rate all the helpful posts
Hi Julio ,t hanks for responding,  attached is my  packet-tracert configuration
packet tracert output
packet-tracer input  inside icmp 192.168.1.20 8 0 4.2.2$
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Found no matching flow, creating a new flow
Phase: 3
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   0.0.0.0         0.0.0.0         outside
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
class-map inspection_default
match default-inspection-traffic
  inspect icmp
service-policy global_policy global
Phase: 6
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 7
Type: NAT
Subtype:
Result: ALLOW
Config:
  match ip inside 192.168.1.0 255.255.255.0 outside any
    dynamic translation to pool 1 ( [Interface PAT])
    translate_hits = 1, untranslate_hits = 0
Dynamic translate 192.168.1.20/0 to /4 using netmask 255.255.255.255
Phase: 8
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
  match ip inside 192.168.1.0 255.255.255.0 inside any
    dynamic translation to pool 1 (No matching global)
    translate_hits = 0, untranslate_hits = 0
( is this  the issue here?)
Phase: 9
Type: HOST-LIMIT
Subtype:
Result: ALLOW
Config:
Phase: 10
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 11
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 71, packet dispatched to next module
Phase: 12
Type: ROUTE-LOOKUP
Subtype: output and adjacency
Result: ALLOW
Config:
found next-hop using egress ifc outside
adjacency Active
next-hop mac address 0026.f324.ba24 hits 294
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: allow
Here is my show nat
show nat
NAT policies on Interface inside:
  match ip inside 192.168.1.0 255.255.255.0 _internal_loopback any
THe ipconfig on my linux server is
192.168.1.20
255.255.255.0
192.168.1.1 (cisco asa)
dns 208.67.222.222
Hello Alex,
As you marked on the packet tracer that is the issue, there is no translation for those packets..
You are running a very old version but I have not see any bugs related to the ASA to apply the proper translation when the protocol its ICMP...
Is it possible that you could do a hard reload, if this does not solve it I will look into our database for a bug or something related to this odd behavior,
Julio
Rate all the helpful posts
Hi All - thanks for responding,  i fixed the issue by upgrading to asa843.   I then configured nat with the following an d poof! it worke.
object network  obj-
nat (inside,outside) dynamic interface
Hello Alex,
Julio
Thanks Julio - i do need help with acl issue, if you can take a look at that, i would appreciat it. Its a new thread,
Upgrade the asdm image too.
1089
