Basic natting ( or no natting) question
I have a 515 running 6.3.3 with a DMZ. I am having some problems understanding the natting for the DMZ. Basically I have an internal network (10.0.0.0/8), DMZ (172.18.5.0/24), and outside (0.0.0.0/0)
I would like a DMZ server to be able to address the internal server with the 10.0.0.0 address without a nat. Basically I would like the DMZ to know the real addresses of the inside, and the inside to know about the real addresses of the outside. I would also still be needing to keep the dmz servers statically natted to the outside of course. Am I missing something, or do I just need two nat 0 statements? After that I should just be able to create ACLs for lower security interfaces to get to higher...
I am still getting the no translation messages...
  • Firewalling
Re: Basic natting ( or no natting) question
I think it should be something like the following.
static (inside,dmz) 172.18.5.0 172.18.5.0 netmask 255.255.255.0
Silver
Use the static command to translate the dmz and inside address to itself. Leave your static for the dmz to outside.
static (internal-interface, external) global-ip local-ip netmask MASK
static (dmz, inside) 172.18.5.0 172.18.5.0 netmask 255.255.255.0
static (inside, dmz) 10.0.0.0 10.0.0.0 netmask 255.0.0.0
Chad
Please rate if this helps!
107
