Best ddos protection for UDP(gameserver)
Hello ,
I need ddos protection for gameserver with port UDP
and i hope it's under 400 or little
thanks
Hall of Fame Super Gold
"400" of what?   Lines of
"400" of what?
Lines of code?  Bitcoins?  Swiss francs?  Steam credits?
400$ price of firewall
Try e-bay for used ASA 5505
Try e-bay for used ASA 5505 or PIX.
The problem you're going to find is the lack of supported firmware and warranty.
Thanks for replying can this
Thanks for replying
can this stop 500gbs attack ?
500 Gbps DDoS amplification
500 Gbps DDoS amplification attack?  No.  Not for < $400.
Besides, are you saying you're willing to spend less than $400 to stop a 500 Gbps DDoS attack?
ASA 5505 can handle 10gbs?
No, not even close.
You really need to think about it:  You want to stop a DDoS on your 10 Gbps link and you're going to spend only <$400.
If you have the funds to pay for a dedicated 10 Gbps link then a firewall that will support this speed is worth more than $400.
how much that can stop 500gb
how much that can stop 500gb attack?
Do you have any idea how much
Do you have any idea how much a 500 Gbps bandwidth cost?
No how much ?
No how much ?
I think you're just trolling.
I will therefore stop responding to your posts.
No i am not i am talking for
No i am not i am talking for real !
ASA Can stop http://www.boothard.com/ ?
318
