Better to use static translations with or without port address?
I'm creating statics like:
static (dmz,outside) public dmz mask
I thought I would just open the ports in the acl, but I know I can do something like:
static (dmz,outside) public ip 80 dmz ip 80 netmask
Is this the "better" way of doing it, or does it really matter?
John
HTH, John *** Please rate all useful posts ***
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: Better to use static translations with or without port addre
John
Others may differ but i only use ports in the static statement when i am doing port forwarding ie. using the same public IP to forward to multiple private IP addresses on different ports.
Otherwise i just use a static and tie down the access with acl entries. NAT should not really be relied upon for security.
Jon
John
Jon
Okay, that's what I'm doing. I have a single public address that's forwarding on different ports to different hosts (some in dmz and some on the inside). I've had to use port translation on those.
Thanks Jon!
John
107
