Broken link for PDM Configuration Guide - Please HELP!
When I click on the link titled "Configuring PDM" of the PDF document "Cisco PDM Installation and Configuration Guide for Firewall Services Module Version 4.1" (http://www.cisco.com/en/US/docs/security/fwsm/fwsm23/pdm41/configuration/guide/pdm_ig.html)ç
I just get a broken link error message. All of the other links on that page are working.
Can anyone tell me another URL with that broken link working?
Thanks in advance.
Sergio.
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: Broken link for PDM Configuration Guide - Please HELP!
Sergio
Ok i understand now :).
That link doesn't work for me either. However attached is the link for the same chapter with version 4.0 of PDM. I know that you are loading v4.1 but there should not be any major differences between the two.
http://www.cisco.com/en/US/docs/security/fwsm/fwsm22/pdm40/configuration/guide/pdm40CH4.html
Jon
Hi Sergio
Not quite sure why link doesn't work as it seems to work fine for me. I have attached a link to one of the chapters in this doc - see if that helps.
http://www.cisco.com/en/US/docs/security/fwsm/fwsm23/pdm41/configuration/guide/pdm40pf.html
Jon
Hi Jon,
The link you are refering to is working right for me. The no working link is the chapter titled "Configuring PDM" on that PDF.
The URL of that chapter is:
http://www.cisco.com/en/US/docs/security/fwsm/fwsm23/pdm41/configuration/guide/pdm40CH4.html
One more time, thanks for your help Jon :)
Sergio.
Sergio
Jon
Thank you so much, Jon.
Sergio.
137
