Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Bypass NAT for single printer IP
Hi all,
I posted a while ago that we were having problems translating an IP for a printer (located here https://supportforums.cisco.com/message/4099013#4099013)
We still haven't been able to get it working and thought about another approach which is to leave the printer IP as a 10.100.x.x IP and instead set up the ASA to bypass the NAT for this IP so it doesn't get translated.
Is this possible and how would i go about doing it?
Many thanks
Jamie
Super Bronze
Would need more information related to this. Are you doing this on an ASA firewall? What software version is it running on? Towards which interface should the printer be visible with its own IP address? Is there only a certain network towards which the printer should show up with its original IP address?
Generally this is configured with NAT0 / Identity NAT but the format depends on your software level if you are using ASA.
- Jouni
Community Member
We are on ASA 5510 8.3+.
We originally tried to translate the printer so anything received on the 10.100.104.20 address would get translated to its 172.29.x.x address but we can't seem to get it working so the other option is to change the printer to 10.100.104.20 and stop this address from the NAT.
Our ASA address is 10.100.104.2 and apparently we have IPs up to .24
MAny thanks
Super Bronze
But I still dont know the actual setup.
Where should the host 10.100.104.20 be visible with its own IP address?
Where are the hosts located which need to be able to connect to this host with its original IP addresses?
If we do the wrong configuration it might override some NAT behaviour that is needed for this host.
For example if we did this configuration then the host would show up towards any other network behind different ASA interface with its own IP address. (If we presume the host is located behind an interface called "inside")
object network PRINTER
host 10.100.104.20
nat (inside,any) 1 source static PRINTER PRINTER
But I would rather know more about the actual setup and current ASA configuration to determine what configuration is needed
- Jouni
Community Member
Its a very strange setup.
We are a school located on a council network. Our admin users use a virtual desktop to login to a council computer which has a printer pointing to the IP address of 10.100.104.20, however this printer is on our site located behind the firewall so isn't accessible as our ASA is setup to NAT all of our 172.29 local ip addresses.
So i believe the printer would be located on the Inside interface and our outside interface is 10.100.104.1/24
Many thanks
Super Bronze
Re: Bypass NAT for single printer IP
If your ASA firewalls "outside" interface is actual connected to some other network and not directly to the Internet then it would seem to me that you could use
host 10.100.104.20
nat (inside,outside) 1 source static PRINTER PRINTER
Though this would indeed mean that the PRINTER would communicate through this interface always with its own IP address which might potentially affect connectivity to the Internet for the PRINTER. That is, if it needs that connectivity.
If this NAT needs to apply only to some destination network behind the "outside" interface then we need to define that network or multiple networks in the "nat" configuration.
In this case we would need to have this kind of configuration
host 10.100.104.20
object network PRINTER-USER-NETWORKS
network-object
network-object
nat (inside,outside) 1 source static PRINTER PRINTER destination static PRINTER-USER-NETWORKS PRINTER-USER-NETWORKS
- Jouni
Community Member
Yes technically we would be on another network outside our ASA.
Just tried the top settings and created a network object but the print still wouldn't come through, as soon as we plug the printer on the network outside of the ASA the print comes through fine!
Pulling my hair out over this!
Super Bronze
I have to say again that its very hard to give any help regarding this matter if we have no idea of the actual setup.
To form any kind of picture of your network setup we would need to see the ASA configurations to determine where the actual networks are located and how the current NAT/ACL configurations have been done.
Also, I am abit confused about the fact that you have placed the Printer behind your ASA but you are using an IP address that according to the above posts are actually located behind the "outside" interface? (the IP address for which you want to do NAT0) This naturally can't work as the traffic would never be forwarded even past the ASA if the actual network is connected to the "outside" interface. In that case there would need to be a Static NAT rather than NAT0 since it seems that the local IP address is something completely different than 10.100.104.20.
We would need to see some configurations and know the network/subnet from which users are trying to connect to the Printer when its behind your ASA.
- Jouni
Community Member
I've managed to get the sh run from the firewall, hopefully this helps.
ASA Version 8.4(4)1
hostname TSTC-FW
enable password  encrypted
passwd encrypted
names
interface Ethernet0/0
nameif outside
security-level 0
ip address 10.100.104.2 255.255.248.0
interface Ethernet0/1
nameif inside
security-level 100
ip address 172.29.8.1 255.255.248.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 0
boot system disk0:/asa845-k8.bin
ftp mode passive
object network any-inside
subnet 0.0.0.0 0.0.0.0
object network TSTC-Printing
host 172.29.8.20
object service tcp_9100
service tcp source eq 9100 destination eq 9100
object network TCSC-Printing
object network TSTCPrint2
host 10.100.104.20
host 10.100.104.20
host 10.100.104.20
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
object-group service DM_INLINE_TCP_1 tcp
port-object eq 52221
port-object eq 52222
port-object eq https
access-list inside_access_in extended permit icmp any any
access-list inside_access_in extended permit ip any any
access-list outside_access_in extended permit icmp any any
access-list outside_access_in extended permit tcp any host 172.29.8.20 eq 9100
access-list outside_access_in remark Form Pearson Exam Software
access-list outside_access_in extended permit tcp host 212.62.15.118 any object-group DM_INLINE_TCP_1
access-list outside_access_in extended permit object tcp_9100 any host 10.100.104.20
pager lines 24
logging enable
logging timestamp
logging monitor informational
logging buffered informational
logging trap informational
logging asdm informational
logging host inside 172.29.10.226 format emblem
mtu outside 1500
mtu inside 1500
mtu management 1500
ip verify reverse-path interface outside
ip verify reverse-path interface inside
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-712.bin
no asdm history enable
arp timeout 14400
nat (inside,outside) source static PRINTER PRINTER
nat (inside,outside) dynamic interface
nat (inside,outside) static 10.100.104.20 service tcp 9100 9100
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
route outside 0.0.0.0 0.0.0.0 10.100.104.1 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication enable console LOCAL
aaa authentication ssh console LOCAL
http server enable 1234
http 192.168.1.0 255.255.255.0 management
http 172.29.8.0 255.255.248.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh 172.29.8.0 255.255.248.0 inside
ssh 192.168.1.0 255.255.255.0 management
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd address 192.168.1.10-192.168.1.20 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
username  password  encrypted privilege 15
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Super Bronze
It seems to me that you have the internal network of 172.29.8.0/21 and the external network is 10.100.104.0/21
Pretty large for a single network/subnet.
So it would seem to me that you are probably looking to do Static NAT for your internal Printer 172.29.8.20 to the NAT IP address 10.100.104.20 ?
If so, do these changes
Remove the original NAT I suggested
no nat (inside,outside) source static PRINTER PRINTER
Go under the below "object" and remove the NAT configuration and add a new one
  no nat (inside,outside) static 10.100.104.20 service tcp 9100 9100
Then just to be sure for testing purposes allow all services to this host with the following ACL addition
access-list outside_access_in permit ip any object TSTC-Printing
Then test the connections. Make sure that the Printer truly has your local IP address 172.29.8.20 on it with the correct default gateway and mask.
- Jouni
Community Member
That is definitely what we were originall trying to do, translate any print jobs sent to 10.100.104.20 to our printer with the IP of 172.29.8.20 but it never seemed to work!
I've added your config to the firewall, what sort of settings should i be putting into the packet tracer to make sure it gets through ok?
Your help is really appreciated, thank you.
Super Bronze
I am not quite sure about the ports used by the Printers. The most common I see should be TCP/515 and TCP/9100 though I am not certain
You could try for example
packet-tracer input outside tcp 10.100.104.100 12345 10.100.104.20 515
and
packet-tracer input outside tcp 10.100.104.100 12345 10.100.104.20 9100
The reason why I used the source address from the same network is that I presume that the requirement was that the network behind the "outside" interface should see these hosts as if they were belonging to the same network as them.
Let us know if it works when you have had the chance to test things out
- Jouni
Community Member
That seems to pass the packet trace fine.
Is there anyway to test that any packet being sent to 10.100.104.20 is infact being translated correctly to 172.29.8.20?
Many thanks
Super Bronze
The NAT we configured above should handle it already. Its Static NAT that binds these IP addresses 1:1.
You can try this command though
show xlate local 172.29.8.20
Hope this helps
- Jouni
Super Bronze
Have you been able to confirm if this works? I guess if the printer replies to ICMP then the easiest way to test general connectivity would be to ICMP from behind the "outside" interface.
But as I said, there should be no problems related to the configurations if you changed the configurations I mentioned.
If the users behind "outside" interface are all part of the 10.100.104.0/21 network then there should be no problems for the traffic to get forwarded to the ASA and then to the Printer when using the destination IP address 10.100.104.20. I assume you have confirmed that that IP address can be used from the network range.
- Jouni
Community Member
No unfortunately it didn't work.
I checked the xlate and its definitely translating the IPs. We currently have the printer connected outside the firewall with the proper IP of 10.100.104.20, 255.255.255.0 and 10.100.104.1 as the gateway, prints fine.
As soon as i connect it to the firewall, IP address 172.29.8.20, 255.255.248.0 and 172.29.8.1 as the gateway the prints just do not get through.
According to our council the print spoolers are on the IP address 172.23.60.73.
So frustrating!
Many thanks
Super Bronze
Since you have been switching the Printer with the IP address 10.100.104.20 directly to the network outside of the ASA and then moving it behind the ASA and doing NAT for the local IP address to 10.100.104.20 that could mean that some upstream router might have an ARP information that pairs IP address 10.100.104.20 to the MAC address of the actual printer.
When you move the Printer behind the ASA and use the NAT then the Printer would be visible to the upstream router with the MAC address of the ASA as the ASA is doing the NAT.
In other words the upstream router would have the Printer MAC address in the ARP table (IP/MAC address pair) and couldnt therefore pass the traffic onto the ASA.
I would suggest changing the IP address for the NAT to 10.100.104.21 for example or any other IP address that you can use from the range and then trying connections again.
If you are using the NAT configuration I suggested then these changes should be enough
Go under the "object" configuration mode and then remove the current "nat" command and enter a new one.
nat (inside,outside) static 10.100.104.21
This would naturally mean the tests should be towards this new IP address. This should probably tell us if ARP is the problem (because you have had the printer directly with the NAT IP address on the network outside of ASA)
- Jouni
Community Member
The weird thing is i gave a completely different printer the 10.100.104.20 address and plugged it outside the network and it worked fine so im thinking the mac address maybe ok, but as soon as i change that printers IP to 172.29.8.20 and put it behind the firewall.. nothing!
At a loss now as to what it could be, the ASA couldn't be blocking anything else could it? They've definetely said that the printers use port 9100.
Many thanks
Super Bronze
Well you could configure a traffic capture on the ASA I guess
access-list PRINTER-CAPTURE permit ip host 10.100.104.20 any
access-list PRINTER-CAPTURE permit ip any host 10.100.104.20
capture PRINTER-CAPTURE type raw-data access-list PRINTER-CAPTURE interface outside buffer 1000000
Then you should ask them to test the connection when the Printer is behind the ASA
Then you could use the following command to check if anything has hit the capture
show capture
If something has hit the capture you could use this command to show the contents of the capture on the CLI
show capture PRINTER-CAPTURE
These should tell us if the traffic from the testers is arriving to the ASA
- Jouni
Community Member
Ok i just plugged in the 172.29 printer behind the firewall, did a test print which failed, did the printer capture and its coming up with the following:
3 packets captured
   1: 04:58:38.515277 10.100.104.20.138 > 255.255.255.255.138:  udp 201
   2: 05:01:09.341870 10.100.104.2.56538 > 10.100.104.20.161:  udp 78
   3: 05:01:09.345105 10.100.104.20.161 > 10.100.104.2.56538:  udp 81
3 packets shown
Many thanks
Super Bronze
The first capture UDP packet is a broadcast related to some Windows service. It wont go through the firewall.
The second 2 UDP packets are SNMP traffic back and forth from the Printer.
No traffic related to the ports you mentioned.
I am not sure of all the roles of the ports that Windows uses but could the broadcast message from the host 10.100.104.138 be related to the test?
It seems though that the SNMP traffic is both ways but I dont see anything else there other than the broadcast that might be unrelated also.
- Jouni
Super Bronze
Also,
I presume you had the capture configured BEFORE you did any tests?
- Jouni
Community Member
Yes i configured the capture, then did a test print, then did a show capture.
I've since put the 10.100.104.20 printer back outside of the firewall and did another capture, seems to still be getting some hits.
4: 05:10:41.985926 10.100.104.20.138 > 255.255.255.255.138:  udp 201
   5: 05:10:41.987131 10.100.104.20.137 > 255.255.255.255.137:  udp 68
   6: 05:10:42.219394 10.100.104.20.137 > 255.255.255.255.137:  udp 68
   7: 05:10:42.488835 10.100.104.20.137 > 255.255.255.255.137:  udp 68
   8: 05:11:09.450767 10.100.104.2.56538 > 10.100.104.20.161:  udp 78
   9: 05:11:09.454245 10.100.104.20.161 > 10.100.104.2.56538:  udp 81
  10: 05:14:41.004836 10.100.104.20.138 > 255.255.255.255.138:  udp 201
  11: 05:19:39.758673 10.100.104.20.138 > 255.255.255.255.138:  udp 201
  12: 05:21:08.559571 10.100.104.2.56538 > 10.100.104.20.161:  udp 78
  13: 05:21:08.563828 10.100.104.20.161 > 10.100.104.2.56538:  udp 81
13 packets shown
I believe SNMP may be disabled on the councils end but like i say it still seems to print fine when not behind the ASA.
Many thanks
Super Bronze
I actually managed to read the capture wong since it lists the ports right after the IP address. There is no IP address 10.100.104.138 as it was actually 10.100.104.20.138
Actually now that I look at it closer, it seems to me that there is traffic from behind the "inside" interface of your ASA towards that destination IP address?
And this traffic is birectional and not broadcast. The IP address 10.100.104.2 is your "outside" interface IP address with which ALL your internal hosts show up to the hosts behind the "outside" interface.
If you had taken the Printer of the "outside" network when this traffic was captured then it would seem to me that there is a device behind the "outside" interface with the IP address 10.100.104.20 already?
These packets in the capture would seem to point that there was still a device with IP address 10.100.104.20 in the network when that capture was taken
This is because we see a broadcast on the ASA to destination address 255.255.255.255 from the IP address 10.100.104.20
When the Printer is behind the "inside" interface can you do so that you clear the ARP on the ASA with the command "clear arp" and then send ICMP to the IP address 10.100.104.20 with the command "ping 10.100.104.20" and then view the arp with "show arp | inc 10.100.104.20" command.
It should show if there is a device behind the "outside" interface that is already using that IP address.
- Jouni
Community Member
Ok will run that command in a second. Clearing the ARP won't have any affect on users currently logged in and using the internet will it?
Many thanks
Super Bronze
To my understanding clearing the ARP should not cause any problems. The ASA should send ARP request for the destination IP addresses right after clearing  the ARP.
- Jouni
Community Member
Ok, ive cleared the ARP, there is now no answer from the ping so it should be clear. Should i try a print again or is there something else i can do on the ASA?
Many thanks
Super Bronze
Did you take the output of "show arp | inc 10.100.104.20" after your cleared the ARP and pinged that destination IP address? That was what I was after. The device might not reply to ICMP but it will answer to ARP requests. (If there is another device in the network with that IP address)
- Jouni
Community Member
Yep nothing is appearing after doing the show arp command.
Super Bronze
If the configuration was as suggested when the device was behind the ASA and the traffic was allowed then it doesnt seem like a problem with the ASA.
There seems to be something else wrong but I am not sure what. I dont know what the actual topology of the network is.
There should be nothing different with the Printer being NATed to the IP address towards the network segment that holds this subnet 10.100.104.0/21 or having the device directly in that network segment together with the ASA. If there is something perhaps related to broadcast traffic (which would mean users of the Printer would be in the same network 10.100.104.0/21) then that naturally stops at the ASA but not in the situation when the Printer is directly connected to the network 10.100.104.0/24
I don't know how much else can be determined from the ASA itself anymore.
We didnt see the traffic on the ASA with the capture that we were expecting and we dont know what is different in the situation when the printer is directly in the network. Unless ofcourse you capture that traffic from some switch to which the printer is connected when its outside the ASA.
- Jouni
1611
