cable based failover config on asa 5520
hi,
we had 1 5520 & have purchased 1 new asa 5520. we want to make cable based active/active failover on this 2 devices. can someone help me with sample config? i found some docs but that were for pix. i need on asa.
Silver
Re: cable based failover config on asa 5520
could u please tell me my config is correct or wrong:
interface GigabitEthernet0/3
description STATE Failover Interface
failover
failover link failover GigabitEthernet0/3
failover interface ip failover 192.168.50.1 255.255.255.0 standby 192.168.50.2
Silver
You'll need to do that for each context that you have. You also need to configure the failover groups.
See this doc. Will show you everything you need for A/A failover.
http://www.cisco.com/en/US/customer/products/ps6120/products_configuration_guide_chapter09186a008063b31a.html#wp1096075
Chad
can't active/standby filover be configured in asa in cable based failover mode?
Silver
Your original post said Active/Active. Which one are you trying to do?
Chad
if i connect the 2nd asa in cable based failover mode, will the replication be done automatically? don't i need to specify the lan, wan side ip address also??
303
