Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Calculating throughput for ASA
Is there a way that I can tell how much throughput I actually need when purchasing an ASA? I have about 5000 users, and it's easy for me to say that I need 1.2gbps, but is there a better way?
<br />
<br />Thanks!
<br />John
HTH, John *** Please rate all useful posts ***
Re: Calculating throughput for ASA
John,
There are various tools such as iperf and mrtg/prtg that can assist you in determining the appropriate sized appliance for your network.
Your Cisco Account Manager and SE should also be available to assist you in making this determination.
Hope this helps.
Community Member
This doesnt specifically answer your question, but it does list the performance of the different models:
http://www.cisco.com/web/partners/tools/quickreference/index.html
As far as bieng able to tell how much bandwidth you are using, it is difficult to answer without knowing what type of device(s) you are currently using. I would probably start by trying to collect snmp or netflow data if your device supports it. There are a lot of good free tools that will collect usage stats via snmp. Most use RRDTOOL, some I have used are MRTG, Cacti, and NMIS. Do a quick google and try one out.
*Please rate if helpful
359
