Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
can i connect to outside interface from inside then outside nats back in?
I have an ASA5510 running version 8.2(5)
I am having an issue with routing/natting from an internal network to the
outside interface IP on port 443 which has a nat back in to another internal address... is
this possible? i works externally in from a public address.
i also see log messages to do with IP Spoofing
Everyone's tags (4)
1 REPLY
Red
Hi Dino,
Unfortunately that might not be possible, you would not be able to connect to a remote interface from your internal lan, for this you might need to use any other free public ip and then u-turn the traffic.
Varun Rao
Security Team,
Cisco TAC
Thanks, Varun Rao Security Team, Cisco TAC
223
