Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Can I upgrade FWSM 4.0.3 to 4.0.17 with Chassis IOS s72033-adventerprisek9_wan-mz.122-33.SXH4.bin ?
In chassis's slot we have ACE and FWSM slot also. if I will upgrade chassis it will reboot ACE too.
I do not want to reload Chassis.
Shain Bharati
Shain Bharati CCIE (R&S) #28837
Everyone's tags (5)
Hi Shain
I upgraded my client's Cisco FWSM from 4.0.3 to 4.1.7 few months ago, and everything was good. I didn't have to do incremental upgrade as proposed by Cisco (best practise). This saves time because in the real world, we don't normally have the luxury of long maintenance window (in a non-HA environment).
However, if you choose to upgarde to 4.0.17, that's fine too. The upgrade has no bearing to the IOS version currently running in your C6509 chassis. This is because the FWSM runs on its' own operating system.
For further details on this, you could refer to http://www.cisco.com/en/US/docs/security/fwsm/fwsm41/release/notes/fwsmrn41.html
If you ask me personally, go for 4.1.9 as your FWSM will then be covered with the latest bug fixes.
P/S: If you think this comment is helpful, please do rate them accordingly.
Warm regards, Ramraj Sivagnanam Sivajanam Technical Specialist/Service Delivery Manager – Managed Service Department
Community Member
Hi Ramraj,
I am going to upgrade FWSM version 3.2(23) to 4.1(9) in couple of weeks, I read in the release notes that the configurations will be automatically changed. Could you pls let me know where can I find the new features or major differences in 4.1(9)? Also, is there any procedure to manually upgrade like from 3.2 4 and then from 4 to 4.1?
584
