Can not connect ASA through SSH and HTTPS
I have just configured the firewall with all the standard configuration but I can not gain SSH access. I have attached the running-config below, can someone please let me know what am I missing. I have configured the SSH exactly as stated at :
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/mgaccess.html#wpxref11628
still no connectivity, do I have to generate any other certificates other than the crypto rsa key which I have already generated ?
For more info, I can not even connect the device through HTTPS even after enabling the HTTP server.
Murtaza
Re: Can not connect ASA through SSH and HTTPS
What is the output of:
show crypto key mypubkey rsa
If general connectivity is OK (it does answer
to pings when connected to network, right ?)
Then I'd zeroize the current key and create new ones for a check
ASA(config)# crypto key zeroize rsa
ASA(config)# crypto key generate rsa
If it doesn't help ,trying to enable debug and
connecting simultaneously by Console and http/ssh would reveal more info ..
ASA# debug http 255
ASA# debug ssh 255
If there is some communication you'll see smth like
ASA(config)# listen: Received HTTP request.
Started http listen on interface outside port 443
ASA(config)# http_get_token: received no block data for ssl
BTW running config is OK 100%
Thanks for that Yuri, I'll have a look at the troubleshooting through debugging as suggested, the device is offline currently so I'll have to check that later.
Murtaza
548
