Cannot connect to ASA using https
I'm trying to access my box ASA 5540 by https://ipaddress but I can't. I'm using Linux. I already have installed ASDM (when it works) and I can enter in the box by ASDM.
The Mozilla show the message: "Error code: ssl_error_no_cypher_overlap".
But I was looking and I did these tests.
OSInternet Explorer 7 and 8
Mozilla Firefox 3.6
Google Chrome
Linuxdoesn't workdoesn't workdoesn't work
Windows XPWorks Finedoesn't workWorks Fine
Windows Vista / Windows 7doesn't workdoesn't workdoesn't work
I've already clear all configuration of browsers, reboot the box, reboot the machines, re-generate a crypto key on ASA, enable and disable the http server and didn't work.
st02/sec/act# sh run http
http server enable
http 192.168.1.0 255.255.255.0 management
http 0.0.0.0 0.0.0.0 external
st02/sec/act# sh run asdm
asdm image disk0:/asdm-625.bin
asdm history enable
Looking to ASA log it possible see:
6|Apr 20 2010|14:01:19|725001|192.168.100.100|35539|||Starting SSL handshake with client external:172.28.7.94/35539 for TLSv1 session.
Can anyone help with this situation.
Jennifer Halim
Check the output of: sh run all ssl
Make sure you have all the combinations of ssl encryption algorithm as per the following:
http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/s8.html#wp1406272
ssl encryption 3des-sha1 des-sha1 rc4-md5 aes128-sha1 aes256-sha1
mvsheik123
Level 7
Level 7
You might checked on this - but just incase, For Mozilla, I found the below...
https://support.mozilla.com/en-US/forum/1/585826
hth
MS
Jennifer Halim
the command
solve the problem. Thanks!
