Capture Problems on ASA
Who knows why the capture command on the asa 8.0 release does capture packets but is not able to display (or export to wireshark) all packets.
The command I use (in several variations)
capture cap1 type raw-data buffer 33554432 interface outside circular-buffer headers-only [Capturing - 17124 bytes]
the command sh capture cap1
simply shows several lines (from some thousands)
Wireshark displays "The capture file appears to have been cut short in the middle of a packet"
1 REPLY
Re: Capture Problems on ASA
Don't use the "headers-only" and then if you save the capture in pcap Wireshark should be able to open it.
I hope it helps.
PK
606
