case about remote-vpn
hi
the problem is that remote client connected the vpn device,it's ASA5505,
i can ping the PCs of inside,but i cannot ping inside interface,is it right??? if wrong,how can i access the inside interface by remote vpn client????
THANKS!!!!!!!!!
Re: case about remote-vpn
Put in the command
management-access "inside" where inside is the name of the inside interface...
you got it
thank you very much!!!!!
No Problem.
-C
113
