Checkpoint and ASA
Inside I have 2 networks: 10.10.x.x and a 10.199.x.x
My ASA interfaces was the following:
E0/0 Public IP
E0/1 10.199.1.2/24
E0/2 10.10.144.47/22
I put a checkpoint in front of the ASA and changed to the following:
Checkpoint Ext. 10.10.144.47/22
Checkpoint Int. 192.168.1.1/30
ASA E0/1 10.199.1.2/24
ASA E0/2 192.168.1.2/30
Now I am having trouble talking between the networks 10.199.x.x and 10.10.144. x
I have attached ASA config.
Thanks in advance on any help provided
1 ACCEPTED SOLUTION
Super Bronze
Checkpoint and ASA
So if I am looking correct then the "insideNOV" interface leads to the Checkpoint which has the other LAN network behind it?
The interface ACL for the interface is not really clear to me as it contains a lot of "name" and "object-group" references which are not mentioned. It seems though that on multiple occasions you have referenced the NOV network as the destination. Should this not be the source network as that network is located behind that interface?
Also with regards to the routing you have only shared your Default Route in the configuration.
Do you have a route for the NOV network towards "insideNOV" ?
route insideNOV 10.10.144.0 255.255.252.0 192.168.1.1
Does the Checkpoint have the appropriate routing and other configurations to allow the traffic?
- Jouni
Super Bronze
Checkpoint and ASA
- Jouni
Checkpoint and ASA
Jouni,
Thanks so much, I was forgeting the insideNOV inside the command.
Thanks again,
Bobby
87
