04-21-2008 09:14 AM - last edited on 03-25-2019 05:39 PM by ciscomoderator
I'm having two odd problems with a 2821 that is used as a firewall. I'll describe one of them.
Every few days, I can not access a server on the internet at port 1055. Running a 'clear ip nat trans *' does not fix the issue. Strangely enough, after reloading the 2821, access from the internal network to the internet server at port 1055 works again.
Additionally, while the problem is occurring, any other port that is listening on the internet server is accessible, just not 1055. A reload fixes the issue.
Also, sh ip nat trans only has about 1000 lines when the problem is occurring.
Any ideas what a permanent solution might be?
04-22-2008 04:47 AM
Check if you have setup low embryonic or max-connections on your access-lists somewhere.
rkalia
04-22-2008 08:18 AM
neither of those exist in the router config
05-02-2008 09:43 PM
which IOS you are using.update latest IOS first.its resolves some errors.
regs
S.Mohana sundaram
06-24-2008 03:10 PM
Upgrading didn't help. The problem magically went away. I'm still not sure what changed. I narrowed it down to a handful of lines in the Cisco config, though none of them should have helped the issue from what I could tell.
