Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Cisco 5505 and single access point.
I have a Cisco 5505 and have an access point plugged into the POE port 7.
I have 2 SSID'S on the access point
vlan 1 - production on the 192.168.70.0 /24
vlan 10 - guest                 172.16.0.0 /24
I do not have a  seperate DHCP sever so the ASA will have to act as the DHCP server for both vlans.
I need the guest network just to have access to the internet nothing else.
can this be done?
I also have the option of using IPSEC to a site which has a windows DHCP server if this helps?
James
Super Bronze
I guess you would have to configure a Trunk between the standalone AP and the ASA5505. And to support Trunking your ASA5505 would have to have Security Plus license if I dont remember wrong.
Then you could Trunk the 2 Vlans from AP to the ASA and configure separate DHCP pool for them.
Sadly I never even touch Wireless networks/devices in my work (other people for that) so I dont what your different options there are. I just imagine that if your ASA5505 is running Base License and you cannot trunk and IF your AP had 2 physical ports then you could do around the Trunking limitation of your ASA by configuring Access Mode ports for each Vlan on the ASA and connecting 2 separate ports from the AP to those ASA ports.
Allowing only Internet access for the other WLAN should be possible with simple access rules.
The DHCP through L2L VPN might be an option but its surely more complicated to set up.  If you had a Cisco router at the local site you could even use it as DHCP server. I am not sure if APs have this possibility? As I said I dont know the first thing about configuring Wireless networks.
Hope this helps
- Jouni
Community Member
Thanks for the reply.
The AP has 1 physical port so obviously this will be trunked and so will the port on the ASA. I do have the secuirty plus license.
As you can see in the config below. the actual physical IP address of the inside network is 192.168.70.254 ( port 7 facing the AP vlan 1 ) i can provide DHCP range to an interface. how do i guest the guest network to work on the ASA? and set an IP range to this network? hope this make sense?
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
shutdown
interface Ethernet0/3
shutdown
interface Ethernet0/4
shutdown
interface Ethernet0/5
shutdown
interface Ethernet0/6
shutdown
interface Ethernet0/7
switchport trunk allowed vlan 1,10
switchport trunk native vlan 1
switchport mode trunk
interface Vlan1
nameif inside
security-level 100
ip address 192.168.70.254 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address *****
Super Bronze
Well you would have to add an interface for the Vlan10
interface Vlan10
nameif guest
security-level 10
ip address 172.16.0.x 255.255.255.0
dhcpd address 172.16.0.a-172.16.0.b guest
dhcpd dns guest
dhcpd enable guest
And you would naturally need some additional configurations like interface ACL and NAT configuration depending on your needs and current configurations
- Jouni
Community Member
sorted this. thanks for you help anyway.
Super Bronze
Good to hear. Was there a problem with some configuration or were you missing some of the above configurations for example?
If any reply answered your question please do remember to mark the reply as the correct answer.
- Jouni
101
