Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Cisco Active/standby failover configuration using mgt interface
Any one Can help me to configure ASA active standby configuration, here I want to use mgt interface for both failover and state full failover link, why because all of my other interfaces are been used for
Production (internal, external, dmz, wan), that leaves me the mgmt port to for the failover. My “primary” ASA is fully configured and up and running. My "secondary" ASA has just been taken out of the box
What do I need to do on the out of box "secondary" firewall, to prepare it, so the primary can talk to secondary , do I use console for initial configuration on secondary ASA
interface Management0/0
nameif management
security-level 100
ip address 192.168.100.1 255.255.255.0
management-only
how do I change management interface to normal interface for failover?
no nameif
no security-level
no ip address
please correct above syntax
failover
failover lan unit secondary
failover lan interface failover management0/0
failover lan enable
failover key cisco
failover interface ip failover 1.1.1.1 255.255.255.0 standby 1.1.1.2
Failover interface ip state ? 255.255.255.0 standby ?
Re: Cisco Active/standby failover configuration using mgt interf
ASA - 1
failover
failover lan unit primary
failover lan interface lan-asa5520-ha Management0/0
failover link lan-asa5520-ha Management0/0
failover interface ip lan-asa5520-ha 192.168.168.1 255.255.255.252 standby 192.168.168.2
ASA - 2
failover
Good Luck
thaks,
what about the statefull failover ? can i use the same link for satefull failover in that case what will be the ip address for that ?
regards
in addition to the code posted, make sure you issue the command " no management-only" under the management interface to make it behave like a normal interface.
the stateful failover ip-address will be the same as the lan-based failover ip-address.
277
