Cisco ASA 5505 and Cisco Small Business WRVS4400N VPN tunnel
Good Morning,
I'm trying to establish a VPN tunnel between our main office running a Cisco ASA 5505 [8.3(2)] and a remote user using a Cisco Small Business WRVS4400N firmware version V2.0.1.3.
The Cisco ASA 5505 is already configured to allow incoming IPSec VPN connections via the Cisco VPN Client.
Is this possible, and if so, how would I go about doing so? The remote user has a static IP address as well as the main office.
Any information provided would be appreciated. Thanks
Good Morning,
Everyone's tags (3)
1 ACCEPTED SOLUTION
Yes, this will work.  I have it up and running.  Use the site to site vpn wizard on the ASA and then on the WRVS4400N, make sure to select the settings below.  *You need to disable PFS on the ASA either during the wizard of afterward under vpn properties/advanced.
Phase 1 >
Mode = IKE w/ Preshared Key
Encryption = 3DES
Auth = SHA1
Group = 1024 bit
key lifetime = 86400
Phase 2 >
Encryption = 3DES
Auth = SHA1
PFS = Disable
Group = 1024 bit
key lifetime = 3600
Anyone?
Phase 1 >
Encryption = 3DES
Auth = SHA1
Group = 1024 bit
Phase 2 >
Encryption = 3DES
Auth = SHA1
PFS = Disable
Group = 1024 bit
key lifetime = 3600
945
