Cisco ASA 5505 License
All,
We have bought a Cisco ASA 5505 firewall with base license. We are confused about the base license provide for 10 users. I am trying to understand what method Cisco uses to calculate license:
For example there are 3 hosts connected to the inside network of ASA currently: Output below:
Result of the command: "show arp"
            inside 130.47.22.3 0012.3f3a.4524 140
            inside 130.47.22.6 001e.3732.4fac 438
            inside 130.47.22.9 0021.861e.c1b6 465
            outside 24.240.94.1 001b.54cb.bed9 2
and non of users are authenticated:
Result of the command: "show uauth"
                                    Current               Most Seen
Authenticated Users     0             6
Authen In Progress       0             64
But when we do show local-host we find out that 6 license are already used.
Result of the command: "show local-host"
Detected interface 'outside' as the Internet interface. Host limit applies to all other interfaces.
Current host count: 6, towards licensed host limit of: 10
Interface outside: 5 active, 33 maximum active, 0 denied
Interface inside: 6 active, 8 maximum active, 0 denied
Interface _internal_loopback: 0 active, 2 maximum active, 0 denied
Can you please explain what method Cisco uses to count the number of license?
Re: Cisco ASA 5505 License
What we see in "show local-host" gives the exact picture of what is used to calculate number of inside users. Hope this calrifies it.
Prapanch
Prapanch,
I am interested in knowing the method calculation. On what basis it concludes that 6 licenses are already in use where as only 3 hosts are connected?
Dharmendra
What do you notice in the output of "show local-host". You should see IP addresses of all 6 inside users that the firewall sees.
Prapanch
Note: I have changed ip addresses for security reasons:
Here is the output of show local-host detail. It is not making sense to me. It says 6 active connections on inside interface where as I only see 1 udp connection.
Result of the command: "show local-host detail"
local host: <172.16.50.80>,
    TCP flow count/limit = 0/unlimited
    TCP embryonic count to host = 0
    TCP intercept watermark = unlimited
    UDP flow count/limit = 1/unlimited
  Conn:
    UDP outside:172.16.50.80/53 inside:172.16.22.9/53114,
        flags -, idle 54s, uptime 54s, timeout 2m0s, bytes 0
local host: <172.16.22.9>,
  Conn:
Super Bronze
Hi Dharmendra,
Please ignore my previous post as the behaviour seems to have changed.
Here is the correct behaviour as per syslog# 407001:
http://www.cisco.com/en/US/docs/security/asa/asa83/system/message/logmsgs.html#wp4773013
Hope that helps.
Thanks Jennifer, do you know if Cisco have documented this fact anywhere in their support document pages? If you have the url it will be very helpful.
Thanks, Dharmendra
3491
