Cisco asa 5505: No traffic lan to wan with IPv6
Hello everybody,
I have a Cisco ASA 5505, public ipv6 in outside interface, private ipv6 in LAN, from router I can ping any ipv6 in Internet and ping my LAN ipv6. Traffic doesn't go through router.
This is my configuration.
interface Vlan1
 nameif inside
 security-level 100
 ip address PRIV-Saturn1 255.255.255.0
 ipv6 address fc00::1/7
 ipv6 enable
interface Vlan2
 nameif outside
 security-level 0
 ip address PUBLIC26 255.255.255.248
 ipv6 address xxxx:yyyy:67:36::2/64
 ipv6 enable
 ipv6 nd suppress-ra
access-list Dynamic_Filter_ACL extended permit tcp any6 any6
ipv6 route outside ::/0 xxx:yyyy:67:36::1
Am I omitting anything?
Thanks in advance for the help.
Jos P
Everyone's tags (1)
1 REPLY
Hall of Fame Super Silver
Since you're using IPv6
Since you're using IPv6 private addressing (fc00::) on the inside, you need a dynamic NAT entry to translate your private IPv6 addresses to a public one.
Alternatively, you could just use a subnet of your registered IPv6 block for the inside network and not worry about NAT.
91
