Cisco ASA 5505 not able to access flash
Hi All:
I have searched and searched all over the net for an answer to this question and have decided to just post it. I have a 5505 that was given to me by my job to use for working on my CCNA Sec. cert and did the following:
I plugged it in and booted it up just fine. Made config changes as I followed along with the examples in my CCNA Security book. Got to the point in chapter 14 where the initial setup happens to configure it for working with ASDM. I never did a write mem on it and decided to take it back to square one by unplugging it to allow it to lose the changes that I made. This is where things got ugly.
When it booted back up it got stuck in a bootup loop and couldn't find an IOS. After following all kinds of steps to boot to rommon and tftp another IOS and such (several times) I decided to follow another posting that said that the flash could be corrupted and to just delete it and start anew. Did that and through rommon as it would not boot up normally any more. After trying this over and over for the last couple hours I realized that it would boot from tftp so I did that in hopes of fixing the flash issue.
I've tried deleting it, and re-initializing it and formating it. But the thing is that it no longer SEES the disk0: mount point. I've used two different flash cards...the one that came with it and the one that I already had. With the cover off I can see that there is no activity light next to the flash drive when I issue a delete or initialize or format command.
Here is a copy of some of the output file. Any help or suggestions are greatly appreciated.
CISCO SYSTEMS
Embedded BIOS Version 1.0(12)11 04/30/08 15:45:41.19
Low Memory: 632 KB
High Memory: 507 MB
PCI Device Table.
Bus Dev Func VendID DevID Class              Irq
00  01  00   1022   2080  Host Bridge
00  01  02   1022   2082  Chipset En/Decrypt 11
00  0C  00   1148   4320  Ethernet           11
00  0D  00   177D   0003  Network En/Decrypt 10
00  0F  00   1022   2090  ISA Bridge
00  0F  02   1022   2092  IDE Controller
00  0F  03   1022   2093  Audio              10
00  0F  04   1022   2094  Serial Bus         9
00  0F  05   1022   2095  Serial Bus         9
Evaluating BIOS Options ...
Launch BIOS Extension to setup ROMMON
Cisco Systems ROMMON Version (1.0(12)11) #4: Thu May  1 14:50:05 PDT 2008
Platform ASA5505
Use BREAK or ESC to interrupt boot.
Use SPACE to begin boot immediately.
Ethernet0/0
MAC Address: 0023.339e.2a91
Link is UP
Please set ADDRESS Variable.
Please set SERVER Variable.
Please set IMAGE Variable.
Launching BootLoader...
Default configuration file contains 1 entry.
Boot mode is 1. Default entry is 1.
Searching / for images to boot.
No images in /
Error 15: File not found
unable to boot an image
No images in /
Failsafe booting engaged.
No images in /
CISCO SYSTEMS
Low Memory: 632 KB
High Memory: 507 MB
PCI Device Table.
Platform ASA5505
Ethernet0/0
Link is UP
No images in /
No images in /
No images in /
CISCO SYSTEMS
Low Memory: 632 KB
High Memory: 507 MB
PCI Device Table.
Platform ASA5505
Ethernet0/0
Link is UP
No images in /
No images in /
No images in /
CISCO SYSTEMS
Low Memory: 632 KB
High Memory: 507 MB
PCI Device Table.
Platform ASA5505
Ethernet0/0
Link is UP
No images in /
No images in /
No images in /
CISCO SYSTEMS
Low Memory: 632 KB
High Memory: 507 MB
PCI Device Table.
Platform ASA5505
Ethernet0/0
Link is UP
No images in /
No images in /
No images in /
CISCO SYSTEMS
Low Memory: 632 KB
High Memory: 507 MB
PCI Device Table.
Platform ASA5505
Ethernet0/0
Link is UP
No images in /
No images in /
No images in /
CISCO SYSTEMS
Low Memory: 632 KB
High Memory: 507 MB
PCI Device Table.
Platform ASA5505
Boot interrupted.
Ethernet0/0
Link is UP
Use ? for help.
rommon #0> format disk0:
Invalid or incorrect command.  Use 'help' for help.
rommon #0> ADDRESS=10.10.10.110
rommon #1> GATEWAY=10.10.10.1
rommon #2> SERVER=10.10.10.98
rommon #3> IMAGE=asa914-k8.bin
rommon #4> tftp
ROMMON Variable Settings:
  SERVER=10.10.10.98
  GATEWAY=10.10.10.1
  PORT=Ethernet0/0
  VLAN=untagged
  IMAGE=asa914-k8.bin
  CONFIG=
  LINKTIMEOUT=20
  PKTTIMEOUT=4
  RETRY=20
tftp asa914-k8.bin@10.10.10.98 via 10.10.10.1
Received 27076608 bytes
Launching TFTP Image...
Cisco Security Appliance admin loader (3.0) #0: Thu Dec  5 19:38:43 PST 2013
Platform ASA5505
Loading...
IO memory blocks requested from bigphys 32bit: 9956
Àdosfsck 2.11, 12 Mar 2005, FAT32, LFN
Currently, only 1 or 2 FATs are supported, not 42.
dosfsck(/dev/hda1) returned 1
mount: mounting /dev/hda1 on /mnt/disk0 failed: Invalid argument
Processor memory 343932928, Reserved memory: 62914560
Total SSMs found: 0
Total NICs found: 10
88E6095 rev 2 Gigabit Ethernet @ index 09 MAC: 0000.0003.0002
88E6095 rev 2 Ethernet @ index 08 MAC: 0023.339e.2a90
88E6095 rev 2 Ethernet @ index 07 MAC: 0023.339e.2a8f
88E6095 rev 2 Ethernet @ index 06 MAC: 0023.339e.2a8e
88E6095 rev 2 Ethernet @ index 05 MAC: 0023.339e.2a8d
88E6095 rev 2 Ethernet @ index 04 MAC: 0023.339e.2a8c
88E6095 rev 2 Ethernet @ index 03 MAC: 0023.339e.2a8b
88E6095 rev 2 Ethernet @ index 02 MAC: 0023.339e.2a8a
88E6095 rev 2 Ethernet @ index 01 MAC: 0023.339e.2a89
y88acs06 rev16 Gigabit Ethernet @ index 00 MAC: 0023.339e.2a91
INFO: Unable to read firewall mode from flash
       Writing default firewall mode (single) to flash
INFO: Unable to read cluster interface-mode from flash
       Writing default mode "None" to flash
Verify the activation-key, it might take a while...
Failed to retrieve permanent activation key.
Running Permanent Activation Key: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
The Running Activation Key is not valid, using default settings:
Licensed features for this platform:
Maximum Physical Interfaces       : 8              perpetual
VLANs                             : 3              DMZ Restricted
Dual ISPs                         : Disabled       perpetual
VLAN Trunk Ports                  : 0              perpetual
Inside Hosts                      : 10             perpetual
Failover                          : Disabled       perpetual
Encryption-DES                    : Enabled        perpetual
Encryption-3DES-AES               : Disabled       perpetual
AnyConnect Premium Peers          : 2              perpetual
AnyConnect Essentials             : Disabled       perpetual
Other VPN Peers                   : 10             perpetual
Total VPN Peers                   : 12             perpetual
Shared License                    : Disabled       perpetual
AnyConnect for Mobile             : Disabled       perpetual
AnyConnect for Cisco VPN Phone    : Disabled       perpetual
Advanced Endpoint Assessment      : Disabled       perpetual
UC Phone Proxy Sessions           : 2              perpetual
Total UC Proxy Sessions           : 2              perpetual
Botnet Traffic Filter             : Disabled       perpetual
Intercompany Media Engine         : Disabled       perpetual
Cluster                           : Disabled       perpetual
This platform has a Base license.
Encryption hardware device : Cisco ASA-5505 on-board accelerator (revision 0x0)
                             Boot microcode        : CN1000-MC-BOOT-2.00
                             SSL/IKE microcode     : CNLite-MC-SSLm-PLUS-2_05
                             IPSec microcode       : CNlite-MC-IPSECm-MAIN-2.09
Cisco Adaptive Security Appliance Software Version 9.1(4)
  ****************************** Warning *******************************
  This product contains cryptographic features and is
  subject to United States and local country laws
  governing, import, export, transfer, and use.
  Delivery of Cisco cryptographic products does not
  imply third-party authority to import, export,
  distribute, or use encryption. Importers, exporters,
  distributors and users are responsible for compliance
  with U.S. and local country laws. By using this
  product you agree to comply with applicable laws and
  regulations. If you are unable to comply with U.S.
  and local laws, return the enclosed items immediately.
  A summary of U.S. laws governing Cisco cryptographic
  products may be found at:
  If you require further assistance please contact us by
  sending email to export@cisco.com.
  ******************************* Warning *******************************
This product includes software developed by the OpenSSL Project
for use in the OpenSSL Toolkit (http://www.openssl.org/)
Copyright (C) 1995-1998 Eric Young (eay@cryptsoft.com)
All rights reserved.
Copyright (c) 1998-2011 The OpenSSL Project.
This product includes software developed at the University of
California, Irvine for use in the DAV Explorer project
(http://www.ics.uci.edu/~webdav/)
Copyright (c) 1999-2005 Regents of the University of California.
Busybox, version 1.16.1, Copyright (C) 1989, 1991 Free Software Foundation, Inc.
51 Franklin St, Fifth Floor, Boston, MA 02110-1301  USA
Busybox comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to redistribute it under the General
Public License v.2 (http://www.gnu.org/licenses/gpl-2.0.html)
See User Manual (''Licensing'') for details.
DOSFSTOOLS, version 2.11, Copyright (C) 1989, 1991 Free Software Foundation, Inc.
59 Temple Place, Suite 330, Boston, MA 02111-1307
675 Mass Ave, Cambridge, MA 02139
DOSFSTOOLS comes with ABSOLUTELY NO WARRANTY.
grub, version 0.94, Copyright (C) 1989, 1991 Free Software Foundation, Inc.
grub comes with ABSOLUTELY NO WARRANTY.
libgcc, version 4.3, Copyright (C) 2007 Free Software Foundation, Inc.
libgcc comes with ABSOLUTELY NO WARRANTY.
Public License v.2 (http://www.gnu.org/licenseSee User Manual (''Licensing'') for details.
libstdc++, version 4.3, Copyright (C) 2007 Free Software Foundation, Inc.
libstdc++ comes with ABSOLUTELY NO WARRANTY.
Linux kernel, version 2.6.29.6, Copyright (C) 1989, 1991 Free Software
Foundation, Inc.
Linux kernel comes with ABSOLUTELY NO WARRANTY.
module-init-tools, version 3.10, Copyright (C) 1989, 1991 Free Software
Foundation, Inc.
59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
module-init-tools comes with ABSOLUTELY NO WARRANTY.
numactl, version 2.0.3, Copyright (C) 2008 SGI.
Author: Andi Kleen, SUSE Labs
Version 2.0.0 by Cliff Wickman, Chritopher Lameter and Lee Schermerhorn
numactl comes with ABSOLUTELY NO WARRANTY.
pciutils, version 3.1.4, Copyright (C) 1989, 1991 Free Software Foundation, Inc.
pciutils comes with ABSOLUTELY NO WARRANTY.
readline, version 5.2, Copyright (C) 1989, 1991 Free Software Foundation, Inc.
59 Temple Place, Suite 330, Boston, MA 02111 USA
readline comes with ABSOLUTELY NO WARRANTY.
udev, version 146, Copyright (C) 1989, 1991 Free Software Foundation, Inc.
udev comes with ABSOLUTELY NO WARRANTY.
Cisco Adapative Security Appliance Software, version 9.1,
Copyright (c) 1996-2013 by Cisco Systems, Inc.
Certain components of Cisco ASA Software, Version 9.1 are licensed under the GNU
Lesser Public License (LGPL) Version 2.1.  The software code licensed under LGPL
Version 2.1 is free software that comes with ABSOLUTELY NO WARRANTY.  You can
redistribute and/or modify such LGPL code under the terms of LGPL Version 2.1
(http://www.gnu.org/licenses/lgpl-2.1.html).  See User Manual for licensing
details.
                Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
                Cisco Systems, Inc.
                170 West Tasman Drive
                San Jose, California 95134-1706
Insufficient flash space available for this request:
  Size info: request:32 free:0  delta:32
Could not initialize system files in flash.
config_fetcher: channel open failed
ERROR: MIGRATION - Could not get the startup configuration.
INFO: Power-On Self-Test in process.
INFO: Power-On Self-Test complete.
INFO: MIGRATION - Saving the startup errors to file 'flash:upgrade_startup_errors_200804300128.log'
Pre-configure Firewall now through interactive prompts [yes]? n
Type help or '?' for a list of available commands.
ciscoasa> en
Password:
ciscoasa# format disk0:
Format operation may take a while. Continue? [confirm]
Format operation will destroy all data in "disk0:".  Continue? [confirm]
Initializing partition - done!
Creating FAT16 filesystem
mkdosfs 2.11 (12 Mar 2005)
System tables written to disk
Format of disk0 complete
ciscoasa# format disk:
ERROR: % Invalid input detected at '^' marker.
ciscoasa# format flash:
Format operation will destroy all data in "flash:".  Continue? [confirm]
ciscoasa# format disk0:/
/dev/hda1: No such file or directory
mount: mounting /dev/hda1 on /mnt/disk0 failed: No such file or directory
ciscoasa#
1 ACCEPTED SOLUTION
Bronze
0 bytes total (0 bytes free)
You can try to reseat the flash, if this doesn't work then it will have to be replaced.
Felipe.
Remember to rate useful posts.
Re: Cisco ASA 5505 not able to access flash
Could you post 'show flash' output?
You could do 'erase' flash' but note it will remove license/activation keys.
Yeah...I think I found that one out the hard way already. I'll cross that bridge when I get to it. I want to get this issue fixed before I start thinking about the license issue.
ciscoasa#
ciscoasa#
ciscoasa#
ciscoasa# sh flash
--#--  --length--  -----date/time------  path
2403  0           Apr 30 2008 02:00:56  test
2285  196         Apr 30 2008 01:28:20  upgrade_startup_errors_200804300128.log
2283  0           Apr 30 2008 01:28:20  coredumpinfo
2284  59          Apr 30 2008 01:28:20  coredumpinfo/coredump.cfg
2280  0           Apr 30 2008 01:27:56  crypto_archive
2267  0           Apr 30 2008 01:27:38  log
ciscoasa#
ciscoasa#
ciscoasa#
ciscoasa# sh disk0
ciscoasa#
Bronze
Felipe.
I know that my original post was long but, as mentioned earlier, I have tried multiple flash cards. I guess I should not have pressumed that it would be understood that I properly seated both cards before posting here for advice. The zero bytes total started before I opened it up to look at the flash card and/or swap it out for another one. I have a third one that I'm going to try. But in the mean time....
Any other suggestions?
Hello Ellis,
Weird enough,
So if you change it to another you still see the 0 Byte???
I mean you will need to copy a ASA Image to the Flash in order to boot properly but with that disk space you are going to have issues.
If you change it to a different memory card and do a sh flash what do you get?
Looking for some Networking Assistance?
Contact me directly at jcarvaja@laguiadelnetworking.com
I will fix your problem ASAP.
Cheers,
Julio Carvajal Segura
http://laguiadelnetworking.com
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
So I decided to take it back to work and have our firewall guy to look at it. He said that it was a common ASA issue and popped in a new flash that Cisco had just delivered and voila...it booted right up. Thank you all for the help.
if my memory is correct there
if my memory is correct there was a manufacturing issue with a batch of asa5505 and had flash problems.
i remember a few years back we had to replace a bunch of them because of this.
we just had 3 of them fail while we were upgrading firmware
I have the same issue with my ASA 5505, can you suggest me please what is the excect solution for the same?
Is it about new flash card solution or something issue with the ASA?
2546
