Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Cisco ASA 5505 - outside can't DHPC as router use same range
Im new to the ASA and is trying to setup at test net. The ASA is connected to my router on port zero using DHPC.
(Or i guess its not as the router use the same ip range as ASA does inside).
I tried to set a static IP in the same range (eg. 192.168.1.20) but then get the message "cannot overlap with the subnet of interface inside".
So I belive that is why it dont get a IP from my router - it does show up in the router DHPC table as 192.168.1.5 but ASDM home says outside "no IP address".
I tried to change the inside range of the ASA but if I change the inside IP i loose connection.
(Had to restore factory-default useing the console).
I guess I could setup another range using the console, but how?
How can I setup this test net?
1 ACCEPTED SOLUTION
Re: Cisco ASA 5505 - outside can't DHPC as router use same range
Hello Frank,
For the DHCP to work:
dhcpd adresss 192.168.2.2 192.168.2.254 inside
dhcpd enable inside
dhcpd dns 4.2.2.2 interface inside
For the PC on the inside to be able to access ASDM
http 0 0 inside
Please rate helpful posts,
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Hello Frank,
Correct, you cannot have the same ip address on two interfaces because the ASA got to divide the broadcast domain (routed mode)
So you need to change the DCHP scoope address ( Ip address and DHCP configuration on the router) or change the inside interface of the ASA.
Option 1:
On the ASA
vlan 1
no ip add
ip add 192.168.2.1 255.255.255.0
Option2:
On the router ( lets say port 0/1 is connected to the ASA)
Interface ethernet 0/1
no ip add
ip dhcp pool Inside_Firewall
network 192.168.3.0 255.255.255.0
default-router 192.168.2.1
ip dhcp excluded-address 192.168.2.1
This two solutions will do it for you..
Please rate helpful hosts.
Julio
Julio Carvajal
Community Member
Thanks.
The commands seems to work (Except it should be "interface vlan 1" to be accepted).
- But still no working asa.
The sesson:
ciscoasa(config)# vlan 1
ERROR: % Invalid input detected at '^' marker.
ciscoasa(config)# interface vlan 1
ciscoasa(config-if)# no ip add
WARNING: DHCPD bindings cleared on interface 'inside', address pool removed
ciscoasa(config-if)# ip add 192.168.2.1 255.255.255.0
However Im still not able to connect. Both 192.168.2.1 and 192.168.1.1 did not respond.
I then tried a reboot (turned the asa on/off).
It showed this error during boot:
ciscoasa> ERROR: Failed to apply IP address to interface Vlan2, as the network overlaps with interface Vlan1. Two interfaces cannot be in the same subnet.
It seems the IP change command for vlan1 was accepted - how can i read out current setting?
Hello Frank,
You did not save the changes so as soon as you rebooted the ASA it will go to the last configuration saved ( the one with the issue)
What do you mean you cannot connect from vlan 1 to vlan 2, do you have nat configured to accomplish that?
Can you share the configuration file with the changes I have asked you to make.
Julio
Julio Carvajal
Community Member
If I need to save I did not. (I have not used the console before).
Found the: "write memory" and reload command.
I cant connect to the asa using ADSM-IDM Launcher (from PC connected to the inside lan).
It seems that the asa DHPC server does not work.
And: show running-config
ciscoasa# show running-config
: Saved
ASA Version 8.2(5)
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 192.168.2.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
no ip address
ftp mode passive
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
dhcp-client client-id interface outside
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:5085ad55b43198c7490b2edfee450906
: end
Hello Frank,
Please make the following changes and let me know the result:
no http 192.168.1.0 255.255.255.0 inside
no dhcp-client client-id interface outside
no dhcpd auto_config outside
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
Hope this helps.
Julio
Julio Carvajal
Community Member
Hi Julio,
The ADSM-IDM Launcher is still unable to connect.
And the PC connected to the inside ports still dont get a IP from the asa.
show running-config:
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ftp mode passive
pager lines 24
mtu inside 1500
mtu outside 1500
arp timeout 14400
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
Cryptochecksum:050b5d46b0af856b0c016c5ea4b4f9b8
: end
Hello Frank,
dhcpd enable inside
http 0 0 inside
Julio
Julio Carvajal
Community Member
Thanks that did the magic. I now got a IP for the PC and the asa got a IP from my router.
Just for future references here are the working commands:
ciscoasa(config)# dhcpd address 192.168.2.2-192.168.2.254 inside
Warning, DHCP pool range is limited to 32 addresses, set address range as: 192.168.2.2-192.168.2.33
ciscoasa(config)# dhcpd enable inside
ciscoasa(config)# dhcpd dns 4.2.2.2 interface inside
ciscoasa(config)# http 0 0 inside
Hello Frank,
That is something great to hear.
Have a wonderful day,
Julio
Julio Carvajal
2122
