Cisco ASA 5505 problem resetting the enable password - how to bypass the security policy
I am trying to access & control a Cisco ASA 5505 firewall via console access. The problem is that I do not have a working enable password and I need to reset it. I've checked the Cisco manual and other various posts online and these are the instructions I was going to use:
1.      Power cycle ASA
2.      As it boots keep pressing ESC so that the ronmon> prompt shows up
3.      Type confreg
4.      Type n for each item except for: “disable system configuration” (push y)
5.      Type “boot” -> prompt will then become “ciscoasa>”
6.      Type “enable” and leave password blank, push enter, now it will change to ciscoasa#
7.      Type “copy start run”
8.      Now type “config t”
9.      Type “enable password cisco” (this sets pw to cisco)
10.      Type “config-register 0x10011”
11.      Type “exit”
12.      Type “copy run start”
13.      Type “reload” to reboot
The problem is that on Step #2 when I try to interrupt the boot up sequence, I get the following error:
WARNING:  Password recovery and ROMMON command line access has been
disabled by your security policy.  Choosing YES below will cause ALL
configurations, passwords, images, and files systems to be erased.
ROMMON command line access will be re-enabled, and a new image must be
downloaded via ROMMON.
It sounds like at this point the only way to get past this will be a factory reset. This is problematic since I want to retrieve the current running config. This is a live firewall being used daily by a small company.
Any ideas what I should take as the next step? Does anyone know if Cisco has a way to get past this if we purchase a service contract for this ASA to get the support?
1 REPLY
Hall of Fame Super Silver
If password recovery is
If password recovery is disabled then you are locked out hard. You have to sacrifice the config to "re-admin" the appliance. Sorry for the bad news but that's the way it is by design. If there was a "back door" it would hardly be a security appliance would it?
263
