Cisco ASA 5510 8.3 open ports problem
Hi All,
I got a situation here for Nat-ed IPs i configured. I expected to open some ports on the interface to allow certain traffics to pass through, yet there are some of them are failed. Down is my current config.
object-group service DM_INLINE_SERVICE_1
service-object icmp
service-object tcp destination eq https
service-object tcp-udp destination eq 443
service-object tcp-udp destination eq 3389
service-object tcp-udp destination eq www
service-object tcp-udp destination eq domain
service-object tcp-udp destination eq 5061
service-object tcp-udp destination eq 3478
access-list outside_access_in extended permit object-group DM_INLINE_SERVICE_2
ny any
access-group outside_access_in in interface outside
The only ports opened are 443, www, 3389 while ports domain, 5061,3478,3389.
Please advise how to open domain, 5061, 3478, and 3389 ports on my ASA .
  • Firewalling
Red
Hi Luqman,
What are the static commands that you have, can you please let me know the ip address for which you need to open these ports and can you also share an output of "show run static"
Varun
Thanks, Varun Rao Security Team, Cisco TAC
Hi Varun,
object network DMZ-11
host 192.168.1.11
nat (DMZ,outside) static 1.1.1.1
object network DMZ-12
host 192.168.1.12
nat (DMZ,outside) static 1.1.1.2
object network DMZ-13
host 192.168.1.13
nat (DMZ,outside) static 1.1.1.3
I supposed those the only static nat i configured. and those IPs above i want it ports opened as well, sh run static doesnt work on 8.3 version. I tried using any any but seems doesnt work either on access list.
Red
Can you please use these static and try:
object newtork DMZ11_public
  host 1.1.1.1
object newtork DMZ12_public
  host 1.1.1.2
object newtork DMZ13_public
  host 1.1.1.3
nat (outside,DMZ) source static any any destination static DMZ11-public DMZ-11
nat (outside,DMZ) source static any any destination static DMZ12-public DMZ-12
nat (outside,DMZ) source static any any destination static DMZ13-public DMZ-13
Let me knw how it goes.
Varun
Hi varon, nope, still remain the same.
I reckon there's nothing wrong with the NAT but the access list it self since some ports are opened.
Red
Hi Luqman,
If you suspect it to be the access-list, can you just for testing apply this:
access-list outside_access_in extended permit any any
Just check if it works, if not then it does seem to be the ACL issue.
Lets see what happens.
Varun
Hi Varun,
It doesnt work either. Anyway, below is the packet tracer i did try.
ciscoasa# packet-tracer input DMZ tcp 8.8.8.8 80 192.168.1.11 5061
Result:
input-interface: DMZ
input-status: up
input-line-status: up
output-interface: DMZ
output-status: up
output-line-status: up
Action: allow
Does it mean it already opened ? yet i still cant see it opened on the scanner
1755
